HP4554
High Input Voltage Charger with OVP protection
GENERAL DESCRIPTION
FEATURES
The HP4554 is a cost-effective, fully integrated high
input voltage single-cell Li-ion battery charger. The
charger uses a CC/CV charge profile required by Li-ion
battery. The charger accepts an input voltage up to
24V but is disabled when the input voltage exceeds
the OVP threshold, typically 6.8V, to prevent
excessive power dissipation. The 24V rating
eliminates the over-voltage protection circuit
required in a low input voltage charger.
The charge current and the Full-of-charge (FOC)
current are programmable with external resistors.
When the battery voltage is lower than 2.55V, the
charger preconditions the battery with typically 20%
of the programmed charge current. When the charge
current reduces to the programmable FOC current
level during the CV charge phase, an FOC indication is
𝐶𝐶𝐶𝐶𝐶𝐶 pin, which is an open-drain
provided by the ������
output. An internal thermal foldback function
protects the charger from any thermal failure. Two
������ and ������
𝐶𝐶𝐶𝐶𝐶𝐶 ) allow simple
indication pins ( 𝑃𝑃𝑃𝑃𝑃𝑃
interface to a microprocessor or LEDs. When no
adapter attached, the charger draws less than 1μA
leakage current from the battery.
The HP4554 is available in Green DFN-2×2-8L
Complete Charger for Single-Cell-Li-ion or
Polymer Batteries
Integrated Pass Element and Current Sensor
No External Blocking Diode Required
Low Component Count and Cost
Programmable Charger Current
Programmable Full-of-Charger Current
Charger Current Thermal Foldback for Thermal
Protection
2.55V Trickle Charge Threshold
6.8V Input Over-Voltage Protection
24V Maximum Voltage for the Power Input
Power Presence and Charge Indications
Less than 1μA Leakage Current from the
Battery When No Input Power Attached
Less than 200uA Supply Current when
Charging is terminated
Available in Green DFN-2x2-8L Packages
APPLICATIONS
packages and is rated between -40 ℃ to +85 ℃
temperature range.
Mobile Phones
Blue-Tooth Devices
PDAs
MP3 Players
Stand-Alone Chargers
Other Handheld Devices
PIN ASSIGNMENT
HP4554(TOP VIEW)
1
8
2
7
3
GND
VIN
PPR
CHG
EN
4
6
5
BAT
IREF
IMIN
GND
DFN-2x2-8L
HP4554 Datasheet, 2019 V1.0
Hypower Microelectronics(Shanghai)Co., Ltd.
Page 1
Sales@hypwr.com
HP4554
ORDER INFORMATION
PART NO
PACAKGE
TEMPERATURE
TAPE & REEL
HP4554D8-42
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4554D8-43
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4554D8-435
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4554D8-44
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
PART NUMBER RULES
MARKING DESCRIPTION:
HP4554□
1 -□
2
Code
Description
1
Package:
DFN-2x2-8L
XXXX
JYWA
D8: DFN-2x2-8L
Charge voltage:
2
42/43/435/44:
Battery
charge
“XXXX”: Part number, here is “4554”.
voltage are 4.2V/4.3V/4.35V/4.4V
“JYWA”: “J” stands for Internal Control Code, “Y” stands
for Internal Control Code, “W” stands for the week of
manufacturing, “A” stands for charge voltage.
TYPICAL APPLICATION CIRCUIT
VIN
BAT
C1
IREF
ON
RIMIN
CHG
VIN
BAT
C1
R1
LED1
R2
LED2
GND
Figure 1.Typical application circuit interfacing to indication LEDs
Component Description for Figure 1
IREF
C2
PPR
EN
TO INPUT
HP4554
HP4554
OFF
IMIN
TO BATTREY
RIREF
OFF
ON
IMIN
TO BATTREY
RIREF
RIMIN
C2
VCC
R1
R2
TO MCU
TO INPUT
CHG
PPR
EN
GND
Figure 2.Typical application circuit with the indication signals
interfacing to an MCU
Component Description for Figure 2
PART
DESCRIPTION
PART
DESCRIPTION
C1, C2
1μF X5R ceramic cap
C1, C2
1μF X5R ceramic cap
R IREF
24KΩ,1% for 500mA charge current
R IREF
R IMIN
270KΩ,1% for 40mA FOC current
R IMIN
R1, R2
1KΩ, 5%
R1, R2
100KΩ, 5%
Page 2
Sales@hypwr.com
HP4554
PIN DESCRIPTION
PIN NO
SYMBOL
1
VIN
2
𝑃𝑃𝑃𝑃𝑃𝑃
3
𝐶𝐶𝐶𝐶𝐶𝐶
4
𝐸𝐸𝐸𝐸
5
Open-drain Power Presence Indication. The open-drain MOSFET turns on when the input voltage is
above the POR threshold but below the OVP threshold, and turns off otherwise. This pin is capable
of sinking 15mA (MIN) current to drive an LED. The maximum voltage rating for this pin is 5.5V. This
𝐸𝐸𝐸𝐸 pin input.
pin is independent on the ����
Open-drain Charge Indication. This pin outputs a logic low when a charge cycle starts and turns to
high impedance when the full-of-charge (FOC) condition is qualified. This pin is able to sink 15mA
(MIN) current to drive an LED. When the charger is disabled, the ������
𝐶𝐶𝐶𝐶𝐶𝐶 pin outputs high impedance.
Enable Input. This is a logic input pin to disable or enable the charger. Drive high to disable the
charger. When this pin is driven to low or left floating, the charger is enabled. This pin has an
internal 200kΩ pull-down resistor.
GND
System Ground.
6
IMIN
7
IREF
8
BAT
FUNCTION
Power Input. A 1μF or larger value X5R ceramic capacitor is recommended to be placed as close as
possible to the input pin for decoupling purpose. Additional capacitance may be required to provide
a stable input voltage.
Full-of-Charge (FOC) Current Programming Pin. Connect a resistor between this pin and the GND pin
to set the FOC current. The FOC current I MIN can be programmed by the following equation:
9700
𝐼𝐼𝑀𝑀𝑀𝑀𝑀𝑀 =
+ 4 (𝑚𝑚𝑚𝑚)
𝑅𝑅𝐼𝐼𝐼𝐼𝐼𝐼𝐼𝐼
where R IMIN is in kΩ. The programmable range covers from 5mA to 120mA. FOC current will be
influenced by battery internal impedance and results in a small drift. When programmed to less
than 5mA, the stability is not guaranteed.
Charge-Current Programming and Monitoring Pin. Connect a resistor between this pin and the GND
pin to set the charge current limit determined by the following equation:
12000
𝐼𝐼𝑅𝑅𝑅𝑅𝑅𝑅 =
(𝑚𝑚𝑚𝑚)
𝑅𝑅𝐼𝐼𝐼𝐼𝐼𝐼𝐼𝐼
where R IREF is in kΩ. The resistor should be placed very close to this pin. The IREF pin voltage also
monitors the actual charge current during the entire charge cycle, including the trickle, constantcurrent, and constant-voltage phases. When disabled, V IREF = 0V.
Charger Output Pin. Connect this pin to the battery. A 1μF or larger X5R ceramic capacitor is
recommended for decoupling and stability purposes. When the ����
𝐸𝐸𝐸𝐸 pin is pulled to logic high, the
BAT output is disabled.
ABSOLUTE MAXIMUM RATINGS (Note)
SYMBOL
V IN
R θJA
ITEMS
VALUE
UNIT
Input Voltage
-0.3~27
V
Voltage of other PINs
-0.3~6
V
118
℃/W
Thermal Resistance
DFN-2x2-8L
TJ
Junction Temperature
150
T STG
Storage Temperature
-65 ~ +150
Package Lead Soldering Temperature (10s)
260
ESD MM
Machine Mode
200
V
ESD HBM
Human Body Mode
8
KV
T SOLDER
Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability.
Page 3
Sales@hypwr.com
HP4554
RECOMMANDED OPERATING RANGE
SYMBOL
ITEMS
VALUE
UNIT
V MAX
Maximum Supply Voltage
≤24
V
V IN
Operating Supply Voltage
4.55 to 6.10
V
I REF
Programmed Charge Current
20 to 700
mA
T OPT
Operating Temperature
-40 to +85
TYPICAL CHARGE PROFILE
Trickle
CC
CV
4.2V
IREF
Charge Voltage
75% IREF
2.55V
20% IREF
Charge Current
IMIN
CHG
indication
CHG
Time
Figure 3. Typical Charge Profile
Page 4
Sales@hypwr.com
HP4554
ELECTRICAL CHARACTERISTICS
V IN =5V, R IMIN =243KΩ, T A =25℃, unless otherwise noted.
SYMBOL
ITEMS
CONDITIONS
MIN
TYP
MAX
UNIT
3.4
3.9
4.2
V
3.1
3.6
3.9
V
100
150
mV
Power-ON Reset
V POR
Rising POR Threshold
V BAT =3.0V, R IREF =120KΩ, use
V POR
Falling POR Threshold
indicate the comparator output.
𝑃𝑃𝑃𝑃𝑃𝑃
to
𝑃𝑃𝑃𝑃𝑃𝑃
to
𝑃𝑃𝑃𝑃𝑃𝑃
to
V IN -V BAT Offset Voltage
V OS
Rising Edge
V BAT =4.5V, R IREF =120KΩ, use
Falling Edge
V OVP
OVP Threshold
V OVPHYS
OVP Threshold Hysteresis
V OS
(1)
10
80
mV
6.5
6.80
7.1
V
170
250
300
mV
Standby Current
I VINSTD
I BATSTD
standby Mode VIN Pin Current
Standby Mode BAT Pin Current
Shutdown Current
𝐸𝐸𝐸𝐸 = L, R IREF =120KΩ
V IN =5V, V BAT =4.5V, ����
135
200
μA
1.7
2
μA
200
μA
I VINDIS
Shutdown Mode VIN Pin Current
V IN =5V, R IREF =120KΩ, Charger disabled
130
I VINASD
V BAT =4.5V, V IN =4.3V
92
μA
I BATASD
Shutdown Mode BAT Pin Current
1.8
μA
I VINUVLO
UVLO Mode Supply Current
V IN =V BAT =3.6V
88
μA
I BATUVLO
UVLO Mode BAT Pin Current
V IN =V BAT =3.6V
1
μA
Sleep Current
I BATSLEEP
BAT Pin Current
Input is floating or 0V
1
μA
Voltage Regulation
V OUT
Output Voltage
R DS(ON)
PMOS On Resistance
4.158
4.2
4.242
R IREF =120KΩ, 4.55V V OS
3. V IN < V OVP
where the V OS is the offset voltage for the input and
output voltage comparator, discussed shortly, and
the V OVP is the over-voltage protection threshold
given in the Electrical Characteristics table. All V POR ,
V OS , and V OVP have hysteresis, as given in the
Electrical Characteristics table. The charger will not
charge the battery if the input voltage is not in the
power good range.
Input and Output Comparator
The charger will not be enabled unless the input
voltage is higher than the battery voltage by an offset
voltage V OS . The purpose of this comparator is to
ensure that the charger is turned off when the input
power is removed from the charger. Without this
comparator, it is possible that the charger will fail to
power down when the input is removed and the
current can leak through the PFET pass element to
continue biasing the POR and the Pre-Regulator
blocks.
PPR Indication
������ pin is an open-drain output to indicate the
The 𝑃𝑃𝑃𝑃𝑃𝑃
Page 11
Sales@hypwr.com
HP4554
Dropout Voltage
IREF Pin
The constant current may not be maintained due to
the R DS (ON) limit at a low input voltage. The worst case
R DS(ON) is at the maximum allowable operating
temperature.
The IREF pin has the two functions as described in the
Pin Description section. When setting the fast charge
current, the charge current is guaranteed to have 10%
accuracy with the charge current set at 100mA. When
monitoring the charge current, the accuracy of the
IREF pin voltage vs. the actual charge current has the
same accuracy as the gain from the IREF pin current
to the actual charge current.
CHG Indication
The ������
𝐶𝐶𝐶𝐶𝐶𝐶 is an open-drain output capable of sinking
at least 15mA current when the charger starts to
charge, and turns off when the FOC current is
������ signal is interfaced either with a
reached. The 𝐶𝐶𝐶𝐶𝐶𝐶
microprocessor GPIO or an LED for indication.
EN Input
𝐸𝐸𝐸𝐸 is an active-low logic input to enable the charger.
𝐸𝐸𝐸𝐸 pin to low or leave it floating to enable
Drive the ����
the charger. This pin has a 200kΩ internal pull-down
resistor so when left floating, the input is equivalent
to logic low. Drive this pin to high to disable the
charger. The threshold for high is given in the
Operation without the Battery
The HP4554 relies on a battery for stability and works
under LDO mode if the battery is not connected. With
a battery, the charger will be stable with an output
ceramic decoupling capacitor in the range of 1µF to
220µF. In LDO mode, its stability depends on load
current, C OUT , etc. The maximum load current is
limited by the dropout voltage 4.2V, the programmed
IREF and the thermal foldback.
Thermal Foldback
The thermal foldback function starts to reduce the
charge current when the internal temperature
reaches a typical value of 115℃.
Page 12
Sales@hypwr.com
HP4554
APPLICATION INFORMATION
Input Capacitor Selection
The input capacitor is required to suppress the power
supply transient response during transitions. Mainly
this capacitor is selected to avoid oscillation during
the start up when the input supply is passing the POR
threshold and the VIN-BAT comparator offset voltage.
When the battery voltage is above the POR threshold,
the V IN - V BAT offset voltage dominates the hysteresis
value. Typically, a 1µF X5R ceramic capacitor should
be sufficient to suppress the power supply noise.
Output Capacitor Selection
The criterion for selecting the output capacitor is to
maintain the stability of the charger as well as to
bypass any transient load current. The minimum
capacitance is a 1µF X5R ceramic capacitor. The actual
capacitance connected to the output is dependent on
the actual application requirement.
Layout Guidance
The HP4554 uses thermally-enhanced DFN packages
that have an exposed thermal pad at the bottom side
of the packages. The layout should connect as much
as possible to copper on the exposed pad. Typically,
the component layer is more effective in dissipating
heat. The thermal impedance can be further reduced
by using other layers of copper connecting to the
exposed pad through a thermal via array. Each
thermal via is recommended to have 0.3mm diameter
and 1mm distance away from other thermal vias.
Input Power Sources
The input power source is typically a well-regulated
wall cube with 1-meter length wire or a USB port. The
HP4554 can withstand up to 24V on the input without
damaging the IC. If the input voltage is higher than
typically 6.8V, the charger stops charging.
Page 13
Sales@hypwr.com
HP4554
PACKAGE OUTLINE
Package
DFN-2x2-8L
Devices per reel
4000pcs
Unit
mm
Package Dimension:
D
N5
e
N8
D1
k
E1
E
L
N4
TOP VIEW
b
N1
BOTTOM VIEW
A
A1
A2
SIDE VIEW
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Typ
Max
Min
Typ
Max
A
0.700
0.750
0.800
0.028
0.0295
0.031
A1
0.000
0.025
0.050
0.000
0.001
0.002
A2
0.203
0.008
D
1.900
2.000
2.100
0.075
0.079
0.083
D1
1.100
1.200
1.300
0.043
0.047
0.051
E
1.900
2.000
2.100
0.075
0.079
0.083
E1
0.500
0.600
0.700
0.020
0.024
0.028
b
0.180
0.24
0.300
0.007
0.0095
0.012
e
0.500
k
0.200
L
0.250
0.020
0.008
0.350
0.450
0.010
0.014
0.018
Page 14
Sales@hypwr.com
HP4554
REVISION HISTORY
Version No.
Date
Description
Preliminary
2018-02-08
- Initial preliminary release
V0.1
2018-07-10
- Update typical performance characteristics
V0.2
2018-08-22
- Update ordering information and PN rules
V0.3
2018-10-08
- Update IMIN function description
V0.4
2018-10-30
V0.5
2019-01-25
- Add 4.4V charge voltage
V0.6
2019-04-12
- Update package information
V0.7
2019-05-13
- Update electrical characteristics
V0.8
2019-06-24
- Add programmed charge current
V 1.0
2019-12-02
- Update marking description
- Update description of IMIN and IREF
- Update electric parameters
Page 15
Sales@hypwr.com
