MT855X
Omni-polar, High Voltage & Low Power
Consumption Hall-Effect Switch IC
1 Product Description
The MT855X family is produced by BCD technology
with both high performance and high reliability. The
Hall IC internally includes an on-chip Hall voltage
generator, a voltage regulator for operation with
supply voltage of 3.0V to 24V, temperature
compensation circuitry, small-signal amplifier, Hall IC
with dynamic offset cancellation system, Schmitt
trigger and open drain output. It also includes an
clamp diode at output and reversed power supply
protection enhances the robustness of Hall IC.
The product responds to either North pole or South
pole magnetic fields. The output will be turned on
(Low) when the magnetic flux density (B) is larger
than the operating point (BOP), and be turned off
(High) when the magnetic flux density (B) is lower
than the releasing point (BRP).
The MT855X family provides a variety of packages to
customers: SOT-23 for surface mount and flat TO-92
for through-hole mount. All packages are RoHS
compliant.
4 Applications
Home appliances, Industrial
Position Detection
Magnetic Encoder
Proximity Switch
5. Pin Configuration and Functions
2 Features
BCD Technology
Omni-polar Switch
3.0~24V Operating Vcc Range
-40℃~125℃ Operating Temperature
Package Option:
Flat TO-92
SOT-23
Magnetic Sensitivity Option:
MT8551 (BOP=±32Gs, BRP=±27Gs)
MT8552 (BOP=±80Gs, BRP=±60Gs)
MT8553 (BOP=±60Gs, BRP=±45Gs)
Open Drain Output
-16V Reversed Power Supply Protection
Output Limiting Current Protection
RoHS Compliant: (EU)2015/863
VCC
Out
GND
SOT-23
1
2
3
Flat TO-92
1
3
2
Description
Power
Open
Drain
Ground
3 Product Overview of MT855X
Part No.
Description
MT855XA
Flat TO-92, bulk packaging
(1000pcs/bag)
MT855XAT
SOT-23, tape & reel
(3000pcs/bag)
Figure.1
magntek.com.cn | Magnetic Tech Makes Magic Change
1
Pin Configuration & Functions
Rev
1.6
MT855X
Omni-polar, High Voltage & Low Power Consumption Hall-Effect Switch IC
Table of Contents
1
Product Description………...…….……………….……...…………………………………….…….………1
2
Features……………………………….……..……………………………………………………………….…….1
3
Product Overview of MT855X ..…………………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Definition of Switching Function……………………………………………………………………….3
7
Function Description……...…………………………………………………………………………………..3
8
Feature Description……………………………………………………………………………………………3
9
Functional Block Diagram…………………………………………………………………………………..4
10
Electrical and Magnetic Characteristics………………………………………………………………4
10.1 Absolute Maximum Ratings……………………………………………………………………………….4
10.2 Electrical Specifications……………………………………………………………………………………..5
10.3 Magnetic Characteristics……………………………………………………………………………………5
10.4 ESD Ratings………………………………………………………………………………………………………..5
10.5 Characteristic Performance………………………………………………………………….…………….6
10.6 Typical Output Waveform…………………………………………………………………………………..7
11
Typical Application Circuit………………………………………………………………………………….7
12
Package Material Information……………………………………………………………………………8
12.1 SOT-23 Package Information……………………………...………………………………………………8
12.2 Flat TO-92 Package Information………………………………………………………………………9
13
Copy Rights and Disclaimer……………………………………………………………………………..10
1
2
Originally Version
1.1 Version
3
4
1.2 Version
1.3 Version
5
6
7
1.4 Version
1.5 Version
1.6 Version
Reversion History
Update Package Type
Update Electrical Specifications
Update Copy Rights and Disclaimer
Update MT8552 & MT8553 Series
Update the marking spec of SOT-23
Update the Magnetic Spec of MT8551
Update the Magnetic Spec of MT8553
Update the Logo of MagnTek
2
Rev
1.6
MT855X
6 Definition of Switching Function
Figure.2 shows the device functionality and hysteresis
Vcc
North
Figure.2
BOP N BRP N
BRP S
BOP S
South
Omni-polar Switching Function
7 Function Description
BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the
output driver ON (VOUT=Low)
BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the
output driver OFF (VOUT=High)
BHYST: Hysteresis Window, |BOP - BRP|
Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher
thresholds (VOUT=Low) generally require a closer distance or larger magnet.
8 Feature Description
The MT855X device is sensitive to the magnetic field component that is perpendicular to the top of the
package
or
or
S
N
S
N
N
S
N
S
Flat TO-92
SOT-23
Figure.3
Motion
or
or
S
N
S
N
N
S
N
S
Flat TO-92
SOT-23
PCB
PCB
VOUT = Low
VOUT= High
Flux Direction Polarity
3
Rev
1.6
MT855X
9 Functional Block Diagram
Vcc
Reference
Dynamic
Offset
Cancelation
Regulator
Limiting
Current
Protection
ESD
Out
Hall Plate
ITA
COMP
Output Driver
ESD
GND
Figure.4
10 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VCC
Supply Voltage
30
V
VRCC
Reverse Battery Voltage
-16
V
VOUT
Output Voltage
30
V
IOUT
Continuous Output Current
55
mA
TA
Operating Ambient Temperature
-40
125
TS
Storage Temperature
-50
150
TJ
Junction Temperature
165
B
Magnetic Flux Density
No Limit
4
Gs
Rev
1.6
MT855X
At TA=-40~125 ℃, Vcc=3.0V~24V (unless otherwise specified)
Symbol
Parameters
Test Condition
Min
Typ
Max
Unit
VCC
Supply Voltage
Operating
3.0
24
V
ICC
Supply Current
∣B∣∣BOP∣,
VOUT=Vcc
50
mA
VDSON
Output Saturation Voltage
IOUT=20mA,
∣B∣>∣BOP∣
0.4
V
IOFF
Output Leakage Current
VOUT=24V,
∣B∣5V/uS
∣B∣>∣BOP∣ (MAX)
15
us
FC
Chopping Frequency
400
KHz
FS
Sampling Frequency
25
KHz
Thermal Resistance of SOT-23
301
℃/W
Thermal Resistance of TO-92
230
℃/W
RTH
At VCC=3.0V~24V (unless otherwise specified)
Part No.
Symbol
Min
Typ
Max
Unit
BOP, TA =25℃
±23
±32
±41
Gs
MT8551 Series BRP, TA =25℃
±18
±27
±36
Gs
5
Gs
BOP, TA =25℃
±55
±80
±105
Gs
MT8552 Series BRP, TA =25℃
±35
±60
±85
Gs
10
Gs
BOP, TA =25℃
±35
±60
±85
Gs
MT8553 Series BRP, TA =25℃
±20
±45
±70
Gs
5
15
25
Gs
BHYST, TA =25℃
BHYST, TA =25℃
BHYST, TA =25℃
10.4 ESD Ratings
Symbol
VESD
Reference
Level
Unit
Human-body model (HBM)
AEC-Q100-002
Class H2
Grade
Charged-device model (CDM)
AEC-Q100-011
Class C3
Grade
5
Rev
1.6
MT855X
MT8551 At VCC=5V
Supply Current (mA)
1.4
1.2
1
0.8
0.6
0.4
0.2
85
125
Temperature ℃
Supply Current vs. Temperature
Bop S
Brp S
5
Bop N
Brp N
-5
-15
-40
85
125
-25
-35
Temperature ℃
MT8551
Magnetic Field Intensity (Gs)
Figure.6
10
8
6
4
2
-4
-6
-8
-10
-40
MT8551
Figure.7
100
80
60
40
-40
-60
-80
-100
80
-40
Bop S
Brp S
Bop N
Brp N
85
125
15
25
60
40
-40
Bop S
Brp S
Bop N
Brp N
85
125
-40
-60
-80
Temperature ℃
Temperature ℃
MT8553
MT8552
Magnetic Characteristics vs. Temperature (BOP & BRP)
Bhyst S
25
85
125
Bhyst N
Temperature ℃
35
25
10
5
-10
-15
-20
-25
Bhyst S
-40
Bhyst N
25
85
Temperature ℃
125
Figure.5
15
10
5
Bhyst S
-40
Bhyst N
25
85
-10
-15
-20
Temperature ℃
MT8553
MT8552
Magnetic Characteristics vs. Temperature (BHYST)
6
Rev
1.6
125
MT855X
MT8551A as example
B
BOP S
BRP S
T
BRP N
BOP N
V
High
Low
Figure.8
T
Digital Output vs. Magnetic Flux Density
11 Typical Application Circuit
MT8551AT as example
Note: Recommended value for RL is 10KOhms
C1=100nF
Vcc
1
RL
按钮
Vcc
OUT
3
GND
GND
2
Out
C2=1nF
Figure.9
7
Rev
1.6
MT855X
12 Package Material Information (For Reference Only – Not for Tooling Use)
3
XXXX
按钮
Product ID
按钮
2
1
OUT
Vcc
Figure.10
DateCode:
Y: Year W: Week
YW
GND
XXXX YW
SOT-23 Chip Marking Spec
Sensing
Center
Figure.11
SOT-23 Package Drawing
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Max
Min
Max
A
1.050
1.300
0.041
0.051
A1
0.000
0.150
0.000
0.006
A2
1.000
1.200
0.039
0.047
b
0.300
0.500
0.012
0.020
c
0.080
0.220
0.003
0.009
D
2.800
3.020
0.110
0.119
E
1.500
1.700
0.059
0.067
E1
2.600
3.000
0.102
0.118
e
0.950 TYP
0.037 TYP
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0︒
8︒
0︒
8︒
x
1.460 TYP
0.057 TYP
y
0.800 TYP
0.032 TYP
z
0.600 TYP
0.024 TYP
8
Rev
1.6
MT855X
12.3 Flat TO-92 Package Information
XXXX
XXXX
YWW
Product ID
YWW
DateCode: week (01~55)
DateCode: year (0~9)
3 OUT
2 GND
1 Vcc
Figure.12
Flat TO-92 Chip Marking Spec
Sensing
Center
Figure.13
Flat TO-92 Package Drawing
Symbol
Min
Max
Min
Max
A
1.420
1.620
0.056
0.064
A1
0.660
0.910
0.026
0.036
b
0.330
0.560
0.013
0.022
b1
0.400
0.510
0.016
0.020
c
0.330
0.510
0.013
0.020
D
3.900
4.200
0.154
0.165
D1
2.280
2.680
0.090
0.106
E
2.900
3.280
0.114
0.128
e
1.270 TYP
0.050 TYP
e1
2.440
2.640
0.096
0.104
L
13.500
16.200
0.531
0.638
θ
45︒ TYP
45︒ TYP
x
2.025 TYP
0.080 TYP
y
1.545 TYP
0.061 TYP
z
0.500 TYP
0.020 TYP
9
Rev
1.6
MT855X
13 Copy Rights and Disclaimer
1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior
written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated.
2. MagnTek reserves the right to make changes to the information published in this document at
anytime without notice.
3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products are
not to be used in any device or system, including but not limited to medical life support equipment and
system.
For the latest version of this document, please visit our website: www.magntek.com.cn
10
Rev
1.6
很抱歉,暂时无法提供与“MT8553A”相匹配的价格&库存,您可以联系我们找货
