FP6276BXR-G1
FP6276BXR-G1
    ANALOGYSEMI(类比半导体)
    SOP8_EP
    功能类型:升压型;同步整流:是;输出通道数:1;拓扑结构:升压式;输入电压:2.4V~4.5V;输出电压:5.3V;输出电流(最大值):6A;开关频率:500kHz;
FP6276BXR-G1 数据手册
FP6276B 500kHz 6A High Efficiency Synchronous PWM Boost Converter General Description The FP6276B is a current mode boost DC-DC converter with PWM/PSM control. Its PWM circuitry with built-in 40mΩ high side switch and 40mΩ low side switch make this regulator highly power efficient. The internal compensation network also minimizes external component counts to only 6. An internal 0.6V voltage is connected to error amplifier the non-inverting input as precision reference voltage. Built-in soft-start function can reduce the inrush current. Features  Current mode with PWM/PSM control  Input voltage range: 2.4V~4.5V  Adjustable Output up to 5.3V  Shutdown current:
FP6276BXR-G1 价格&库存
很抱歉,暂时无法提供与“FP6276BXR-G1”相匹配的价格&库存,您可以联系我们找货
