FR201GR THRU FR207GR
2.0AMPS . GLASS PASSIVATED FAST RECOVERY RECTIFIERS
DO-15
FEATURE
.Fast switching
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /10sec/ 0.375" lead length at 5 lbs tension
1.0(25.4)
MIN.
.140(3.6)
.104(2.6)
.300(7.6)
.230(5.8)
MECHANICAL DATA
.Terminal: Plated axial leads solderable per
MIL-STD 202E, method 208C
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Polarity: color band denotes cathode
.Mounting position: any
DIA.
1.0(25.4)
MIN.
.034(0.9)
.028(0.7)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
.375"(9.5mm) lead length
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rated load (JEDEC
method)
Maximum Instantaneous forward Voltage at
2.0A DC
Maximum DC Reverse Current
@TJ =25°C
at rated DC blocking voltage
@TJ =125°C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance (Note 3)
Storage Temperature
Operation Junction Temperature
SYM
BOL
FR201
FR202
FR203
FR204
FR205
FR206
FR207
GR
GR
GR
GR
GR
GR
GR
VRRM
VRMS
VDC
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
50
100
200
400
600
800
1000
V
units
IF(AV)
2.0
A
IFSM
60.0
A
VF
1.3
V
IR
5.0
100.0
µA
trr
CJ
R(JA)
R(JC)
TSTG
TJ
150
250
13
70
22
nS
pF
°C/W
-55 to +150
°C
-55 to +150
°C
Note:
1. Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
3. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted.
-1-
500
RATING AND CHARACTERISTIC CURVES (FR201GR THRU FR207GR)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
10
2.0
1.0
Single Phase Half
Wave 60Hz
Resistive or
inductive Load
1.0
0.1
5
0.8
1.1
1.4
AMBIENT TEMPERTURE,(℃)
INSTANEOUS FORWARD
VOLTAGE,(V)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
80
8.3ms Single Half
Sine-Wave (JEDEC
Method)
40
INSTANEOUS REVERSE
CURRENT,(μA)
PEAK FORWARD SURGE
CURRENT,(A)
.01
60
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
TJ=125℃
TJ=100℃
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERSITIC
50 Ω
NONINDUCTIVE
25Vdc
(approx)
10 Ω
NONINDUCTIVE
PULSE
GENERATOR
(NOTE 2)
1Ω
(NOTE 1)
NON- OSCILOSCOPE
INDUCTIVE
NOTES:1. Rise Time=7ns max, Input
Impedance= 1 megohm.22pF.
2. Rise Time=10ns max,
Souce Impedance= 50 ohms.
-2-
1.7
很抱歉,暂时无法提供与“FR207GR”相匹配的价格&库存,您可以联系我们找货
