AX3071
Wide Input Range CC/CV Step Down
Controller
GENERAL DESCRIPTION
The AX3071 is a step down PWM controller with a driving dual output current to 4.8A
(2.4A+2.4A). It is designed to allow for operating a wide supply voltage range from 9V to 40V.
The external shutdown function can be controlled by logic level to pull COMP/EN pin down,
and then comes into standby mode. The external compensation makes feedback control
have good line and load regulation with flexible external design.
The AX3071 operates in the CC(Constant output Current) mode or CV(Constant output
Voltage) mode, and the OCP current value is set by current sensing resisters.
The AX3071 is suitable for the DC/DC switching power applications when requested
the current limit function. The devices are available in MSOP-10L packages and require very
few external devices for operation.
FEATURES
VIN Operate with 9V ~ 40V Supply Voltage
VOUT Accuracy (VREF =1.0V) ±2.0%
Dual-Channeling CC/CV Mode Control
External Current Limit Setting for 2 channel
Over Temperature Protection
Internal Soft Start ~ 3ms
Fixed Frequency 120KHz
UVLO Protection (min=7V, typ=7.5V, max=8V)
Duty Cycle Range (0~90%)
Single Pin to External Compensation and Shutdown Control
COUT MLCC support.
Built in Adjustable Line-Compensation
MSOP-10L Package
APPLICATION
Car Charger
High-Brightness Lighting
Portable Charger Devices
General-Purpose DC/DC Controller with Current Limit
1/15
Axelite Confidential Materials, do not copy or distribute without written consent.
Rev1.5 Nov.24, 2016
AX3071
BLOCK DIAGRAM
Over Temperature
Protection
POR
VIN
Internal
Regulator
5V
5V
FB
0.36V
Fault
Logics
UVP
BS
0.4V
UG
VREF
ERROR
AMPLIFIER
COMP
Cable
COMP
SEN1
0.1V
SEN2
0.1V
Current
Sensor1
Gate
Control
LX
ramp
Current
Sensor2
LG
Oscillator
120KHz
Zero
Current
Detection
GND
PIN ASSIGNMENT
The package of AX3071 is MSOP-10L the pin assignment is given by:
(Top View)
VIN 1
10 BS
COMP 2
9 LX
FB
3
AX3071
8
UG
SEN2 4
7
LG
SEN1 5
6
GND
MSOP-10L
2/15
Rev1.5 Nov.24, 2016
AX3071
Name
VIN
COMP
FB
SEN2
SEN1
GND
LG
UG
LX
BS
Description
Power Supply Input. Bypass this pin with a 1uF ceramic capacitor to GND,
placed as close to the IC as possible.
Error Amplifier Output. This is the output of the error amplifier (EA) and the
non-inverting input of the PWM comparator. Use this pin in combination with the
FB pin to compensate the voltage control feedback loop of the converter. Pulling
COMP to a level below 0.4V nominal disables the controller, causes the
oscillator to stop, and makes the UGATE and LGATE outputs held low.
Feedback Pin. The voltage at this pin is regulated to 1.0V. Connect to the
resistor divider between output and GND to set the output voltage.
The Current Sense Input2 (+) Pin. When the SEN2 is larger than the current
sense voltage, OCP function will enable.
The Current Sense Input1 (+) Pin. When the SEN1 is larger than the current
Ground. Connect this pin to a large PCB copper area for best heat dissipation,
Return FB, and COMP to this GND and connect this GND to power GND at a
single point for best noise immunity.
Output to Low-side Gate Driver.
Output to High-side Gate Driver.
Power Switching Output to External Inductor.
Bootstrap Pin. This provides power to the internal higher MOSFET gate driver.
Connect a 100nF capacitor from BS pin to LX pin.
ORDER/MARKING INFORMATION
Order Information
Top Marking
Logo
AX 3 0 7
1
Y Y W WX
Part number
ID code: internal
WW: 01~52
Year: 11=2011
12=2012
19=2019
3/15
Rev1.5 Nov.24, 2016
AX3071
ABSOLUTE MAXIMUM RATINGS (at TA = 25°C)
Characteristics
Supply Input Voltage
BS to LX
LX to GND
BS, UG to GND
FB, COMP, LG,SEN1, SEN2 to GND
ESD HBM (Human Body Mode)
ESD MM (Machine Mode)
Power Dissipation, PD @TA=25°C
Thermal Resistance from Junction to case
Thermal Resistance from Junction to ambient
Symbol
VIN
PD
θJC
θJA
Rating
-0.3 to +43
-0.3 to +7
-1 to +VIN+1
VSW-0.3 to VSW+7
0.3 to +7
±2K
±200
( TJ-TA ) / θJA
43
135
Unit
V
V
V
V
V
V
V
W
°C/W
°C/W
RECOMMENDED OPERATION CONDITIONS
Characteristics
Storage Temperature Range
Junction Temperature
Operating Temperature
Lead Temperature Range(Soldering 10sec)
Symbol
TST
TJ
TOP
Rating
-65 to +150
-40 to +125
-40 to +85
260
Unit
°C
°C
°C
°C
4/15
Rev1.5 Nov.24, 2016
AX3071
ELECTRICAL CHARACTERISTICS
VCC=12V, TA=25°C (unless otherwise specified.) Mosfet use AMS4004*2.
Characteristics
Symbol
Test Conditions
Min Typ Max Units
Supply Voltage Range VIN
VCC
9 - 40 V
ICCQ COMP/EN=GND
- 2 - mA
Supply Input Current
ICC 12Vin Vout=5V,No load
- 7.5 - mA
ICC 30Vin Vout=5V,No load
- 15 20 mA
Power-On-Reset
VCCRTH VCC Rising.
7 7.5 8
VCC POR Threshold
V
VCCFTH VCC Falling.
6 6.5 7
Oscillator
Normal PWM Frequency
FOSC IOUT=200mA
96 120 144 KHz
Minimum On-Time
TON-MIN
- 200 - ns
Duty Cycle Range
Duty
0 - 90 %
Reference
VREF
- 1.0 V
Reference Voltage
-2 - +2 %
Reference Voltage Tolerance
Line compensation Current
IFB VSEN1 or VSEN2 =100mV
- 5 - uA
PWM Error Amplifier
- 0.4 V
COMP Shutdown Threshold Voltage
VCOMP=VCOMP_H -1V
- 132 - uA
COMP Source Current
VCOMP=1V
- 126 - uA
COMP Sink Current
Current Sense Amplifier
Difference Voltage between
△VSEN
95 100 105 mV
SEN- and SEN+
Pre-Driver (Ensured by design)
source
- 7 Ω
UG Driver
sink
- 1.5 Ω
source
- 10 Ω
LG Driver
sink
- 1.2 Ω
UG low to LG high
- 40 - nS
Dead Time
LG low to UG high
- 100 - nS
5/15
Rev1.5 Nov.24, 2016
AX3071
Characteristics
Symbol
Test Conditions
Min Typ Max Units
Protection
- 160 - °C
Over Temperature Shutdown
- 40 - °C
Over Temperature Hysteresis
Soft Start
TSS
- 3 - ms
Soft Start Time
- 0.5 s
Recycle Time
Output Short Circuit Protect Section
VSCP
- 0.4 V
Short Circuit Fold Back Voltage
Note 1: Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device.
These are for stress ratings. Functional operation of the device at these or any other conditions beyond
those indicated in the operational sections of the specifications is not implied. Exposure to absolute
maximum rating conditions for extended periods may remain possibility to affect device reliability.
Note 2: Devices are ESD sensitive. Handling precaution recommended.
Note 3: θJA is measured in the natural convection at TA = 25°C on a high effective thermal conductivity test board
of JEDEC 51-7 thermal measurement standard.
APPLICATION CIRCUIT
VIN =10V~40V
INPUT
R7
C4
IN
10R
C1
100uF
C8
UG
C9
4.7uF~10uF
R4
Q1
AMS4004
0R~10R
4.7uF~10uF
LX
AX3071
COMP
LG
R8 10R
R5
0R~10R
OUTPUT
L1
33uH
Q2
AMS4004
R6
R2
4.7R
C7
12K
C5
C6
1nF
470uF
2.2nF
R1
C2
0.1uF
BS
4.7K
FB
C3
SEN1
R3
3K
15pF
2.2nF
GND
SEN1
SEN2
RS1
SEN2
36mR for 2.4A
RS2
36mR for 2.4A
Note: If output only 1 port, the other Sense pin need connect with GND.
6/15
Rev1.5 Nov.24, 2016
AX3071
QC2.0 APPLICATION CIRCUIT
MLCC OUTPUT CAPACITOR APPLICATION
VIN =10V~40V
INPUT
R7
C4
IN
C1
100uF
C8
UG
C10
4.7uF~10uF
R4
Q1
AMS4004
0R~10R
4.7uF~
10uF
LX
AX3071
COMP
LG
R8 10R
R5
0R~10R
OUTPUT
L1
33uH
Q2
AMS4004
R6
4.7R
C7
R2
12K
2.2nF
R1
C2
0.1uF
BS
10R
FB
1K
R3
C5
C6
C9
1nF
100uF
MLCC
100uF
MLCC
RS1
RS2
3K
1nF
SEN1
C3
10nF
GND
SEN1
SEN2
SEN2
7/15
Rev1.5 Nov.24, 2016
AX3071
MOSFET SUGGESTION
AMS4004*2 for 4.8A
AMBA4810 for 4.8A~6A
AMS4006*2 for 6A~8A
2.4A+2.4A or 4.8A
2.4A+2.4A or 2A+2A+2A or 6A
2A+2A+2A or 2A+2A+2A+2A or 8A
8/15
Rev1.5 Nov.24, 2016
AX3071
FUNCTION DESCRIPTIONS
CC/CV Mode Control
The AX3071 provides CC/CV function. The Constant output Current control Mode and
Constant output Voltage control Mode.
Over Current Protection
The AX3071 provides over current protection. A drop voltage on the current sensing
resister is over the OCP value, the OCP function will shut down the controller.
Soft Start
The AX3071 has internal soft start function to control rise rate of the output voltage
and limits the large inrush current at start up. The typical soft start interval is about 3mS.
Power on Reset
A power-on reset circuit monitors the input voltage. When the input voltage exceeds
7.5V, the converter will start operation. Once input voltage falls below 6.5V, the controller
will shut down.
The AX3071 provides over temperature protection. The OTP will shut down the
converter when junction temperature exceeds 160°C. Once the junction temperature cools
down by approximately 40°C, the converter will resume normal operation.
Current Limit Protection
The Current limit is set by outside resistance (RSENSE), When the SEN1 or SEN2
voltage larger than 100mV, the current limit is happened that driver can be turned off. The
current limit set according to the following equation:
100mV
Current Limit (A) =
R SENSE
Output Short-Circuit Protection
The AX3071 provides output short-circuit protection function. When VOUT is short
(VFB
很抱歉,暂时无法提供与“AX3071UA”相匹配的价格&库存,您可以联系我们找货
