GR8830CG
GR8830CG
    GRENERGY(南京绿芯)
    SOT-26
GR8830CG 数据手册
GR8830 Green-Mode PWM Controller below 100mW Standby Power Features Description  Current mode PWM control The GR8830 is a highly-integrated, low startup  Standby power below 100mW solution current, current mode PWM controller with  Under voltage lockout (UVLO) Green-mode function. This function enables the  Non-audible-noise green-mode control power supply to easily meet even the strictest  Programmable switching frequency power conservation requirements. The integrated  Internal leading-edge blanking functions also include the leading-edge blanking  Internal slope compensation of  Internal soft start compensation,  Gate output voltage clamp limiting, and soft start. OLP, OCP and OVP  Jitter and soft driving for reducing EMI provide protection performance for fault conditions.  Over-voltage protection (OVP) on VCC pin For protecting the external power MOSFET from  Over-load protection (OLP) being damaged by supply over voltage, the  Over-current protection (OCP) on CS pin GR8830 OUT pin voltage is clamped to about the current sensing, cycle-by-cycle internal peak slope current 13V. The GR8830 improves the performance and Applications reduces the cost of power supplies. It is with both  Switching AC/DC power adaptor DIP-8 and SOT-26 package.  Battery charger  Open-frame SMPS Ordering and Marking Information GR8830 Package Code RoHS Code G: Green (Halogen Free) Device L: PB Free Device J: DIP-8 C: SOT-26 DIP-8 SOT-26 GR8830 X X XXX Code 1 30 X X XXX Code 2 Serial No. Code 1 Serial No. Code 2 Code 1 8 9 A B Year 2008 2009 2010 2011 Code 2 1 2 3 4 Month Jan. Feb. Mar. Apr. G 2016 ● ● ● H 2017 I 2018 J 2019 9 A B C Sep. Oct. Nov. Dec. Grenergy OPTO Inc. reserves the right to make changes to improve reliability or manufacture ability without notice, and advise customers to obtain the latest version of relevant information to verify before placing orders. 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 1 GR8830 Pin Configuration Pin Description Pin No. Name Function 1 GND 2 COMP 3 RT Connecting a resistor to ground to set the switching frequency 4 CS Current sense pin, connect to sense the MOSFET current 5 VCC Power Supply pin 6 OUT The output driver for driving the external MOSFET Ground Voltage feedback pin, by connecting a photo-coupler to control the duty cycle Note: Pin No. is only for SOT-26 package, DIP-8 see Pin Configuration. Absolute Maximum Ratings Supply voltage VCC COMP, RT, CS OUT --------------------------------------------------------------------------------------------------------- 30V -------------------------------------------------------------------------------------------------------- -0.3 ~ 7V ------------------------------------------------------------------------------------------------------------ Junction temperature -0.3 ~ Vcc+0.3V ---------------------------------------------------------------------------------------------------- Operating ambient temperature Storage temperature range ----------------------------------------------------------------------------- ------------------------------------------------------------------------------- SOT-26 package thermal resistance -20℃ ~ 85℃ -65℃ ~ 150 ℃ ---------------------------------------------------------------------------- Power dissipation (SOT-26, at ambient temperature = 85℃) Power dissipation (DIP-8, at ambient temperature = 85℃) Lead temperature (All Pb free packages, soldering, 10 sec) ESD voltage protection, human body model ESD voltage protection, machine model 150℃ 250℃/W ------------------------------------------------ 250mW --------------------------------------------------- 650mW -------------------------------------------------- 260℃ ------------------------------------------------------------------------- ---------------------------------------------------------------------------- 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 2KV 200V 2 GR8830 Recommended Operating Conditions Item Min. Max. Unit Supply voltage VCC 12 25 V Switching frequency 50 130 KHz Block Diagram VCC VCC UVLO Internal Bias & Vref 10.8V/6.8V + 27V 3.5V EN debounce + Vref OK VCC OK OVP All Blocks OLP 60ms delay - Latch EN Protection RB + 0.95V CS LEB - CS open, 2ndary rectify diode short + 0.9V OCP - Slope compensation Protection Vbias Soft Start + - R Q RT_F EN Driver stage OUT S COMP Mode select OSC RT RT open/short RT_F GND 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 3 GR8830 Electrical Characteristics (VCC = 15.0V and TA = +25℃,unless otherwise specified) Parameter Pin Min. Typ. Max. Unit 15 uA SUPPLY VOLTAGE Startup current 5 8 Operating current (with 1nF load on OUT pin), Vcomp = 0V 5 1.5 mA Operating current (with 1nF load on OUT pin), Vcomp = 2.5V 5 2.5 mA 5 0.6 mA UVLO (off) 5 6.8 V UVLO (on) 5 10.8 V OVP level on VCC pin 5 Operating current (with 1nF load on OUT pin), protection tripped (OLP, OVP) 26 27 28 V 5 V VOLTAGE FEEDBACK Open loop voltage, COMP pin open 2 Green-mode threshold voltage 2 1.8 V CURRENT SENSING Maximum input voltage, Vcs (off) 4 0.85 Minimum input voltage at 0% duty, Vcs (off) Leading-edge blanking time 4 Input impedance 4 Delay to output 4 0.9 0.95 V 0.6 V 350 nS 1 MΩ 100 nS OSCILLATOR Frequency (RT = 100KΩ) 3 Jitter frequency 3 Green mode frequency (RT = 100KΩ) 3 Temp. stability (-40°C ~ 110°C) Voltage stability (Vcc = 11V ~ 25V) 60 65 70 ±6 20 KHz % 25 KHz 3 3 % 3 1 % Output low level, VCC = 15V, Io = 10mA 6 1 V Output high level, VCC = 15V, Io = 10mA 6 Rising time, load capacitance = 1000pF 6 200 nS Falling time, load capacitance = 1000pF 6 80 nS VGATE-clamp (at VCC = 20V ) 6 GATE DRIVER OUTPUT 8 12 V 13 14 V OLP OLP trip level, Vcomp (OLP) - 3.5 V OLP delay time (note), Fs = 65KHz - 60 mS PWM Section Maximum duty cycle - 70 75 80 % - 130 160 190 ℃ OTP OTP trip level 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 4 GR8830 Typical Performance Characteristics 2.2 10.0 Operating current (mA) VDD Start up current (uA) 12.0 8.0 6.0 4.0 2.0 -40 0 40 80 1.8 1.6 1.4 1.2 120 125 0 40 80 120 125 Temperature (℃ ) Fig. 1 VDD Start up current vs. Temperature Fig. 2 Operating current vs. Temperature Minimum Input Voltage of CS pin(V) 3.8 3.6 3.4 3.2 3.0 -40 0 40 120 125 80 Temperature (℃ ) Fig. 3 OLP Trip - Level vs. Temperature 0.61 0.60 0.59 0.58 0.57 -40 0 40 Temperature (℃ ) 80 120 125 Green Mode Frequency (KHz) RT=100Kohm 25 67 24 23 66 22 65 64 63 -40 0.62 Fig. 4 Minimum Input Voltage of CS pin vs. Temperature 68 Frequency (KHz)RT=100Kohm -40 Temperature (℃ ) 4.0 OLP-Trip Level (V) 2.0 0 40 80 120 125 Temperature (℃ ) Fig. 5 Frequency vs. Temperature 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 21 20 -40 0 40 Temperature (℃ ) 80 120 125 Fig. 6 Green Mode Frequency vs. Temperature 5 GR8830 Application Information Start-up Current The typical start-up current is around 8uA. Very low start-up current allows the PWM controller to increase the value of start-up resistor and then reduce the power dissipation on it. Where R is the resistor connected at RT pin. 100Kohm resistor results in 65KHz switching frequency. Under-voltage Lockout (UVLO) A The recommended range of oscillation frequency is 50 KHz~130 KHz. A hysteresis UVLO comparator is implemented in GR8830, once the VCC rises above UVLO (on) voltage, the controller starts to switch with a soft start period. It will continue to operate unless the voltage drops below UVLO (off) voltage. It’s operation is shown in Fig. 7 Green-Mode Operation When the load decreases to an extent, the frequency of the controller will decrease so as to reduce the system power consumption. The minimum frequency is about 21 KHz, which is outside the audio range. Leading-edge Blanking (LEB) Vcc Each time the power MOSFET is switched on, a turn-on spike will inevitably occur at the sense UVLO (on) resistor. To avoid fault trigger, a 350ns leading-edge blanking time is built in. Conventional RC filtering UVLO (off) can therefore be omitted. During this blanking period, the current-limit comparator is disabled and Fig. 7 Internal Slope Compensation Soft Start During initial power on, the GR8830 provides soft start function. can not switch off the gate driver. It effectively suppresses the start up peak current to reduce the power MOSFET drain voltage especially at high line. A built-in slope compensation circuit is constructed in GR8830. When the switch is on, a ramp voltage is added to the sensed voltage across the CS pin, which helps to stabilize the system and prevent sub-harmonic oscillations. Oscillator The maximum duty-cycle of internal oscillator is limited about 75% saturation. to avoid the transformer The frequency of the oscillator is decided by an external resistor connected from RT pin to ground. fosc= 6500KHz/R (Kohm) 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 6 GR8830 UVLO on. The GR8830 is working in a hiccup mode as shown in Fig. 9. Application Information (Cont.) Over-load Protection (OLP) The controller has over load protection function. An internal circuit detects the load level, when the load is larger than a threshold and the condition lasts more than 60ms, the gate output will keep low VCC OVP Tripped OVP Level UVLO(on) UVLO(off) t level. Then VCC decreases below UVLO off level, OUT the controller resets again. Fig. 8 shows the waveform of the OLP operation. Non-Switching Switching Switching t VCC Fig. 9 UVLO(on) Gate Clamp/Soft Driving UVLO(off) OLP Driver is clamped to 13V by an internal clamping ( off ) OLP Counter Reset t circuit. COMP OLP delay time Those damages usually come from undesired over-voltage gate signals. Under the conditions listed below, the gate output will turn off 3.5 V OLP trip Level t immediately to protect the power circuit. The GR8830 also has soft driving function to minimize OUT EMI. Switching Non - Switching Switching VCC Mode Operation t In order to avoid the output voltage shut down by Fig. 8 load changing from full to no load, the GR8830 is built-in the VCC mode function. When the load from Over-voltage Protection (OVP) on VCC full changes to no load, the output voltage will To prevent power MOSFET from being damaged, overshoot and pull low the COMP pin by feedback the GR8830 is implemented an OVP function on loop. Thus the duty will disappear and no power VCC. When the VCC voltage is higher than the OVP delivers to the secondary. If there is without any threshold voltage, the output gate driver circuit will mechanism to prevent this situation, the VCC pin be shut down immediately to stop the switching of voltage will down to UVLO off and the IC will re-start power MOSFET. The VCC OVP function is an again. In the GR8830, before the VCC is down to auto-recovery type protection. If OVP happens, the UVLO off, it will force the OUT pin outputs the pulses will be stopped and recover at the next specified duty to pull the VCC higher than UVLO off. 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 7 GR8830 The operation is shown in Fig.10. Application Information (Cont.) VCC The VCC mode function is used to prevent the VCC mode Burst mode output re-start again when load changes. So never VCC mode(off) VCC mode(on) UVLO(off) let the system operate on the VCC mode at no load. t LOAD The system should operate on burst mode, otherwise the input power maybe become larger. Full load t OUT Switching t Fig. 10 Typical Application Circuit 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 8 A B C N L F1 2A/250V T1B 1 5 OHM/3A NTC 1 10R R6 t D FR1 03 D2 NC R2 NC R1 C2 10u/50V CX 1 0.1u L1 UU 9.8 NC Z1 R2B 1M R2A 1M 2 1N4 007 D1A ~D 2 IC2B EL8 17 C13 0.01u C1 33u/400V RT 91K 3 2 RT CO MP 5 IC1 GR 8830 VC C GND 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 1 1 3 CS OU T 3 4 6 CS 100P R7 27R RS 100R R4B 51K R4A 51K D3 1N4 007 2200P /1K V C4 4 RS 1//RS 2 2.4R//1.5R Q1 2A/600V T1A EI22 1KP CY 1 R51 A,B 22R //22R D51 5A/40V C51 2200P /1K V 4 C52 1000u /25V 5 Date: File: B Size Title C55 0.1u R53 2.8K R55 0 R52 10.7K 1 5 -Oct-2 0 0 9 D:\G R8 8 3 6 \LD 7 5 3 2 -SCH .d d b R54 250R C54 470u/25V ZD5 1 NC Nu mb er IC51 KA 431AZ IC2A EL8 17 R56 NC L51 R3* 15 :0.7* 15Ts 5 6 Sh eet o f Drawn By : Rev is io n GN D VO UT 12V /1.5A 6 A B C D GR8830 9 GR8830 Package Information SOT-26 SYMBOL MILLIMETERS MIN. INCHES MAX. A MIN. MAX. 1.45 0.057 A1 0.00 0.15 0.000 0.006 A2 0.90 1.30 0.035 0.051 b 0.30 0.50 0.012 0.020 c 0.08 0.22 0.003 0.009 D 2.70 3.10 0.106 0.122 E 2.60 3.00 0.102 0.118 E1 1.40 1.80 0.055 0.071 e 0.95 BSC 0.037 BSC e1 1.90 BSC 0.075 BSC L θ 0.30 o 0 0.60 8 o 0.012 o 0 0.024 8 o Note: 1. Followed from JEDEC TO-178 AB. 2. Dimension D and E1 do not include mold flash, protrusions or gate burrs. Mold flash, protrusions or gate burrs shall not exceed 10 mil per side. 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 10 GR8830 Package Information DIP-8 SYMBOL MILLIMETERS MIN. INCHES MAX. A MIN. MAX. 5.33 0.210 A1 0.38 A2 2.92 4.95 0.015 0.115 0.195 b 0.36 0.56 0.014 0.022 b2 1.14 1.78 0.045 0.070 c 0.20 0.35 0.008 0.014 D 9.01 10.16 0.355 0.400 D1 0.13 E 7.62 E1 6.10 0.005 8.26 0.300 7.11 0.240 0.325 0.280 e 2.54 BSC 0.100 BSC eA 7.62 BSC 0.300 BSC eB L 10.92 2.92 3.81 0.430 0.115 0.150 Note: 1. Followed from JEDEC MS-001 BA. 2. Dimension D, D1 and E1 do not include mold flash or protrusions. Mold flash or protrusions shall not exceed 10 mil. 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 11 GR8830 Carrier Tape & Reel Dimensions SOT-26 Application A H 178.0±2.00 50 MIN. P0 P1 P2 D0 D1 4.0±0.10 4.0±0.10 2.0±0.05 1.5+0.10 -0.00 1.0 MIN. SOT-26 T1 C d 8.4+2.00 13.0+0.50 -0.00 -0.20 D 1.5 MIN. W E1 20.2 MIN. 8.0±0.30 1.75±0.10 T A0 B0 F 3.5±0.05 K0 0.6+0.00 3.20±0.20 3.10±0.20 1.50±0.20 -0.40 (mm) Application SOT -26 Carrier Width Cover Tape Width Devices Per Reel 8 5.3 3000 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 12 GR8830 Taping direction information SOT-26 Direction of feed AAA AA AAA AA AAA AA AAA AA AAA AA AAA AA AAA AA AX AX AX AX AX AX AX Direction of feed _______________________________________________________________________ 2012.03 Ver. 1.2 Copyright Grenergy OPTO, Inc. www.grenergy-ic.com 13
GR8830CG 价格&库存
很抱歉,暂时无法提供与“GR8830CG”相匹配的价格&库存,您可以联系我们找货
