AZ164S-04F.R7G
AZ164S-04F.R7G
    AMAZING(晶焱)
    DFN-10(1x2.5)
AZ164S-04F.R7G 数据手册
AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Features Description ESD Protect for Super Speed Differential Signaling (above 10Gb/s) channels Protects four I/O lines Provide ESD protection for each line to IEC 61000-4-2 (ESD) ±17kV (air), ±15kV (contact) IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 5.5A (8/20µ µs) For low operating voltage of 1.5V and below Ultra low capacitance : 0.45pF typical Fast turn-on and Ultra-low clamping voltage Array of ESD rated diodes with internal equivalent TVS (Transient Voltage Suppression) diode Solid-state silicon-avalanche and active circuit triggering technology Green part Applications USB3.1 and USB3.0 interfaces Thunderbolt interface DisplayPort interface SATA and eSATA interface V-By-One interface Consumer Electronics AZ164S-04F is a design which includes ESD rated diode arrays to protect high speed data interfaces. The AZ164S-04F has been specifically designed to protect sensitive components which are connected to data and transmission lines from over-voltage caused by Electrostatic Discharging (ESD), Lightning, and Cable Discharge Event (CDE). AZ164S-04F is a unique design which includes ESD rated, ultra low capacitance steering diodes and a unique design of clamping cell which is an equivalent TVS diode in a single package. During transient conditions, the steering diodes direct the transient to either the internal ESD line or to ground line. The internal unique design of clamping cell prevents over-voltage on the internal ESD line and on the I/O line, which is protecting any downstream components. AZ164S-04F may be used to meet the ESD immunity requirements of IEC 61000-4-2, Level 4 (±15kV air, ±8kV contact discharge). Circuit Diagram 1 2 4 Pin Configuration 5 3,8 Line-1 1 10 NC Line-2 2 9 GND 3 Line-3 4 7 NC Line-4 5 6 NC 8 NC GND DFN2510P10E (Top View) Revision 2016/04/13 ©2016 Amazing Micro. 1 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL RATING UNITS Peak Pulse Current (tp =8/20µs) IPP 5.5 A Operating Voltage (I/O pin-GND) VDC (GND – 0.5) to 1.65 V ESD per IEC 61000-4-2 (Air) ±17 VESD ESD per IEC 61000-4-2 (Contact) kV ±15 Lead Soldering Temperature TSOL 260 (10 sec.) o Operating Temperature TOP -55 to +85 o -55 to +150 o Storage Temperature TSTO C C C ELECTRICAL CHARACTERISTICS PARAMETER Reverse Stand-Off Voltage Channel Leakage Current Reverse Breakdown Voltage Forward Voltage ESD Trigger Voltage (Note 1) ESD Clamping Voltage (Note 1) ESD Dynamic Turn-on Resistance Channel Input Capacitance Channel to Channel Input Capacitance SYMBOL CONDITIONS VRWM Pin-1,-2,-4,-5 to pin-3,-8, T=25 oC. ICH-Leak VPin-1,-2,-4,-5 = 1.5V, VPin-3,-8 = 0V, T=25 oC. MIN TYP MAX UNITS 1.5 V 1 µA VBV IBV = 1mA, T=25 oC, Pin-1,-2,-4,-5 to pin-3,-8. VF IF = 15mA, T=25 oC, pin-3,-8 to pin-1,-2,-4,-5. 0.9 VESD_trigger IEC 61000-4-2, Contact mode, T=25 oC, I/O pin to Ground. 2 V Vclamp IEC 61000-4-2 +8kV (ITLP = 16A), Contact mode, T=25 oC, I/O pin to Ground. 4.8 V Rdynamic IEC 61000-4-2, 0~+8kV, T=25 oC, Contact mode, any I/O pin to Ground. 0.16 Ω CIN Vpin-3,-8 = 0V, VIN = 1.0V, f = 1MHz, T=25 oC, any I/O pin to Ground. 0.45 0.65 pF CCROSS Vpin-3,-8 = 0V, VIN = 1.0V, f = 1MHz, T=25 oC, between I/O pins. 0.06 0.1 pF 9 V 1.1 V Note 1: ESD Trigger Voltage and ESD Clamping Voltage was measured by Transmission Line Pulsing (TLP) System. TLP conditions: Z0= 50Ω, tp= 100ns, tr= 1ns. Revision 2016/04/13 ©2016 Amazing Micro. 2 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Typical Characteristics Typical Variation of CIN vs. VIN Typical Variation of CIO-to-IO vs. VIN 1.0 0.10 0.09 f=1MHz, T=25 ℃ 0.8 Input Capacitance (pF) Input Capacitance (pF) 0.9 0.7 0.6 0.5 0.4 0.3 0.2 I/O Pin to GND Pin 0.07 0.06 0.05 0.04 0.03 0.02 I/O Pin to I/O Pin 0.1 0.01 0.0 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0 3.3 0.00 0.0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0 3.3 Input Voltage (V) Input Voltage (V) Insertion Loss SDD Transmission Line Pulsing (TLP) Measurement 18 0 16 -3 14 Insertion Loss SDD (dB) Transmission Line Pulsing (TLP) Current (A) f=1MHz, T=25 ℃ 0.08 12 10 8 6 4 2 1 2 3 -9 -12 -15 -18 -21 -24 I/O Pin to GND Pin -27 4 -30 1e+8 0 0 -6 5 6 Transmission Line Pulsing (TLP) Voltage (V) Revision 2016/04/13 ©2016 Amazing Micro. 7.9GHz: -3dB 1e+9 1e+10 Frequency (Hz) 3 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Applications Information These pins should be directly connected to the GND rail of PCB (Printed Circuit Board). To get minimum parasitic inductance, the path length should keep as short as possible. AZ164S-04F can provide ESD protection for 4 I/O signal lines simultaneously. If the number of I/O signal lines is less than 4, the unused I/O pins can be simply left as NC pins. AZ164S-04F AZ1143-04F The AZ164S-04F is designed to protect four data lines from transient over-voltage (such as ESD stress pulse). The device connection of AZ164S-04F is shown in the Fig. 1. In Fig. 1, the four protected data lines are connected to the ESD protection pins (pin1, pin2, pin4, and pin5) of AZ164S-04F. The ground pins (pin3 and pin8) of AZ164S-04F are the negative reference pins. Fig. 1 Data lines connection of AZ164S-04F. Revision 2016/04/13 ©2016 Amazing Micro. 4 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port PACKAGE OUTLINE (DFN2510P10E) TOP VIEW (unit in mm) BOTTOM VIEW (unit in mm) SIDE VIEW (unit in mm) Symbol A A1 A3 D E D1 E1 b e L1 L2 b2 L Millimeters min max 0.40 0.55 0.00 0.05 0.152REF. 2.45 2.55 0.95 1.05 0.35 0.45 0.35 0.45 0.15 0.25 0.5 BSC 0.075 REF 0.05 REF 0.20 0.30 0.35 0.45 Revision 2016/04/13 ©2016 Amazing Micro. 5 Inches min max 0.016 0.022 0.000 0.002 0.006 BSC 0.096 0.100 0.037 0.041 0.014 0.018 0.014 0.018 0.006 0.010 0.020 BSC 0.003 REF 0.002 REF 0.008 0.012 0.014 0.018 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port LAND LAYOUT D D1 Dimensions Index Millimeter Inches A 0.875 0.034 B 0.20 0.008 C 0.50 0.02 C1 1.00 0.039 D 0.25 0.01 D1 0.4 0.016 E 0.675 0.027 F 1.55 0.061 B F A E C C1 Notes: This LAND LAYOUT is for reference purposes only. Please consult your manufacturing partners to ensure your company’s PCB design guidelines are met. MARKING CODE 117XY 164XY Part Number Marking Code AZ164S-04F (Green Part) 164XY Note. Green means Pb-free, RoHS, and Halogen free compliant. 164 = Device Code X = Date Code Y= Control Code Ordering Information PN# Material Type Reel size MOQ MOQ/internal box MOQ/carton AZ164S-04F.R7G Green T/R 7 inch 3,000/reel 4 reel= 12,000/box 6 box =72,000/carton Revision 2016/04/13 ©2016 Amazing Micro. 6 www.amazingIC.com AZ164S-04F Ultra Low Capacitance ESD Protection Array For High Speed I/O Port Revision History Revision Modification Description Revision 2015/12/14 Preliminary Release. Revision 2016/04/13 Formal Release. Revision 2016/04/13 ©2016 Amazing Micro. 7 www.amazingIC.com
AZ164S-04F.R7G 价格&库存
很抱歉,暂时无法提供与“AZ164S-04F.R7G”相匹配的价格&库存,您可以联系我们找货
