FD2H001Ba/FD2H001BY/FD2H001BH
Low-Power Hall Switch
General Description
FD2H001B is a low-power integrated Hall switch designed to sense the applied magnetic flux
density and give a digital output, which indicates the present condition of the magnitude sensed. One
example of the applications is the on/off switch in cellular flip-phones.
The micro power design is especially suitable for battery-operated systems such as cellular phones
or laptop computers, in which power consumption is one major concern. The typical power consumption
of FD2H001B is below 10μW at 2.7V.
The magnetic switching points are precise and insensitive to process and temperature variations.
For FD2H001B, the output will be at the “low” level if the applied magnetic flux density is stronger
than the switching threshold.
For detailed magnetic flux direction please refer to the figure.3
Features
Micro power consumption
2.4V to 5.5V battery operation
Chopper Amplifier based design:
Insensitive to noise and offset caused by process variations, operating temperatures and
mechanical stress
Digital output
Programmable output direction
CMOS process
Available in SOT-23L/ TSOT-23L/SIP-3L package
This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without
notice.No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Rev. 0.61
1/13
Pin Descriptions
SOT-23L/ TSOT-23L
Top View
VSS
3
CFXXX
Name
No.
I/O
Description
VDD
1
P
Positive supply
Q
2
O
Open Drain output
VSS
3
G
Ground
Legend: I=input, O=output, I/O=input/output, P=power supply, G=ground
1
2
VDD
Q
SIP-3L
Top View
FD01
XXX
Name
No.
I/O
Description
VDD
1
P
Positive supply
VSS
2
G
Ground
Q
3
O
Open Drain output
1
2
3
VDD VSS Q
Rev. 0.61
2/13
Marking Information
SOT-23L/ TSOT-23L
CFXXX
Lot Number
Year
Part Number Code
Lot Number: Wafer lot number’s last two digits
For Example: XX686
86
Year: Production year’s last digit
Part Number Code: Part number identification code for this product.
SIP-3L
FD01
XXX
Internal ID
Per - Half Month
Year
Internal ID: Internal Identification Code
Per-Half Month: Production period indicator in half month time unit
For Example : A → First Half Month of January
B → Second Half Month of January
C → First Half Month of February
D → Second Half Month of February
Rev. 0.61
3/13
Block Diagram
Bias Generator
Q
Hall Plate
Chopper
Amplifier
Oscillator
Sequencer
Hysteresis
Control
Power on
reset
Figure.1
Functional Descriptions
Refer to the block diagram (Figure.1), FD2H001B is composed of the following building blocks:
Bias generator
The bias generator provides precise, temperature and process insensitive current sources for both
the Hall plate and the chopper amplifier. These current sources in turn guarantee proper operation of the
chip and precise switching thresholds under all kinds of environments specified in the specification.
Oscillator + Sequencer
The built-in oscillator provides the clock signal, which is taken by the sequencer to determine the
periods of the operating phase and the stand-by phase. Typically the operating time is about 60us and
the stand-by time is 150ms. Using such a clocking scheme, the average power consumption is almost
equal to that in the stand-by phase, which is under 10μW at 2.7V.
Power on Reset
Used to detect the power-up ramp and reset the digital circuits to attain correct operation as soon
as the power is ready.
Chopper Amplifier
To achieve a higher resolution the chopper amplifier structure is adopted in this design. Use of this
structure dynamically removes both the offset and flicker noise at the same time.
Hysteresis Control
This block determines the switching threshold of the Hall switch in different situations.
Rev. 0.61
4/13
Ordering information
Part Number
Operating Temperature
FD2H001BaR-G1
Package
Description
MOQ
o
o
TSOT23
±50G (B)
3,000ea/Reel
o
o
SOT23
±50G (B)
3,000ea/Reel
o
o
SIP-3L
±50G (B)
1,000ea/Bag
-20 C to +105 C
FD2H001BYR-G1
-20 C to +105 C
FD2H001BH-LF
-20 C to +105 C
Absolute Maximum Ratings
Parameter
Values
Conditions
min.
max.
Unit
Ambient Operating Temperature
-40
85
Storage Temperature
-40
150
DC Supply Voltage
2.4
5.5
V
Supply Current
2.5
mA
Magnetic Flux Density
unlimited
Gauss
260
Lead Temperature
10sec
IR Re-flow Soldering Curve
ROOM TEMP.
255 ± 5 o C
10 ± 1 sec
150 ± 10 o C
90 ± 30 sec
2~5 o C /sec
2~5 o C /sec
SECOND
IR-Reflow Soldering Condition
Figure. 2
Rev. 0.61
5/13
Operating Conditions
Conditions
Min.
Typ.
Max.
Unit
Supply Voltage
2.4
2.7
5.5
V
Output Voltage
-0.3
2.7
5.5
V
Ambient Temperature
-40
25
85
Conditions
Min.
Typ.
Max.
Unit
µA
Parameter
Electrical Characteristics
Parameter
Average Supply Current
1
3
1.1
1
mA
2.5
1
µA
Output Saturation Voltage
0.1
V
Output Leakage Current
0.01
µA
Operating time
60
µs
Standby time
150
ms
Duty cycle
0.04
Conditions
Min.
Typ.
Max.
Unit
Operate Points ( |BOP| )
40
50
60
G
Hysteresis
5
10
15
G
(operating phase)
(stand-by phase)
Note1. operating voltage 2.7V
Magnetic Characteristics
Parameter
Rev. 0.61
6/13
Magnetic Flux Direction
Voh
Vol
B
BRP BOP
BOP BRP
Figure. 3
Rev. 0.61
7/13
Typical Characteristics
S w it ch in g Po in t vs . Am bi e nt T em pe ra tu re
(G )
80
Sw i tc hi ng
P oi nt s
60
40
Bo pn
Br pn
- 20
- 40
- 60
- 80
-4 0
- 20
60
80
Am bi en t Te mp er at ur e ( C)
Figure.4 Magnetic Switch Points Versus Ambient Temperature (VDD=2.7V)
Switching Point vs. Supply Voltage
80
Switching Points (G)
60
40
Bopn
Brpn
-40
-60
-80
2.5
3
3.5
4
4.5
5
5.5
Supply Voltage (V)
Figure.5 Magnetic Switch Points Versus Supply Voltage (Ta=25C degree)
Rev. 0.61
8/13
Average current vs. Supply Voltage
Average Current (uA)
16
14
12
10
8
6
4
2
3
3.5
4
4.5
5
5.5
Supply Voltage (V)
Figure.6 Average Current Versus Supply Voltage ( Ta=25C degree)
Average Current vs. Ambient Temperature
Average Current(uA)
10
8
6
4
2
-20
60
80
Ambient Temperature (C)
Figure.7 Average Current Versus Ambient Temperature (VDD=2.7V )
Rev. 0.61
9/13
Application Circuit Reference
1
VIN
1
IC1
FD2H001
2
Q
VSS
1
C1
1uF
VDD
3
GND
R1 10K
1
OUT
Figure.8
NOTE:
1.
R1 is for power supply filtering function, and must be placed as close to IC1 as possible.
Rev. 0.61
10/13
Package Outline
TSOT-23L
Unit: mm
Symbols
Dimension In Millimeters
Min
Nom
Max
A
0.750
0.800
A1
0.025
0.050
A2
0.700
0.750
0.775
b
0.350
0.500
c
0.100
0.200
D
2.800
2.900
3.000
E
2.600
2.800
3.000
E1
1.500
1.600
1.700
e
0.950 BSC
e1
1.900 BSC
L
0.370
0.450
L1
0.600 REF
L2
0.250 BSC
0.600
R
0.100
R1
0..100
0.250
Θ
0˚
4˚
8˚
Θ1
4˚
10˚
12˚
Rev. 0.61
11/13
SOT23
Unit: mm
Symbols
Min. (mm)
Nom. (mm)
Max. (mm)
A
1.45
A1
0.15
A2
0.90
1.15
1.30
b
0.30
0.50
c
0.08
0.22
D
2.90 BSC.
E
2.80 BSC
E1
1.60 BSC
e
0.95 BSC
e1
1.90 BSC
L
0.30
0.45
L1
0.60 REF.
L2
0.25 BSC
0.60
R
0.10
R1
0.10
0.25
θ°
0°
4°
8°
θ1°
5°
10°
15°
Rev. 0.61
12/13
e
D
b
b1
A
A1
SIP-3L
L
E
Unit: mm
Symbols
Min. (mm)
Nom. (mm)
Max. (mm)
A
1.245
1.753
A1
b
0.75REF
0.33
b1
0.56
0.54 REF
D
3.85
4.2
E
2.87
3.124
L
13.5
15.6
e
1.27 REF
Note:
1. Dimension “D” does not include molding flash, protrusions or gate burrs.
2. Dimension “E” does not include interlead flash, protrusions.
Rev. 0.61
13/13
很抱歉,暂时无法提供与“FD2H001BAR-LF”相匹配的价格&库存,您可以联系我们找货
