TAK CHEONG
SE MI COND U C TO R
1 Watt DO-41 Hermetically
Sealed Glass Zener Voltage
Regulators
AXIAL LEAD
DO41
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Parameter
Value
Units
-65 to +175
°C
+175
°C
Total Device Dissipation
1.0
Watt
Thermal Resistance Junction to Lead
53.5
°C / W
Thermal Resistance Junction to Ambient
100
°C / W
Storage Temperature Range
Maximum Junction Operating Temperature
DEVICE MARKING DIAGRAM
L
1N
47
xx
T
L
: Logo
Device Code
: TC1N47xxT
VZ Tolerance (T) : A = ±5%
C = ±2%
These ratings are limiting values above which the serviceability of the diode may be impaired.
Specification Features:
Zener Voltage Range 3.3 to 56 Volts
Through-Hole Device Type Mounting
Hermetically Sealed Glass
Compression Bonded Construction
Cathode
Anode
All External Surfaces Are Corrosion Resistant And Leads Are Readily Solderable
RoHS Compliant
ELECTRICAL SYMBOL
Solder Hot Dip Tin (Sn) Terminal Finish
Cathode Indicated By Polarity Band
Electrical Characteristics
ZZT @ IZT
IZT
IZK
(Ω)
(mA)
(mA)
Max
ZZK @ IZK
(Ω)
Max
IR @ VR
(µA)
Max
VR
(Volts)
1
400
100
1
1
400
100
1
9
1
400
50
1
58
9
1
400
10
1
4.7
53
8
1
500
10
1
TC1N4733A
5.1
49
7
1
550
10
1
TC1N4734A
5.6
45
5
1
600
10
2
TC1N4735A
6.2
41
2
1
700
10
3
TC1N4736A
6.8
37
3.5
1
700
10
4
TC1N4737A
7.5
34
4
0.5
700
10
5
TC1N4738A
8.2
31
4.5
0.5
700
10
6
TC1N4739A
9.1
28
5
0.5
700
10
7
TC1N4740A
10
25
7
0.25
700
10
7.6
TC1N4741A
11
23
8
0.25
700
5
8.4
TC1N4742A
12
21
9
0.25
700
5
9.1
TC1N4743A
13
19
10
0.25
700
5
9.9
TC1N4744A
15
17
14
0.25
700
5
11.4
Device Type
VZ @ IZT
(Volts)
Nominal
TC1N4728A
3.3
76
10
TC1N4729A
3.6
69
10
TC1N4730A
3.9
64
TC1N4731A
4.3
TC1N4732A
Number: DB-031
Jun 2016/ I
Page 1
TC1N4728A through TC1N4761A
TAK CHEONG
SE MI COND U C TO R
Device Type
VZ @ IZT
(Volts)
Nominal
IZT
(mA)
ZZT @ IZT
(Ω)
Max
IZK
(mA)
ZZK @ IZK
(Ω)
Max
IR @ VR
(µA)
Max
VR
(Volts)
TC1N4745A
16
15.5
16
0.25
700
5
12.2
TC1N4746A
18
14
700
5
13.7
TC1N4747A
22
0.25
750
5
15.2
TC1N4748A
22
11.5
23
0.25
750
5
16.7
TC1N4749A
24
10.5
25
0.25
750
5
18.2
TC1N4750A
27
9.5
35
0.25
750
5
20.6
TC1N4751A
30
8.5
40
0.25
1000
5
22.8
TC1N4752A
33
7.5
45
0.25
1000
5
25.1
TC1N4753A
36
7
50
0.25
1000
5
27.4
TC1N4754A
39
6.5
60
0.25
1000
5
29.7
TC1N4755A
43
6
70
0.25
1500
5
32.7
TC1N4756A
47
5.5
80
0.25
1500
5
35.8
TC1N4757A
51
5
95
0.25
1500
5
38.8
TC1N4758A
56
4.5
110
0.25
2000
5
42.6
TC1N4759A
62
4.0
125
0.25
2000
5
47.1
TC1N4760A
68
3.7
150
0.25
2000
5
51.7
TC1N4761A
75
3.3
175
0.25
2000
5
56.0
VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types
Notes:
1. TOLERANCE AND TYPE NUMBER DESIGNATION (VZ)
The type numbers listed have a standard tolerance on the nominal zener voltage of ± 5%. Device tolerance of ±2% is indicated by a
“C” instead of an “A”.
2. SPECIALS AVAILABLE INCLUDE
Nominal zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery,
contact you nearest Tak Cheong representative.
3. ZENER VOLTAGE (VZ) MEASUREMENT
The zener voltage (VZ) is tested under pulse condition.
4. ZENER IMPEDANCE (ZZ) DERIVATION
The zener impedance is derived from the 60 cycle AC voltage, which results when an AC current having an RMS value equal to 10%
of the DC zener current (IZT or IZK) is superimposed on IZT or IZK.
Number: DB-031
Jun 2016/ I
Page 2
TAK CHEONG
SE MI COND U C TO R
Typical Characteristics
1000
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
VR = 2V
100
VR = 5V
VR = 30V
0.1
1
60
80
100
120
140
160
180
5
10 15 20 25
Figure 1. Power Dissipation vs Ambient Temperature
50 55 60
Figure 2. Total Capacitance
Valid provided leads at a distance of 0.8mm from case are kept at
ambient temperature
1000
30 35 40 45
VZ - Reverse Voltage [V]
Temperature [℃]
1000
Iz=1mA
Iz=2mA
Ta = 25℃
Ta = 25℃
Iz=5mA
100
Forward Current [mA]
Differential Zener Impedance [Ω]
VR = 20V
10
0.0
Iz=10mA
10
1
100
10
1
0.1
0.1
40
50
0.2
0.4
0.6
0.8
VF - Forw ard Voltage [V]
1
1.2
Figure 4. Forward Current vs. Forward Voltage
Figure 3. Differential Impedance vs. Zener Voltage
1000
100
Reverse Current [mA]
f = 1MHz
Ta = 25℃
VR = 0V
Total Capacitance [pF]
PD-Power Passipation [W]
1.0
100
Ta = 25℃
10
1
10
Ta = 25℃
1
0.1
0.01
0.1
6
9
12
Figure 5. Reverse Current vs. Reverse Voltage
15
10
40
50
60
70
Figure 6. Reverse Current vs. Reverse Voltage
Number: DB-031
Jun 2016/ I
Page 3
TAK CHEONG
SE MI COND U C TO R
Package Outline
Package
Case Outline
D0-41
DO-41
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.68
0.81
0.027
0.032
B
4.25
0.167
C
25.40
1.000
D
2.10
2.60
0.083
0.102
Notes: .
1.
DO41 polarity denoted by cathode band.
Number: DB-031
Jun 2016/ I
Page 4
很抱歉,暂时无法提供与“TC1N4752ATB”相匹配的价格&库存,您可以联系我们找货
