HP4555
High Input Voltage Charger with OVP Protection and Charge Termination
GENERAL DESCRIPTION
FEATURES
The HP4555 is a cost-effective, fully integrated high
input voltage single-cell Li-ion battery charger. The
charger uses a CC/CV charge profile required by Li-ion
battery. The charger accepts an input voltage up to
24V but is disabled when the input voltage exceeds
the OVP threshold, typically 6.8V, to prevent
excessive power dissipation. The 24V rating
eliminates the over-voltage protection circuit
required in a low input voltage charger.
The charge current and the end-of-charge (EOC)
current are programmable with external resistors.
When the battery voltage is lower than 2.55V, the
charger preconditions the battery with typically 20%
of the programmed charge current. When the charge
current reduces to the programmable EOC current
level during the CV charge phase, the charging
process is terminated, and meanwhile an EOC
̅̅̅̅̅̅ pin, which is an
indication is provided by the 𝐶𝐻𝐺
open-drain output. An internal thermal foldback
function protects the charger from any thermal
̅̅̅̅̅̅ ) allow
̅̅̅̅̅̅ and 𝐶𝐻𝐺
failure. Two indication pins ( 𝑃𝑃𝑅
simple interface to a microprocessor or LEDs. When
no adapter attached, the charger draws less than 1μA
leakage current from the battery.
The HP4555 is available in Green DFN-2×2-8L
Complete Charger for Single-Cell-Li-ion or
Polymer Batteries
Integrated Pass Element and Current Sensor
No External Blocking Diode Required
Low Component Count and Cost
Programmable Charger Current
Programmable End-of-Charger Current
Charge termination when charge current
reduces to EOC Current
Charger Current Thermal Foldback for Thermal
Protection
2.55V Trickle Charge Threshold
6.8V Input Over-Voltage Protection
24V Maximum Voltage for the Power Input
Power Presence and Charge Indications
Less than 1μA Leakage Current from the
Battery When No Input Power Attached
Less than 200uA Supply Current when
Charging is terminated
Available in Green DFN-2x2-8L Packages
APPLICATIONS
packages and is rated between -40 ℃ to +85 ℃
temperature range.
Mobile Phones
Blue-Tooth Devices
PDAs
MP3 Players
Stand-Alone Chargers
Other Handheld Devices
PIN ASSIGNMENT
HP4555(TOP VIEW)
1
8
2
7
3
GND
VIN
PPR
CHG
EN
4
6
5
BAT
IREF
IMIN
GND
DFN-2x2-8L
HP4555 Datasheet, 2019 V1.0
Hypower Microelectronics(Shanghai)Co., Ltd.
Page 1
Sales@hypwr.com
HP4555
ORDER INFORMATION
PART NO
PACAKGE
TEMPERATURE
TAPE & REEL
HP4555D8-42
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4555D8-43
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4555D8-435
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
HP4555D8-44
DFN-2x2-8L
-40 ~ +85℃
4000/REEL
PART NUMBER RULES
MARKING DESCRIPTION:
HP4555□
1 -□
2
Code
Description
1
Package:
DFN-2x2-8L
XXXX
XYWV
D8: DFN-2x2-8L
2
Charge voltage:
42/43/435/44:
charge
Battery
voltage
“XXXX”: Part number, here is “4555”.
are
“XYWV”: “X” stands for Internal Control Code, “Y”
4.2V/4.3V/4.35V/4.4V
stands for Internal Control Code, “W” stands for the
week of manufacturing, “V” stands for charge voltage.
TYPICAL APPLICATION CIRCUIT
VIN
BAT
C1
IREF
ON
RIMIN
CHG
VIN
BAT
C1
R1
LED1
R2
LED2
OFF
ON
GND
Figure 1.Typical application circuit interfacing to indication LEDs
Component Description for Figure 1
IREF
C2
PPR
EN
TO INPUT
HP4555
HP4555
OFF
IMIN
TO BATTREY
RIREF
IMIN
TO BATTREY
RIREF
C2
VCC
RIMIN
R1
R2
TO MCU
TO INPUT
CHG
PPR
EN
GND
Figure 2.Typical application circuit with the indication signals
interfacing to an MCU
Component Description for Figure 2
PART
DESCRIPTION
PART
DESCRIPTION
C1, C2
1μF X5R ceramic cap
C1, C2
1μF X5R ceramic cap
RIREF
24KΩ,1% for 500mA charge current
RIREF
RIMIN
270KΩ,1% for 40mA EOC current
RIMIN
R1, R2
1KΩ, 5%
R1, R2
100KΩ,5%
Page 2
Sales@hypwr.com
HP4555
PIN DESCRIPTION
PIN NO
SYMBOL
1
VIN
2
𝑃𝑃𝑅
3
𝐶𝐻𝐺
4
𝐸𝑁
5
GND
6
IMIN
7
IREF
8
BAT
FUNCTION
Power Input. A 1μF or larger value X5R ceramic capacitor is recommended to be placed as close as
possible to the input pin for decoupling purpose. Additional capacitance may be required to provide
a stable input voltage.
Open-drain Power Presence Indication. The open-drain MOSFET turns on when the input voltage is
above the POR threshold but below the OVP threshold, and turns off otherwise. This pin is capable
of sinking 15mA (MIN) current to drive an LED. The maximum voltage rating for this pin is 5.5V. This
̅̅̅̅ pin input.
pin is independent on the 𝐸𝑁
Open-drain Charge Indication. This pin outputs a logic low when a charge cycle starts and turns to
high impedance when the end-of-charge (EOC) condition is qualified. This pin is able to sink 15mA
(MIN) current to drive an LED. When the charger is disabled, the ̅̅̅̅̅̅
𝐶𝐻𝐺 pin outputs high impedance.
Enable Input. This is a logic input pin to disable or enable the charger. Drive high to disable the
charger. When this pin is driven to low or left floating, the charger is enabled. This pin has an
internal 200kΩ pull-down resistor.
System Ground.
End-of-Charge (EOC) Current Programming Pin. Connect a resistor between this pin and the GND
pin to set the EOC current. The EOC current IMIN can be programmed by the following equation:
9700
𝐼𝑀𝐼𝑁 =
+ 4 (𝑚𝐴)
𝑅𝐼𝑀𝐼𝑁
where RIMIN is in kΩ. The programmable range covers from 5mA to 120mA. EOC current will be
influenced by battery internal impedance and results in a small drift. When programmed to less
than 5mA, the accuracy is not guaranteed.
Charge-Current Programming and Monitoring Pin. Connect a resistor between this pin and the GND
pin to set the charge current limit determined by the following equation:
12000
𝐼𝑅𝐸𝐹 =
(𝑚𝐴)
𝑅𝐼𝑅𝐸𝐹
where RIREF is in kΩ. The resistor should be placed very close to this pin. The IREF pin voltage also
monitors the actual charge current during the entire charge cycle, including the trickle, constantcurrent, and constant-voltage phases. When disabled, VIREF = 0V.
Charger Output Pin. Connect this pin to the battery. A 1μF or larger X5R ceramic capacitor is
̅̅̅̅ pin is pulled to logic high, the
recommended for decoupling and stability purposes. When the 𝐸𝑁
BAT output is disabled.
ABSOLUTE MAXIMUM RATINGS (Note)
SYMBOL
VIN
RθJA
ITEMS
VALUE
UNIT
Input Voltage
-0.3~27
V
Voltage of other PINs
-0.3~6
V
118
℃/W
Thermal Resistance
DFN-2x2-8L
TJ
Junction Temperature
150
TSTG
Storage Temperature
-65 ~ +150
Package Lead Soldering Temperature (10s)
260
ESD MM
Machine Mode
200
V
ESD HBM
Human Body Mode
8
KV
TSOLDER
Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability.
Page 3
Sales@hypwr.com
HP4555
RECOMMANDED OPERATING RANGE
SYMBOL
ITEMS
VALUE
UNIT
VMAX
Maximum Supply Voltage
≤24
V
VIN
Operating Supply Voltage
4.55 to 6.10
V
IREF
Programmed Charge Current
20 to 700
mA
TOPT
Operating Temperature
-40 to +85
TYPICAL CHARGE PROFILE
Trickle
CC
CV
EOC Recharge
CV
4.2V
IREF
4.05V
75% IREF
Charge Voltage
2.55V
20% IREF
Charge Current
IMIN
CHG
indication
CHG
Time
Figure 3. Typical Charge Profile
Page 4
Sales@hypwr.com
HP4555
ELECTRICAL CHARACTERISTICS
VIN=5V, RIMIN=243KΩ, TA=25℃, unless otherwise noted.
SYMBOL
ITEMS
CONDITIONS
MIN
TYP
MAX
UNIT
Power-ON Reset
VPOR
Rising POR Threshold
̅̅̅̅̅̅ to
VBAT=3.0V, RIREF=120KΩ, use 𝑃𝑃𝑅
3.4
3.9
4.2
V
VPOR
Falling POR Threshold
indicate the comparator output.
3.1
3.6
3.9
V
100
150
mV
VIN-VBAT Offset Voltage
VOS
Rising Edge
VOS
Falling Edge
̅̅̅̅̅̅ to
VBAT=4.5V, RIREF=120KΩ, use 𝑃𝑃𝑅
output.(1)
10
80
mV
̅̅̅̅̅̅ to
6.5
6.80
7.1
V
170
250
300
mV
VOVP
OVP Threshold
VOVPHYS
OVP Threshold Hysteresis
Standby Current
IVINSTD
IBATSTD
standby Mode VIN Pin Current
̅̅̅̅ = L, RIREF=120KΩ
VIN=5V, VBAT=4.5V, 𝐸𝑁
135
200
μA
Standby Mode BAT Pin Current
1.7
2
μA
200
μA
Shutdown Current
IVINDIS
Shutdown Mode VIN Pin Current
VIN=5V, RIREF=120KΩ, Charger disabled
130
IVINASD
VBAT=4.5V, VIN=4.3V
92
μA
IBATASD
Shutdown Mode BAT Pin Current
VBAT=4.5V, VIN=4.3V
1.8
μA
IVINUVLO
UVLO Mode Supply Current
VIN=VBAT=3.6V
88
μA
IBATUVLO
UVLO Mode BAT Pin Current
VIN=VBAT=3.6V
1
μA
Sleep Current
IBATSLEEP
BAT Pin Current
Input is floating or 0V
1
μA
Voltage Regulation
VOUT
Output Voltage
RDS(ON)
ΔVRECHRG
Charge Current
PMOS On Resistance
Auto Recharge Battery Voltage
RIMIN=2MΩ, charge current=20mA
4.158
4.2
4.242
4.257
4.3
4.343
4.306
4.35
4.394
4.356
4.4
4.444
VBAT=3.8V, charge current=500mA,
1.2
RIREF=10KΩ
VOUT – VBAT
100
150
V
Ω
200
mV
(2)
VIREF
IREF Pin Output Voltage
VBAT=3.8V, RIREF=120KΩ
1.218
V
IREF
Constant Charge Current
RIREF=120KΩ, VBAT=2.8V to 3.8V
90
100
110
mA
ITRK
Trickle Charge Current
RIREF=120KΩ, VBAT=2.4V
13
22
31
mA
IMIN
End-of-Charge Current
RIMIN=243KΩ
22
44
66
mA
RIMIN=2MΩ
4
9
14
mA
2.45
2.55
2.65
V
Preconditioning Charge Threshold
VMIN
Voltage
RIREF=24.3KΩ
Page 5
Sales@hypwr.com
HP4555
VMINHYS
Preconditioning Voltage Hysteresis
RIREF=24.3KΩ
70
100
130
mV
Internal Temperature Monitoring
TFOLD
Charge Current Foldback Threshold
115
Logic input and outputs
VEN_H
̅̅̅̅ Pin Logic Input High
𝐸𝑁
VEN_L
̅̅̅̅ Pin Logic Input Low
𝐸𝑁
REN
ICHG_sink
ICHG_leakage
IPPR_sink
IPPR_leakage
1.5
̅̅̅̅ Pin Internal Pull Down
𝐸𝑁
Resistance
𝐶𝐻𝐺 Sink Current when LOW
𝐶𝐻𝐺 Leakage Current when High
Impedance
̅̅̅̅̅̅ Sink Current when LOW
𝑃𝑃𝑅
̅̅̅̅̅̅ Leakage Current when High
𝑃𝑃𝑅
Impedance
Pin Voltage = 1V
V
150
200
10
18
VCHG = 5.5V
Pin Voltage = 1V
0.8
V
250
KΩ
mA
18
VPPR = 5.5V
μA
mA
μA
Note:
̅̅̅̅̅̅ output can be used as the indication for the offset comparator output indication. If the V BAT is
1. The 4.5V VBAT is selected so that the 𝑃𝑃𝑅
lower than the POR threshold, no output pin can be used for indication.
2. The charge current can be affected by the thermal foldback function if the IC under the test setup cannot dissipate the heat.
Page 6
Sales@hypwr.com
HP4555
TYPICAL PERFORMANCE CHARACTERISTICS
VIREF vs IBAT
VOUT vs VIN
1.4
4.3
1.2
1
VIREF(V)
VOUT(V)
4.25
4.2
0.8
0.6
0.4
4.15
0.2
4.1
5
5.5
6
6.5
200
VIN(V)
IBAT vs VIN
600
VBAT(V)
IBAT(mA)
4.2
BAT=3.8V
300
200
3.2
5.5
VIN=5V
3.6
3.4
RIREF=120K
5
RIREF=24K
3.8
100
4.5
6
100
VIREF vs VIN
120
RIREF=120K
400
RIREF=24.3K
100
1
RIREF=24.3K
ITRK(mA)
VIREF(V)
300
ITRK vs VIN
1.4
0.8
200
IBAT (mA)
VIN(V)
1.2
500
4.4
4
400
400
VBAT vs IBAT
RIREF=24.3K
500
300
IBAT(mA)
0.6
0.4
80
60
40
RIREF=120K
5
5.5
VIN(V)
6
6.5
4
4.5
5
5.5
6
VIN(V)
Page 7
Sales@hypwr.com
6.5
HP4555
IPPR vs VPPR
35
35
30
30
25
25
IPPR(mA)
ICHG(mA)
ICHG vs VCHG
10
10
5
5
2
3
4
5
6
2
3
VCHG(V)
VBAT vs Ta
4.2
OVP(V)
VBAT(V)
4
3.8
3.6
3.4
3.2
3
45
65
85
105
6.9
6.8
6.7
6.6
6.5
6.4
6.3
6.2
6.1
6
OVP recovery
25
125
45
65
VIREF(V)
2.8
Vpre-th(V)
105
125
VIREF vs Ta
3
2.6
2.4
2.2
2
65
85
Ta(℃)
Pre-charge Threshold vs Ta
45
6
OVP
Ta(℃)
25
5
OVP vs Ta
4.4
25
4
VPPR(V)
85
Ta(℃)
105
125
1.4
1.2
1
0.8
0.6
0.4
0.2
VIN=5V
VBAT=2.5V
RIREF=120K
25
35
45
55
65
75
Ta(℃)
Page 8
Sales@hypwr.com
85
HP4555
IBAT vs Ta
VIMIN vs Ta
0.935
120
0.93
100
IBAT(mA)
VIMIN(V)
0.925
0.92
0.915
VIN=5V
RIMIN=243K
0.91
80
60
VIN=5V
VBAT=2.5V
RIREF=120K
40
0.9
35
45
55
65
75
85
25
35
45
55
Ta(℃)
15
IIN(uA)
ITRK(mA)
VIN=5V
VBAT=2V
RIREF=120K
35
45
55
65
75
200
180
160
140
120
100
80
60
40
VIN=5V
VBAT=4.3V
RIREF=120K
25
45
charge
enabled
65
Ta(℃)
85
105
125
85
105
125
Ta(℃)
ICHG vs Ta
IIN vs Ta
25
180
160
140
120
100
80
60
40
ICHG(mA)
IIN(uA)
85
IIN vs Ta
25
5
75
Ta(℃)
ITRK vs Ta
10
65
charge
disabled
VIN=5V
VBAT=4.3V
RIREF=120K
15
10
VIN=5V
VCHG=1V
RIREF=120K
5
45
65
85
Ta(℃)
105
125
25
45
65
Ta(℃)
Page 9
Sales@hypwr.com
HP4555
IBAT vs RIREF
Charge Curve
700
600
VIN=5V
VBAT=3.8V
VBAT=2V
IBAT(mA)
500
400
500
Ich
IBAT(mA)
600
Ipre-ch
300
200
400
300
200
100
100
100
150
200
250
2
300
2.5
3
4
4.5
VBAT(V)
RIREF(Kohm)
EOC vs RIMIN
EOC vs RIMIN
12
160
140
10
RIREF=22K
EOC (mA)
120
EOC (mA)
3.5
100
80
60
RIREF=120K
8
6
4
40
2
400
600
RIMIN (KΩ)
800
1000
1200
4000
6000
8000
10000 12000
RIMIN (KΩ)
Page 10
Sales@hypwr.com
HP4555
OVP Test
CH1:VIN
VIN=0V to 10V
CH3:VBAT
VIN=0V to 15V
VIN=0V to 20V
VIN=5V to 10V
VIN=5V to 15V
VIN=5V to 20V
Page 11
Sales@hypwr.com
HP4555
OPERATION
The HP4555 charges a Li-ion battery using a CC/CV
profile. The constant current IREF is set with the
external resistor RIREF (see Figure 1) and the constant
voltage is fixed at 4.2V (or 4.3V, or 4.35V, or 4.4V). If
the battery voltage is below a typical 2.55V trickle
charge threshold, the HP4555 charges the battery
with a trickle current of 20% of IREF until the battery
voltage rises above the trickle charge threshold. Fast
charge CC mode is maintained at the rate determined
by programming IREF until the cell voltage rises to 4.2V
(or 4.3V, or 4.35V, or 4.4V). When the battery voltage
reaches 4.2V (or 4.3V, or 4.35V, or 4.4V), the charger
enters a CV mode and regulates the battery voltage at
4.2V (or 4.3V, or 4.35V, or 4.4V) to fully charge the
battery without the risk of over charge. Upon
reaching an end-of-charge (EOC) current, the charger
̅̅̅̅̅̅ pin
indicates the charge completion with the 𝐶𝐻𝐺
and terminate the charge current. Figure 3 shows the
typical charge waveforms after the power is on.
The EOC current level IMIN is programmable with the
external resistor RIMIN (see Figure 1). The ̅̅̅̅̅̅
𝐶𝐻𝐺 pin
turns to low when the trickle charge starts and rises
̅̅̅̅̅̅ pin to turn
to high impedance at the EOC. The 𝐶𝐻𝐺
on again when the battery voltage lower than 150mV
(typically) of output voltage after the EOC is reached,
and then the recharge process is beginning.
voltage is higher than the POR threshold, the ̅̅̅̅̅̅
𝑃𝑃𝑅
pin turns on the internal open-drain MOSFET to
indicate a logic low signal, independent on the ̅̅̅̅
𝐸𝑁
pin input. When the internal open-drain FET is turned
off, the ̅̅̅̅̅̅
𝑃𝑃𝑅 pin leaks less than 20µA current. When
̅̅̅̅̅̅ pin is able to sink at least 10mA
turned on, the 𝑃𝑃𝑅
̅̅̅̅̅̅ pin
current under all operating conditions. The 𝑃𝑃𝑅
can be used to drive an LED (see Figure 1) or to
interface with a micro- processor.
Power Good Range
The power good range is defined by the following
three conditions:
1. VIN > VPOR
2. VIN - VBAT > VOS
3. VIN < VOVP
where the VOS is the offset voltage for the input and
output voltage comparator, discussed shortly, and
the VOVP is the over-voltage protection threshold
given in the Electrical Characteristics table. All VPOR,
VOS, and VOVP have hysteresis, as given in the Electrical
Characteristics table. The charger will not charge the
battery if the input voltage is not in the power good
range.
Input and Output Comparator
A thermal foldback function reduces the charge
current anytime when the die temperature reaches
typically 115 ℃ . This function guarantees safe
operation when the printed circuit board (PCB) is not
capable of dissipating the heat generated by the
linear charger. The HP4555 accepts an input voltage
up to 24V but disables charging when the input
voltage exceeds the OVP threshold, typically 6.8V for
HP4555, to protect against unqualified or faulty AC
adapters.
The charger will not be enabled unless the input
voltage is higher than the battery voltage by an offset
voltage VOS. The purpose of this comparator is to
ensure that the charger is turned off when the input
power is removed from the charger. Without this
comparator, it is possible that the charger will fail to
power down when the input is removed and the
current can leak through the PFET pass element to
continue biasing the POR and the Pre-Regulator
blocks.
PPR Indication
The ̅̅̅̅̅̅
𝑃𝑃𝑅 pin is an open-drain output to indicate the
presence of the AC adapter. Whenever the input
Page 12
Sales@hypwr.com
HP4555
Dropout Voltage
The constant current may not be maintained due to
the RDS (ON) limit at a low input voltage. The worst case
RDS(ON) is at the maximum allowable operating
temperature.
current, the charge current is guaranteed to have 10%
accuracy with the charge current set at 100mA. When
monitoring the charge current, the accuracy of the
IREF pin voltage vs. the actual charge current has the
same accuracy as the gain from the IREF pin current
to the actual charge current.
CHG Indication
The ̅̅̅̅̅̅
𝐶𝐻𝐺 is an open-drain output capable of sinking
at least 10mA current when the charger starts to
charge, and turns off when the EOC current is
̅̅̅̅̅̅ signal is interfaced either with a
reached. The 𝐶𝐻𝐺
microprocessor GPIO or an LED for indication.
EN Input
̅̅̅̅ is an active-low logic input to enable the charger.
𝐸𝑁
Drive the ̅̅̅̅
𝐸𝑁 pin to low or leave it floating to enable
the charger. This pin has a 200kΩ internal pull-down
resistor so when left floating, the input is equivalent
to logic low. Drive this pin to high to disable the
charger. The threshold for high is given in the
Operation without the Battery
The HP4555 relies on a battery for stability and works
under LDO mode if the battery is not connected. With
a battery, the charger will be stable with an output
ceramic decoupling capacitor in the range of 1µF to
220µF. In LDO mode, its stability depends on load
current, COUT, etc. The maximum load current is
limited by the dropout voltage 4.2V, the programmed
IREF and the thermal foldback. If no load, the output
voltage is rippled between recharge voltage and
terminated voltage, and the ̅̅̅̅̅̅
𝐶𝐻𝐺 pin is pulled low or
in high impedance periodically. The frequency of this
period influenced by output capacitance. So, the output
voltage is stable only with a load current more than
termination current that is set by IMIN pin.
Thermal Foldback
IREF Pin
The IREF pin has the two functions as described in the
Pin Description section. When setting the fast charge
The thermal foldback function starts to reduce the
charge current when the internal temperature
reaches a typical value of 115℃.
Page 13
Sales@hypwr.com
HP4555
APPLICATION INFORMATION
Input Capacitor Selection
The input capacitor is required to suppress the power
supply transient response during transitions. Mainly
this capacitor is selected to avoid oscillation during
the start up when the input supply is passing the POR
threshold and the VIN-BAT comparator offset voltage.
When the battery voltage is above the POR threshold,
the VIN - VBAT offset voltage dominates the hysteresis
value. Typically, a 1µF X5R ceramic capacitor should
be sufficient to suppress the power supply noise.
Output Capacitor Selection
The criterion for selecting the output capacitor is to
maintain the stability of the charger as well as to
bypass any transient load current. The minimum
capacitance is a 1µF X5R ceramic capacitor. The actual
capacitance connected to the output is dependent on
the actual application requirement.
Layout Guidance
The HP4555 uses thermally-enhanced DFN packages
that have an exposed thermal pad at the bottom side
of the packages. The layout should connect as much
as possible to copper on the exposed pad. Typically,
the component layer is more effective in dissipating
heat. The thermal impedance can be further reduced
by using other layers of copper connecting to the
exposed pad through a thermal via array. Each
thermal via is recommended to have 0.3mm diameter
and 1mm distance away from other thermal vias.
Input Power Sources
The input power source is typically a well-regulated
wall cube with 1-meter length wire or a USB port. The
HP4555 can withstand up to 24V on the input without
damaging the IC. If the input voltage is higher than
typically 6.8V, the charger stops charging.
Page 14
Sales@hypwr.com
HP4555
PACKAGE OUTLINE
Package
DFN-2x2-8L
Devices per reel
4000pcs
Unit
mm
Package Dimension:
D
N5
e
N8
D1
k
E1
E
L
N4
TOP VIEW
b
N1
BOTTOM VIEW
A
A1
A2
SIDE VIEW
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Max
Min
Max
A
0.700
0.800
0.028
0.031
A1
0.000
0.050
0.000
0.002
A2
0.203 REF
0.008 REF
D
1.900
2.100
0.075
0.083
D1
1.100
1.300
0.043
0.051
E
1.900
2.100
0.075
0.083
E1
0.500
0.700
0.020
0.028
b
0.180
0.300
0.007
0.012
e
0.500 TYP
0.020 TYP
k
0.200 MIN
0.008 MIN
L
0.250
0.450
0.010
0.018
Page 15
Sales@hypwr.com
HP4555
REVISION HISTORY
Version No.
Date
Description
Preliminary
2018-09-08
- Initial preliminary release
V0.1
2018-09-30
- Update typical performance characteristics
V0.2
2018-10-15
- Update Order Information
V0.3
2018-10-30
V0.4
2019-01-25
- Add 4.4V charge voltage
V0.5
2019-06-24
- Add programmed charge current
V 1.0
2019-12-02
- Update marking description
- Update description of IMIN and IREF
- Update electric parameters
Page 16
Sales@hypwr.com
