Former Licensed Product from
ON Semiconductor a trademark
of Semiconductor Components
Industries,LLC
TAK CHEONG
1 Watt DO-41 Hermetically
Sealed Glass Zener Voltage
Regulators
Maximum Ratings
Rating
Symbol
Value
Units
Maximum Steady State Power Dissipation
PD
1
W
6.67
mW/℃
-65 to +200
°C
@TL≤50℃, Lead Length = 3/8”
Derate Above 50℃
Operating and Storage
Temperature Range
TJ, Tstg
L
1N
47
xx
A
L
1N47xxA
Specification Features:
= Logo
= Device Code
Zener Voltage Range = 3.3V to 75V
ESD Rating of Class 3 (>6 KV) per Human Body Model
DO-41 Package (DO-204AL)
Double Slug Type Construction
Former Metallurgical Bonded Construction
Oxide Passivated Die
RoHS Compliant and Halogen Free
Solder Hot Dip Tin (Sn) Lead Finish
Cathode
Anode
Case
: Double slug type, hermetically sealed glass
Finish
: All external surfaces are corrosion resistant and leads are readily solderable
Polarity : Cathode indicated by polarity band
Mounting: Any
Number: DB-070
Jun.2016/ H
Page 1
1N4728A through 1N4761A Series
Industries,LLC
TAK CHEONG
ELECTRICAL CHARACTERISTICS (TA = 25℃ unless otherwise noted.)
Zener Voltage (Note 2 & 3.)
Device
(Note 1.)
Device
Marking
VZ (Volts)
Zener Impedance (Note 4.)
@IZT
ZZT @IZT
Leakage Current
ZZK @IZK
IR @ VR
Min
Nom
Max
(mA)
(Ω)
(Ω)
(mA)
(uA Max)
(Volts)
1N4728A
1N4728A
3.135
3.3
3.465
76
10
400
1
100
1
1N4729A
1N4729A
3.420
3.6
3.780
69
10
400
1
100
1
1N4730A
1N4730A
3.705
3.9
4.095
64
9
400
1
50
1
1N4731A
1N4731A
4.085
4.3
4.515
58
9
400
1
10
1
1N4732A
1N4732A
4.465
4.7
4.935
53
8
500
1
10
1
1N4733A
1N4733A
4.845
5.1
5.355
49
7
550
1
10
1
1N4734A
1N4734A
5.320
5.6
5.880
45
5
600
1
10
2
1N4735A
1N4735A
5.890
6.2
6.510
41
2
700
1
10
3
1N4736A
1N4736A
6.460
6.8
7.140
37
3.5
700
1
10
4
1N4737A
1N4737A
7.125
7.5
7.875
34
4
700
0.5
10
5
1N4738A
1N4738A
7.790
8.2
8.610
31
4.5
700
0.5
10
6
1N4739A
1N4739A
8.645
9.1
9.555
28
5
700
0.5
10
7
1N4740A
1N4740A
9.500
10
10.50
25
7
700
0.25
10
7.6
1N4741A
1N4741A
10.45
11
11.55
23
8
700
0.25
5
8.4
1N4742A
1N4742A
11.40
12
12.60
21
9
700
0.25
5
9.1
1N4743A
1N4743A
12.35
13
13.65
19
10
700
0.25
5
9.9
1N4744A
1N4744A
14.25
15
15.75
17
14
700
0.25
5
11.4
1N4745A
1N4745A
15.20
16
16.80
15.5
16
700
0.25
5
12.2
1N4746A
1N4746A
17.10
18
18.90
14
0.25
5
13.7
1N4747A
1N4747A
19.00
12.5
22
750
0.25
5
15.2
1N4748A
1N4748A
20.90
22
23.10
11.5
23
750
0.25
5
16.7
1N4749A
1N4749A
22.80
24
25.20
10.5
25
750
0.25
5
18.2
1N4750A
1N4750A
25.65
27
28.35
9.5
35
750
0.25
5
20.6
1N4751A
1N4751A
28.50
30
31.50
8.5
40
1000
0.25
5
22.8
1N4752A
1N4752A
31.35
33
34.65
7.5
45
1000
0.25
5
25.1
1N4753A
1N4753A
34.20
36
37.80
7
50
1000
0.25
5
27.4
1N4754A
1N4754A
37.05
39
40.95
6.5
60
1000
0.25
5
29.7
1N4755A
1N4755A
40.85
43
45.15
6
70
1500
0.25
5
32.7
1N4756A
1N4756A
44.65
47
49.35
5.5
80
1500
0.25
5
35.8
1N4757A
1N4757A
48.45
51
53.55
5
95
1500
0.25
5
38.8
1N4758A
1N4758A
53.20
56
58.80
4.5
110
2000
0.25
5
42.6
1N4759A
1N4759A
58.90
62
65.10
4
125
2000
0.25
5
47.1
1N4760A
1N4760A
64.60
68
71.40
3.7
150
2000
0.25
5
51.7
1N4761A
1N4761A
71.25
75
78.75
3.3
175
2000
0.25
5
56.0
VF = 1.2V Max @IF = 200mA for 30V below types, VF = 2.0V Max @IF = 200mA for 30~56V types, and VF = 3.0V Max @IF = 200mA for 60V
above types
1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ)
The type numbers listed have a standard tolerance on the nominal zener voltage of ± 5%.
2. SPECIALS AVAILABLE INCLUDE
Nominal zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery, contact
you nearest Tak Cheong representative.
3. ZENER VOLTAGE (VZ) MEASUREMENT
The zener voltage (VZ) is tested under pulse condition. The measured VZ is guaranteed to be within specification with device junction in
thermal equilibrium.
Number: DB-070
Jun.2016/ H
Page 2
Industries,LLC
TAK CHEONG
4. ZENER IMPEDANCE (ZZ) DERIVATION
The zener impedance is derived from the 60 cycle AC voltage, which results when an AC current having an RMS value equal to 10% of the
DC zener current (IZT or IZK) is superimposed on IZT or IZK.
Package Outline
Case Outline
DO-41
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.68
0.81
0.027
0.032
B
3.70
4.25
0.146
0.167
C
25.40
1.000
D
2.10
2.60
0.083
0.102
Number: DB-070
Jun.2016/ H
Page 3
很抱歉,暂时无法提供与“1N4745ATA”相匹配的价格&库存,您可以联系我们找货
