TD814A-G
TD814A-G
    LIGHTNING(天电光电)
    DIP-4
    输入电压类型:AC,DC;输出通道数:1;正向电压:1.24V;反向电压:6V;输出电流:50mA;接收端电压:80V;集射极饱和电压(Vce(sat)@Ic,IF):60mV@1mA,20mA;隔离...
TD814A-G 数据手册
TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler SCHEMATIC Description The TD814 series combine two AlGaAs infrared emitting diodes as the AC input which is optically coupled to a silicon planar phototransistor 1 4 2 3 detector in a plastic DIP4 package with different lead forming options. With the robust coplanar double mold structure, TD814 series provide the most stable isolation feature. Features  High isolation 5000 VRMS  CTR flexibility available see order information PIN DEFINITION 1. Anode/Cathod 2. Cathode/Anode 3. Emitter 4. Collector PACKAGE OUTLINE  DC input with transistor output  Operating temperature range - 55 °C to 110 °C  REACH compliance  Halogen free  MSL class 1  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC – GB4943.1, GB8898 Applications  AC line monitor  Programmable controller  Telephone line interface  System appliance  Measurement instrument Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 1 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF ±60 mA Peak Forward Current IFP ±1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON 2 Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 2 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBO MAX MIN TYP. L . UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 Reverse Current IR - - Input Capacitance Cin - 10 V IF=±10mA 10 μA VR=6V - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 7 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS Current Transfer Ratio TD814 TD814A CTR TD814B 20 - 300 50 - 150 80 - 400 CTR Symmetry 0.7 - 1.3 Collector-Emitter Saturation Voltage VCE(sat) - 0.06 0.2 Isolation Resistance RISO Floating Capacitance CIO - Cut-off Frequency fc Response Time (Rise) Response Time (Fall) % IF=±1mA, VCE=5V IF=±1mA, VCE=5V V IF=±20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. 0.4 1 pF V=0, f=1MHz - 80 - kHz VCE=2V, IC=2mA RL=100Ω,-3dB tr - 3 18 μs tf - 4 18 μs 10^1 10^1 2 4 VCE=2V, IC=2mA RL=100Ω 4 3 3 Note 3. Fig.12&13 Note 4. Fig.14 Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 3 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current Fig.6 Collector Current vs. Collector-emitter Voltage vs. Collector-emitter Voltage Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 4 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Fig.11 Frequency Response Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 5 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 6 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Standard DIP – Through Hole (DIP Type) Gullwing (400mil) Lead Forming – Through Hole (M Type) Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 7 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming (S Type) Surface Mount (Low Profile) Lead Forming (SL Type) Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 8 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount (Gullwing) Lead Forming (SLM Type) RECOMMENDED SOLDER MASK (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming & Surface Mount (Low Profile) Lead Forming Surface Mount (Gullwing) Lead Forming Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 9 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler TUBE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Standard DIP Option M Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 10 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler BOX SPECIFICATIONS (Tube Type) Inner Box  L x W x H = 52.5cm x 10.7cm x 4.7cm Outer Box  L x W x H = 53.5cm x 23.5cm x 25.5cm Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 11 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S(T1) & SL(T1) Option S(T2) & SL(T2) Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 12 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S(T3) & SL(T3) Option S(T4) & SL(T4) Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 13 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option SLM(T1) Option SLM(T2) Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 14 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S & Option SL Option SLM Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 15 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 16 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 814X VYAWW TD 814 X V Y : Company Abbr. : Part Number : CTR Rank : VDE Option : Fiscal Year A WW : Manufacturing Code : Work Week ORDERING INFORMATION LABEL INFORMATION TD814X(Y)(Z)-GV TD – Company Abbr. 814 – Part Number X – Rank (A/B or None) Y – Lead Form Option (M/S/SL/SLM/None) Z – Tape and Reel Option (T1/T2/T3/T4) G – Green V – VDE Option (V or None) Packing Quantity Option Quantity Quantity – Inner box Quantity – Outer box None 100 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 32k Units M 100 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 32k Units S(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units S(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units S(T3) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units S(T4) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SL(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SL(T3) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T4) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SLM(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SLM(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 17 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 18 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler TEMPERATURE PROFILE OF SOLDERING WAVE SOLDERING (JESD22-A111 COMPLIANT) HAND SOLDERING BY SOLDERING IRON   Soldering Temperature 380+0/-5°C Soldering Time 3 sec max. One time soldering is recommended for all soldering method. Do not solder more than three times for IR reflow soldering. Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 19 TD814 Series www.tdled.com DIP4, AC Input, Photo Transistor Coupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No: DWI-022 Rev:A01 Release Date: 2020/1/11 20
TD814A-G 价格&库存
很抱歉,暂时无法提供与“TD814A-G”相匹配的价格&库存,您可以联系我们找货
