SR2100U
SR2100U
    DY(迪一电子)
    DO-15(DO-204AC)
    直流反向耐压(Vr):100V;平均整流电流(Io):2A;正向压降(Vf):820mV@2A;
SR2100U 数据手册
S R 220U THRU S R 225 0U 2.0 AMP. Schottky Barrier Rectifiers Features · Low forward voltage drop · High current capability DO-15 · High reliability · High surge current capability · Plastic material-UL flammability 94V-0 MIN. DIA. Mechanical Data · Case: Molded plastic DO-15 · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed DIA. · Polarity: Color band dentes cathode end MIN. · Mounting Position: Any Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL SR SR SR SR SR SR SR SR SR SR SR Unit 220U 230U240U 245U 250U 260U 280U2100U 2150U 2200U 2250U Maximum Recurrent Peak Reverse Voltage VRRM 20 30 40 Maximum RMS Voltage VRMS 21 26 Maximum DC Blocking Voltage VDC 14 20 30 40 Average Rectified Output Current (Note 1) @TL =120℃ IF(AV) 2.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 70 A I 2t 20.335 A2s I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=2.0A Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=100℃ Typical Junction Capacitance CJ Typical Thermal Resistance Junction to Ambient(Note 2) Operating Temperature Range Storage Temperature Range 45 0.50 VFM IR 45 50 31. 5 35 50 60 80 100 150 200 250 V 42 56 70 105 140 175 V 60 80 100 150 200 250 V 0.67 0.82 0.90 0.1 0.05 10.0 5.0 220 R θJA 180 V mA pF 75.0 ℃/W TJ -55 to + 150 ℃ TSTG -55 to + 150 ℃ Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2.P.C.B.mounted with 0.2x 0.2" (5.0x 5.0mm) copper pad areas version:02 0.92 1of3 www.dyelec.com S R 220U THRU S R 225 0U FIG.2-TYPICAL FORWARD CHARACTERISTICS INSTANTANEOUS FORWARD CURRENT ( A ) 1.6 1.2 0.8 0.4 0 50 75 100 125 150 175 10.0 1 0.01 LEAD TEMPERATURE, ℃ INSTANTANEOUS REVERSE CURRENT (mA ) PEAK FORWARD SURGE CURRENT (A) 60 45 30 15 4 6 8 10 20 40 60 80 100 0.4 0.6 0.8 1.0 1.2 1.4 1.6 V 100 10 TJ=100 C 1 TJ=75 C 0.1 0.01 TJ=25 C 0.001 0 20 40 60 REVERSE VOLTAGE NUMBER OF CYCLES AT 60Hz version:02 0.2 FIG. 4 – TYPICAL JUNCTION CAPACITANCE 75 2 0 INSTANTANEOUS FORWARD FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 1 SR220U-SR245U SR250U-SR260U SR280U-SR2100U SR2150U-SR2200U SR2250U 0.1 2of3 80 ) 25 TA=25 C % 100 ( 0 50 ) 2.0 ( AVERAGE FORWARD CURRENT (A) FIG. 1 – FORWARD CURRENT DERATING CURVE www.dyelec.com S R 220U THRU S R 225 0U Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
SR2100U 价格&库存
很抱歉,暂时无法提供与“SR2100U”相匹配的价格&库存,您可以联系我们找货
