HT84063A
DC-to-DC Converter Control Circuits
(compatible to MC34063)
1.
DESCRIPTION
The HT84063A is a monolithic control circuit containing the primary functions required for DC-to-DC converters.
These devices consist of a internal temperature compensated reference, comparator, controlled duty cycle oscillator
with an active current limit circuit, driver and high current output switch. This series was specifically designed to
be incorporated in Step-Down and Step-up and Voltage-Inverting applications with a minimum number of external
components.
2.
FEATURES
• Operation from 3.0V to 40V Input
• Low Standby Current
• Current Limiting
• Output Switch Current to 1.5A
• Output Voltage Adjustable
• Frequency Operation to 100kHz
• Precision 2% Reference
ORDERING INFORMATION
HT84063ANZ DIP8
Block Diagram
HT84063AREZ ESOP8
TA = 0 to 70C for all packages.
Pin Connection
3.
ABSOLUTE MAXIMUM RATINGS
Rating
Power Supply Voltage
Comparator Input Voltage Range
Switch Collector Voltage
Switch Emitter Voltage (VPIN1 = 40V)
Switch Collector to Emitter Voltage
Driver Collector Voltage
Driver Collector Current (Note 1)
Switch Current
Operating Junction Temperature
Operating Ambient Temperature Range
Storage Temperature Range
Symbol
VCC
VIR
VC(switch)
VE(switch)
VCE(switch)
VC(driver)
IC(driver)
ISW
TJ
TA
Tstg
Value
40
-30 to +40
40
40
40
40
100
1.5
+150
0 to +70
-65 to +150
Unit
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
MA
A
o
C
o
C
o
C
Rev. 01
HT84063A
4. ELECTRICAL CHARACTERISTIC (Vcc=5.0V, TA= Tlow to Thigh , unless otherwise specified)
Characteristics
Symbol
Min
Typ
OSCILLATOR
33
fosc
24
Frequency (Vpin5 = 0V, CT = 1.0nF, TA=25C)
35
ICHG
24
Charge Current (Vcc=5.0 to 40 V, T A=25C)
220
IDISCHG
140
Discharge Current (Vcc=5.0 to 40 V, T A=25C)
Discharge To Charge Current Ratio
IDISCHG/ ICHG
5.2
6.5
300
V
250
Current Limit Sense Voltage (ICHG= IDISCHG, TA=25C)
ipk (sense)
OUTPUT SWITCH
Saturation Voltage, Darlington Connecttion (ISW=1A
VCE(SAT)
1.0
Vcc=5.0V, pin 1, 8 connected)
VCE(SAT)
0.45
Vcc=5.0V, pin8 = 82)
75
hFE
50
DC Current Gain (ISW=1A Vcc=5.0V, TA=25C)
40
Collector Off-State Current (VCE=40V)
IC(off)
Max
Unit
42
42
260
7.5
350
kHz
1.3
V
0.7
V
100
A
COMPARATOR
Threshold Voltage
Vth
1.225
1.275
(TA=25C)
1.21
1.29
(TA =Tlow to Thigh)
Threshold Voltage Line Regulation (Vcc=3.0V to 40V,
Regline
1.4
5.0
TA=25C)
Input Bias Current (VIN=0V)
IIB
-20
-400
TOTAL DEVICE
Supply Current
Icc
4.0
(Vcc = 5.0 V to 40 V, CT = 1.0 nF, Pin 7 = VCC, Vpin 5 >
Vth, Pin 2 = Gnd, remaining pins open)
Note:
1. Maximum package power dissipation limits must be observed
2. Low duty cycle pulse techniques are used during test to maintain junction temperature as close to ambient
temperature as possible.
A
A
mV
V
mV
nA
mA
Rev. 01
HT84063A
5.
TYPICAL PERFORMANCE CHARACTERISTICS
Rev. 01
HT84063A
6.
APPLICATION CIRCUIT
6.1 Step-up Converter
6.2 External Current Boost Connections for IC Peak Greater than 1.5A
6.2a External NPN Switch
6.2b External NPN Saturated Switch
6.3 Step-down Converter
Rev. 01
HT84063A
6.4 External Current Boost Connections for IC Peak Greater than 1.5A
6.4a External NPN Switch
6.4b External NPN Saturated Switch
Rev. 01
HT84063A
6.5 Voltage Inverting Converter
6.6 External Current Boost Connections for IC Peak Greater than 1.5A
6.6a External NPN Switch
6.6b External NPN Saturated Switch
Rev. 01
HT84063A
7.
Design Formula Table
Calculation
Step-Up
Step-Down
Voltage-Inverting
Vout VF - Vin(min)
Vin(min) - Vsat
Vout VF
Vin(min) - Vsat - Vout
Vout VF
Vin Vsat
1
fmin
1
fmin
1
fmin
4.0 x 10-5 ton
4.0 x 10-5 ton
4.0 x 10-5 ton
ton
2Iout(max)
1
toff
2Iout(max)
ton
2Iout(max)
1
toff
RSC
0.3 / Ipk(switch)
0.3 / Ipk(switch)
0.3 / Ipk(switch)
L(min)
Vin(min) - Vsat
ton(max)
Ipk(switch)
ton(max)
Ipk(switch)
Vin(min) - Vsat
ton(max)
Ipk(switch)
ton / toff
(ton + toff)max
CT
Ipk(switch)
CO
9
Iout ton
Vripple(pp)
Ipk(switch)(ton toff)
8Vripple(pp)
9
Iout ton
Vripple(pp)
Terms and Definitions
Vsat – Saturation voltage of the output switch.
VF – Forward voltage drop of the output rectifier.
The following power supply characteristics must be chosen:
Vin – Nominal input voltage
Vout – Desired output voltage.
Iout – Desired output current.
fmin – Minimum desired output switching frequency at the selected values of V in and IO
Vripple(pp) – Desired peak-to-peak output ripple voltage. In practice, the calculated capacitor value will need to be
increased due to its equivalent series resistance and board layout. The ripple voltage should be kept to a low value since
it will directly affect the line and load regulation.
Rev. 01
HT84063A
DIP8
ESOP8
Rev. 01
很抱歉,暂时无法提供与“HT84063AREZ”相匹配的价格&库存,您可以联系我们找货
