BT169D
FSSeries
0.8A Sensitive Gate SCRs
Product Summary
Symbol
Value
Unit
IT(RMS)
0.8
A
VDRM VRRM
600 / 800
V
IGT
10~200
μA
Feature
Application
With high ability to withstand the shock loading of
large current, Provide high dv/dt rate with strong
resistance to electromagnetic interference.
Power charger, T-tools, massager, solid state
relay, AC Motor speed regulation and so on.
Package
Circuit diagram
TO-92
XXXX
BT169D
Marking
www.fuxinsemi.com
Page 1
Ver2.1
BT169D
FSSeries
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Repetitive peak off-state voltage
VDRM
600 / 800
V
Repetitive peak reverse voltage
VRRM
600 / 800
V
RMS on-state current
IT(RMS)
0.8
A
ITSM
8
A
I2t
0.32
A2s
dIT/dt
50
A/μs
IGM
1
A
PG(AV)
0.1
W
Junction Temperature
TJ
-40 ~ +110
Storage Temperature
TSTG
-40 ~ +150
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current (IG =2×IGT)
Peak gate current
Average gate power dissipation
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Gate trigger current
IGT
Gate trigger voltage
VGT
Gate non-trigger voltage
VGD
Test Condition
VD =12V IT=10mA Tj =25℃
VD =1/2VDRM Tj =110℃
Value
Unit
Min
Max
10
200
μA
0.8
V
0.2
V
latching current
IL
VD =12V IG=0.5mA
3
mA
Holding current
IH
RGK=1kΩ Tj =25℃
4
mA
10
V/μs
1.5
V
Tj=25℃
5
μA
Tj=110℃
0.1
mA
Critical-rate of rise
of commutation voltage
dVD/dt
VD=2/3VDRM Gate Open
Tj =110℃
STATIC CHARACTERISTICS
Forward "on" voltage
VTM
Repetitive Peak Off-State Current
IDRM
Repetitive Peak Reverse Current
IRRM
ITM =1.2A tp=380μs
VD =VDRM VR =VRRM
THERMAL RESISTANCES
Thermal resistance
www.fuxinsemi.com
Rth(j-c)
Junction to case
TYP.
60
℃/W
Rth(j-a)
Junction to ambient
TYP.
150
℃/W
Page 2
Ver2.1
BT169D
FSSeries
Typical Characteristics
FIG.2: RMS on-state current versus case temperature
(full cycle)
I T(RMS) (A)
P(W)
0.8
FIG.1: Maximum power dissipation versus RMS
on-state current (full cycle)
0.6
1.0
0.8
0.6
0.4
0.4
0.2
0.2
0.2
0.6
0.8
I T(RMS) (A)
4
6
3
4
2
2
1
100
1000
Number of cycles
Tj=Tjmax
Tj=25ºC
I GT,I H,I L(T) / I GT,I H,I L(T=25
100
10
2.0
1.5
1.0
0.5
2.5
3.0
V TM (V)
FIG.6: Relative variations of gate trigger current, holding
current and latching current versus junction
temperature (typical values)
FIG.5: Non-repetitive surge peak on-state current for
a sinusoidal pulse with width tp < 10ms
I TMS (A)
Tc
5
8
FIG.4: On-state characteristics (maximum values)
I TM (A)
I TMS (A)
FIG.3: Surge peak on-state current versus number of cycles
50
3.0
2.5
IH
IGT
2.0
IL
1.5
1.0
0.5
1
0.01
0.1
www.fuxinsemi.com
1
10
tp(ms)
0.0
-40
Page 3
-20
60
80
120
100
Tj
Ver2.1
BT169D
FSSeries
Ordering Information
BT169 D
_
600
SCRs IT(RMS): 0.8A
600:VDRM /VRRM≥600V
800:VDRM /VRRM≥800V
D:TO-92
TO-92 Package Information
www.fuxinsemi.com
Page 4
Ver2.1
很抱歉,暂时无法提供与“BT169D”相匹配的价格&库存,您可以联系我们找货
