VP3481
High-Efficiency Boost/SEPIC DC/DC Controller
Features
General Description
The VP3481 is a versatile controller designed for
use in Boost, SEPIC and
VP3481MSG10-A in MSOP10 package is AECQ100 Qualified and Manufactured on an Au-
power converter and to-
tomotive Grade Flow
pologies that needs an external low-side NMOSFET acting as primary switch. Besides cycle-
Wide Input Voltage from 2.97V to 40V
by-cycle current limiting, current mode control
Reference Voltage with ± 3.0% Accuracy
scheme also makes it wide bandwidth and good
Adjustable 100kHz~1MHz Clock Frequency
transient response. The current limit can be pro-
10μA Shutdown Current
grammed simply with an external resistor.
1A Peak Current Limit Using Internal Driver
Current Mode Operation
The switching frequency can be set in any value
Internal 4/2Ω MOSFET Switch
between 100kHz and 1MHz with a resistor or any
External RC Compensation
external clock source. The VP3481 can be operat-
Internal Soft-Start
ed at high switching frequency to save the solu-
High Efficiency at Light Loads
tion board size. While entering shutdown mode,
Current Limit and Over Temperature Protection
the VP3481 only sinks 5μA and it allows power
supply sequencing. It has built-in protection cir-
Adjustable Input UVLO Threshold Voltage
cuits such as thermal shutdown, under-voltage
MSOP-10 and TDFN3x3 Green Package with
lockout, short circuit protection, and overvoltage
protection. Internal soft-start circuitry reduces the
inrush current at start-up.
VP3481 is available in
small
MSOP-10 and
DFN3X3-10 green package.
Typical Application
VP3481 Rev A.06
1
Applications
Portable Speakers
Offline Power Supply
Battery Powered Device
Set-Top Box
Photovoltaic Inverters
http://www.viva-elec.com.tw
VP3481
Functional Block Diagram
Pin Assignments And Descriptions
TDFN10
Top View
MSOP-10
Top View
ISEN
UVLO
COMP
FB
1
2
3
4
10
9
8
7
IN
VREG
GATE
PVSS
AGND
5
6
FADJ
ISEN
UVLO
COMP
FB
AGND
1
2
3
4
5
10
9
8
7
6
IN
VREG
GATE
PVSS
FADJ
Pin No.
Pin
I/O/P
Function Description
1
ISEN
P
Current Sense. Use an external resistor in series with ground to measure the voltage drop.
2
UVLO
I
3
COMP
I
4
FB
I
5
AGND
P
Under Voltage Lockout. Use a proper ratio resistor divider network to determine the voltage input to allow switching and the hysteresis to disable switching.
Compensation. Use a RC/C network to do proper loop compensation.
Output Feedback. Connect the external resistor divider network from output to this pin to
sense output voltage. The FB pin voltage is regulated to internal 1.275V reference voltage.
Analog Ground. Connect to exposed pad.
Frequency Adjust/Synchronization/Shutdown. A resistor connected from this pin to
ground simply sets the oscillator frequency. An external clock signal at this pin will syn-
6
FADJ
I
7
PVSS
I
Power Ground. Connect to exposed pad.
8
GATE
O
Gate Drive. Connect this terminal to the gate pin of the external MOSFET.
9
VREG
O
10
IN
I
chronize the controller to the clock. Pull on this pin for ≥ 30 µs will turn the device off
and the device will then very few current about 5µ A from the supply.
VP3481 Rev A.06
Drive Supply Voltage. A bypass capacitor must be connected from this pin to ground. Do
not bias this pin with external power source.
Power Supply Input.
2
VP3481
Absolutely Maximum Ratings
Over operating free-air temperature range, unless otherwise specified (* 1)
Symbol
Parameter
Limit
Unit
VIN
Supply voltage range
-0.3 to 42
V
Low voltage range
-0.3 to 6
V
VCC(VREG)
Regulator output pin range
-0.3 to 5
V
VISEN
Current sense pin range
-0.4 to 0.6
TJMAX
junction temperature MAX
TSTG
VLV (COMP/UVLO/FB/
FADJ/GATE)
V
150
o
C
Storage temperature range
-65 to 150
o
C
Electrostatic discharge
Human body model
2
kV
Machine model
200
V
( *1): Stress beyond those listed at “absolute maximum rating” table may cause permanent damage to the device. These are stress rating ONLY. For
functional operation are strongly recommend follow up “recommended operation conditions” table.
Recommended Operating Conditions
Symbol
Parameter
VIN
Specification
Unit
Min
Max
Supply voltage
2.97
40
V
fOSC
Switching Frequency range
0.1
1
MHz
TJ
Operating Junction range
-40
125
o
C
Thermal Information
Thermal Metric Parameter
θJC(top)
Thermal resistance (Junction to Case
(top)
VP3481MSG10
LM3481DNG10
MSOP
TDFN
46
54
o
C/W
Unit
θJA
Thermal resistance (Junction to Air)
147
49
o
C/W
θJB
Thermal resistance (Junction to Board)
81
21
o
C/W
ψJT
Junction-to-top characterization parameter
3
2
o
C/W
77
21
o
C/W
ψJB
Junction-to-board characterization parame-
VP3481 Rev A.06
ter
3
VP3481
Electrical Characteristics
VIN=12V, RFADJ=150kΩ, TJ=25℃, unless otherwise specified (* 1)
Symbol
Parameter
Specification
Test Condition
Min
VCOMP=1.4V, 3V
很抱歉,暂时无法提供与“VP3481MSG10”相匹配的价格&库存,您可以联系我们找货
