HER101 THRU HER108
HIGH EFFICIENCY RECTIFIERS
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
DO-41
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
High speed switching for high efficiency
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
MECHANICAL DATA
Dimensions in inches and (millimeters)
Case: JEDEC DO-41 molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.012 ounce, 0.34 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS HER
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=50 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
VRRM
VRMS
VDC
101
HER
102
50
35
50
100
70
100
HER
103
HER HER
104 105
200 300
140 210
200 300
400
280
400
HER
106
HER
107
HER
108
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
IFSM
30.0
A
VF
1.3
1.0
1.70
5.0
100.0
IR
trr
50
CJ
RθJA
TJ,TSTG
15.0
µA
75
12.0
50.0
-55 to +150
V
ns
pF
C/W
C
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted
DN:T06S03A0
STAR SEA
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES HER101 THRU HER108
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
1
0.1
HER101-HER103
HER104-HER105
HER106-HER108
0.01
0.2
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
HER101-HER105
HER106-HER108
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
DN:T06S03A0
100
t,PULSE DURATION,sec.
STAR SEA
很抱歉,暂时无法提供与“HER107”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19538
- 200+0.15893
- 600+0.13868
