SR10100L-B
SR10100L-B
    GOODWORK(固得沃克)
    DO-201AD
SR10100L-B 数据手册
SR1045L THRU SR10100L 10.0 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 40 to 100 Volts CURRENT 10.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * Epitaxial construction DO-27 .220(5.6) .197(5.0) DIA. 1.0(25.4) MIN. MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 1.10 grams .375(9.5) .285(7.2) .052(1.3) .048(1.2) DIA. 1.0(25.4) MIN. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SR1 045 L 40 28 40 See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=100C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG SR1 06 0L 60 42 60 SR1 01 00L UNITS 100 70 100 V V V A 10.0 150 0.47 0.57 200 0.70 0.67 0.85 20 670 250 20 -55 to10+125 -55 to +150 -55 to10+150 A V A mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Ambient Vertical PC Board Mounting 0.375"(9.5mm) Lead Length. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SR1045L THUR SR10100L ) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 1.0 0.5 0 0 20 40 60 80 100 120 140 160 180 200 AMBIENT TEMPERATURE,( C) PEAK FORWAARD SURGE CURRENT,(A) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 10 3.0 SR 10 10 0L 1.5 SR 10 SR 45 10 L 60 L 2.0 INSTANTANEOUS FORWARD CURRENT,(A) 2.5 0L 10 10 SR 0L 06 R1 L-S 45 10 SR AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 150 .01 120 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 90 8.3ms Single Half Tj=25 C Sine Wave 60 JEDEC method 30 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 1050 900 750 600 450 300 10 Tj=100 C 1.0 .1 Tj=25 C 150 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2015 JAN PAGE:2/2
SR10100L-B 价格&库存
很抱歉,暂时无法提供与“SR10100L-B”相匹配的价格&库存,您可以联系我们找货
SR10100L-B
    • 1+1.02450
