XB8608AF
______________________________________ ________________________________________________________________________________
One Cell Lithium-ion/Polymer Battery Protection IC
GENERAL DESCRIPTION
The XB8608AF Series product is a high
integration solution for lithiumion/polymer battery protection.
XB8608AF contains advanced power
MOSFET, high-accuracy voltage
detection circuits and delay circuits.
XB8608AF is put into an SOP8
package and only one external
component makes it an ideal solution in
limited space of battery pack.
XB8608AF has all the protection functions
required in the battery application including
overcharging, overdischarging, overcurrent
and load short circuiting protection etc. The
accurate overcharging detection voltage
ensures safe and full utilization charging.
The low standby current drains little current
from the cell while in storage.
The device is not only targeted for digital
cellular phones, but also for any other
Li-Ion and Li-Poly battery-powered
information appliances requiring longterm battery life.
Protection of Battery Cell Reverse
Connection
Integrate Advanced Power MOSFET
with Equivalent of 16mΩ RSS(ON)
SOP8 Package
Only One External Capacitor
Required
Over-temperature Protection
Overcharge Current Protection
Two-step Overcurrent Detection:
-Overdischarge Current
-Load Short Circuiting
Charger Detection Function
0V Battery Charging Function
- Delay Times are generated inside
High-accuracy Voltage Detection
Low Current Consumption
- Operation Mode:3.9μ A typ.
- Power-down Mode: 2.2μ A typ.
RoHS Compliant and Lead (Pb) Free
APPLICATIONS
One-Cell Lithium-ion Battery Pack
Lithium-Polymer Battery Pack
FEATURES
Protection of Charger Reverse
Connection
Figure 1. Typical Application Circuit
Suzhou XySemi Electronic Technology Co., Limited.
-1-
www.xysemi.com.cn
REV0.6
XB8608AF
______________________________________ ____________________________________________________ ____________________________
ORDERING INFORMATION
PART
NUMBER
Overcharg Overcharge Overdischarge Overdischarge Overcurrent
Release
Detection
Release
Detection
Pack e Detection
Voltage
Voltage
Voltage
Voltage
age
Current
[IOV1] (A)
[VCU] (V)
[VCL] (V)
[VDL] (V)
[VDR] (V)
XB8608AF
SOP
8
4.30
4.10
2.40
3.0
9
Top Mark
XB8608AYW (note)
Note: “YW” is manufacture date code, “Y” means the year, “W” means the week
PIN CONFIGURATION
Figure 2. PIN Configuration
PIN DESCRIPTION
XB8608AF PIN
NUMBER
PIN NAME
1,2,3
VM
The negative terminal of the battery pack. The internal FET switch
connects this terminal to GND
4
NC
No Connect
5,7,8
GND
Ground, connect the negative terminal of the battery to this pin
6
VDD
Power Supply
PIN DESCRIPTION
ABSOLUTE MAXIMUM RATINGS
(Note: Do not exceed these limits to prevent damage to the device. Exposure to absolute maximum rating
conditions for long periods may affect device reliability.)
PARAMETER
VDD input pin voltage
VALUE
UNIT
-0.3 to 6
V
VM input pin voltage
-6 to 10
V
Operating Ambient Temperature
-40 to 85
°C
-2-
www.xysemi.com.cn
REV0.6
XB8608AF
Maximum Junction Temperature
150
°C
-55 to 150
°C
300
°C
0.625
W
Package Thermal Resistance (Junction to Ambient) θJA
250
°C/W
Package Thermal Resistance (Junction to Case) θJC
130
°C/W
ESD
2000
V
Storage Temperature
Lead Temperature ( Soldering, 10 sec)
Power Dissipation at T=25°C
ELECTRICAL CHARACTERISTICS
Typicals and limits appearing in normal type apply for TA = 25oC, unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Unit
Detection Voltage
Overcharge Detection Voltage
VCU
Overcharge Release Voltage
VCL
Overdischarge Detection Voltage
VDL
Overdischarge Release Voltage
VDR
4.25
4.30
4.35
4.05
4.10
4.15
V
V
2.3
2.4
2.5
V
2.9
3.0
3.1
V
Detection Current
Overdischarge Current Detection
*IIOV1
VDD=3.6V
6.0
9
12.0
A
Overdischarge Current Recovery
*IROV1 VDD=3.6V
15
25
40
uA
Overcharge Current Detection
*ICHOC VDD=3.6V
5
7
9
A
*ISHORT VDD=3.6V
60
A
3.9
6
μA
2.2
3
μA
200
300
400
15
25
35
Load Short-Circuiting
Detection
Current Consumption
Current Consumption in Normal
Operation
IOPE
Current Consumption in power
Down
IPDN
VDD=3.5V
VM =0V
VDD=2.0V
VM pin floating
VM Internal Resistance
Internal Resistance between
VM and VDD
*RVMD
Internal Resistance between VM
and GND
*RVMS
VDD=2.0V
VM pin floating
VDD=3.6V
kΩ
kΩ
VM=1.0V
FET on Resistance
Equivalent FET on Resistance
*RSS(ON)
VDD=3.6V IVM =1.0A
-3-
14
16
19.5
mΩ
www.xysemi.com.cn
REV0.6
XB8608AF
Over Temperature Protection
*TSHD+
150
Over Temperature Recovery Degree *TSHD-
110
oC
Detection Delay Time
Overcharge Voltage Detection
Delay Time
Overdischarge Voltage Detection
*tDL
Delay Time
Overdischarge Current 1 Detection *tIOV1
Delay Time
Overcharge
Delay Time
Current
Detection *tCHOC
Load Short-Circuiting Detection
Delay Time
80
130
180
mS
60
mS
VDD=3.6V
5
10
mS
VDD=3.6V
5
10
mS
380
600
uS
*tCU
*tSHOR
VDD=3.6V
180
T
Note:* ---The parameter is guaranteed by design.
Figure 3. Functional Block Diagram
FUNCTIONAL DESCRIPTION
The XB8608AF monitors the voltage and
current of a battery and protects it from
being damaged due to overcharge voltage,
overdischarge voltage, overdischarge
current, and short circuit conditions by
disconnecting the battery from the load
or charger. These functions are required in
-4-
order to operate the battery cell within
specified limits.
The device requires only one external
capacitor. The MOSFET is integrated and
its RSS(ON) is as low as 16mΩ typical.
www.xysemi.com.cn
REV0.6
XB8608AF
Normal operating mode
If no exception condition is detected,
charging and discharging can be carried
out freely. This condition is called the
normal operating mode.
Overcharge Condition
When the battery voltage becomes higher
than the overcharge detection voltage (VCU)
during charging under normal condition
and the state continues for the overcharge
detection delay time (tCU) or longer, the
XB8608AF turns the charging control FET
off to stop charging. This condition is called
the overcharge condition. The overcharge
condition is released in the following two
cases:
1, When the battery voltage drops below
the overcharge release voltage (VCL), the
on and returns to the normal condition.
2, When a load is connected and
discharging starts, the XB8608AF turns the
charging control FET on and returns to the
normal condition. The release mechanism
is as follows: the discharging current flows
through an internal parasitic diode of the
charging FET immediately after a load is
connected and discharging starts, and the
VM pin voltage increases about 0.7 V
(forward voltage of the diode) from the
GND pin voltage momentarily. The
XB8608AF detects this voltage and
releases the overcharge condition.
Consequently, in the case that the battery
voltage is equal to or lower than the
overcharge detection voltage (VCU), the
XB8608AF returns to the normal condition
immediately, but in the case the battery
voltage is higher than the overcharge
detection voltage (VCU),the chip does not
return to the normal condition until the
battery voltage drops below the overcharge
detection voltage (VCU) even if the load is
connected. In addition, if the VM pin
-5-
overcurrent detection voltage when a load
is connected and discharging starts, the
chip does not return to the normal
condition.
Remark If the battery is charged to a voltage higher
than the overcharge detection voltage (VCU) and
the battery voltage does not drops below the
overcharge detection voltage (VCU) even when a
heavy load, which causes an overcurrent, is
connected, the overcurrent do not work until the
detection voltage (VCU). Since an actual battery has,
however, an internal impedance of several dozens
of mΩ , and the battery voltage drops immediately
after a heavy load which causes an overcurrent is
connected, the overcurrent work. Detection of load
short-circuiting works regardless of the battery
voltage.
Overdischarge Condition
When the battery voltage drops below the
overdischarge detection voltage (VDL)
during discharging under normal condition
and it continues for the overdischarge
detection delay time (tDL) or longer, the
XB8608AF turns the discharging control
FET off and stops discharging. This
condition is called overdischarge condition.
After the discharging control FET is turned
off, the VM pin is pulled up by the RVMD
resistor
between VM and VDD in XB8608AF.
Meanwhile when VM is bigger than 1.5
V (typ.) (the load short-circuiting detection
voltage), the current of the chip is reduced
to the power-down current (IPDN). This
condition is called power-down condition.
The VM and VDD pins are shorted by the
RVMD resistor in the IC under the
overdischarge and power-down conditions.
The power-down condition is released
when a charger is connected and the
potential difference between VM and VDD
becomes 1.3 V (typ.) or higher (load shortcircuiting detection voltage). At this time,
the FET is still off. When the battery
voltage becomes the overdischarge
detection voltage (VDL) or higher (see note),
www.xysemi.com.cn
REV0.6
XB8608AF
the XB8608AF turns the FET on and
changes to the normal condition from the
continues for the overcharge detection
delay time (tCU) or longer, the XB8608AF
turns the charging control FET off and
stops charging. This action is called
abnormal charge current detection.
Abnormal charge current detection works
when the discharging control FET is on
and the VM pin voltage drops below the
charger detection voltage (VCHA). When an
abnormal charge current flows into a
battery in the overdischarge condition, the
XB8608AF consequently turns the
charging
control FET off and stops charging after
the battery voltage becomes the
overdischarge detection voltage and the
overcharge detection delay time (tCU)
elapses.
Abnormal charge current detection is
released when the voltage difference
between VM pin and GND pin becomes
lower than the charger detection voltage
(VCHA) by separating the charger. Since the
0 V battery charging function has higher
priority than the abnormal charge current
detection function, abnormal charge
current may not be detected by the product
with the 0 V battery charging function while
the battery voltage is low.
Remark If the VM pin voltage is no less than the
charger detection voltage (VCHA), when the battery
under overdischarge condition is connected to a
charger, the overdischarge condition is released
(the discharging control FET is turned on) as usual,
provided that the battery voltage reaches the
overdischarge release voltage (VDU) or higher.
Overcurrent Condition
When the discharging current becomes
equal to or higher than a specified value
(the VM pin voltage is equal to or higher
than the overcurrent detection voltage)
and the state continues for the overcurrent
detection delay time or longer, the
XB8608AF turns off the discharging control
FET to stop discharging. This condition is
called overcurrent condition. (The
overcurrent
includes overcurrent, or load shortcircuiting.)
The VM and GND pins are shorted
internally by the RVMS resistor under the
overcurrent condition. When a load is
connected, the VM pin voltage equals the
VDD voltage due to the load.
The overcurrent condition returns to the
normal condition when the load is released
and the impedance between the B+ and Bpins becomes higher than the automatic
recoverable impedance. When the load is
removed, the VM pin goes back to the
GND potential since the VM pin is shorted
the GND pin with the RVMS resistor.
Detecting that the VM pin potential is lower
(VIOV1), the IC returns to the normal
condition.
Load Short-circuiting condition
If voltage of VM pin is equal or below
short circuiting protection voltage (VSHORT),
the XB8608AF will stop discharging and
battery is disconnected from load. The
maximum delay time to switch current off is
tSHORT. This status is released when voltage
of VM pin is higher than short protection
voltage (VSHORT), such as when
disconnecting the load.
Delay Circuits
The detection delay time for overdischarge
current 2 and load short-circuiting starts
when overdischarge current 1 is detected.
Abnormal Charge Current Detection
If the VM pin voltage drops below the
charger detection voltage (VCHA) during
charging under the normal condition and it
-6-
www.xysemi.com.cn
REV0.6
XB8608AF
As soon as overdischarge current 2 or load
short-circuiting is detected over detection
delay time for overdischarge current 2 or
load short- circuiting, the XB8608AF stops
discharging. When battery voltage falls
below overdischarge detection voltage due
to overdischarge current, the XB8608AF
stop discharging by overdischarge current
detection. In this case the recovery of battery
voltage is so slow that if battery voltage
after overdischarge voltage detection delay
time is still lower than overdischarge
detection voltage, the XB8608AF shifts to
power-down.
Note
(1) Some battery providers do not recommend
charging of completely discharged batteries. Please
refer to battery providers before the selection of 0 V
battery charging function.
(2) The 0V battery charging function has higher
priority than the abnormal charge current detection
function. Consequently, a product with the 0 V
battery charging function charges a battery and
abnormal charge current cannot be detected during
the battery voltage is low (at most 1.8 V or lower).
(3) When a battery is connected to the IC for the
first time, the IC may not enter the normal condition
in which discharging is possible. In this case, set
the VM pin voltage equal to the GND voltage (short
the VM and GND pins or connect a charger) to
enter the normal condition.
Figure 4. Overcurrent delay time
0V Battery Charging Function (1) (2) (3)
This function enables the charging of a
connected battery whose voltage is 0 V by
self-discharge. When a charger having 0 V
battery start charging charger voltage
(V0CHA) or higher is connected between B+
and B- pins, the charging control FET gate
is fixed to VDD potential. When the voltage
between the gate and the source of the
charging control FET becomes equal to or
higher than the turn-on voltage by the
charger voltage, the charging control FET
is turned on to start charging. At this time,
the discharging control FET is off and the
charging current flows through the internal
parasitic diode in the discharging control
FET. If the battery voltage becomes equal
to or higher than the overdischarge release
voltage (VDU), the normal condition returns.
-7-
www.xysemi.com.cn
REV0.6
XB8608AF
TIMING CHART
1.
Overcharge and overdischarge detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
ON
CHARGE
OFF
VDD
VMVov1
VSS
VCHA
Charger connection
Load connection
tCL
tCU
(1)
(2)
(1)
(1)
(3)
Figure5-1 Overcharge and Overdischarge Voltage Detection
2.
Overdischarge current detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
VDD
VSHORT
VM
Vov2
Vov1
VSS
Charger connection
Load connection
tIOV2
tIOV1
(1)
(4)
(1)
tSHORT
(4)
(1)
(4)
(1)
Figure5-2 Overdischarge Current Detection
Remark: (1) Normal condition (2) Overcharge voltage condition (3) Overdischarge voltage condition (4)
Overcurrent condition
-8-
www.xysemi.com.cn
REV0.6
XB8608AF
3.
Charger Detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
VDD
VM
VSS
VCHA
Charger connection
Load connection
tDL
(1)
(3)
(1)
Figure5-3 Charger Detection
4.
Abnormal Charger Detection
VCU
VCU-VHC
Battery
voltage
VDL+VDH
VDL
ON
DISCHARGE
OFF
ON
CHARGE
OFF
VDD
VM
VSS
VCHA
Charger connection
Load connection
tCU
tDL
(1)
(3)
(1)
(2)
(1)
Figure5-4 Abnormal Charger Detection
Overcurrent condition)
-9-
www.xysemi.com.cn
REV0.6
XB8608AF
TYPICAL APPLICATION
As shown in Figure 6, the bold line is the high density current path which must be kept as
short as possible. For thermal management, ensure that these trace widths are adequate. C1
is a decoupling capacitor which should be placed as close as possible to XB8608AF.
Fig 6 XB8608AF in a Typical Battery Protection Circuit
Precautions
• Pay attention to the operating conditions for input/output voltage and load current so that the
power loss in XB8608AF does not exceed the power dissipation of the package.
• Do not apply an electrostatic discharge to this XB8608AF that exceeds the performance
ratings of the built-in electrostatic protection circuit.
- 10 -
www.xysemi.com.cn
REV0.6
XB8608AF
PACKAGE OUTLINE(SOP8)
- 11 -
www.xysemi.com.cn
REV0.6
XB8608AF
DISCLAIMER
The information described herein is subject to change without notice.
Suzhou XySemi Electronic Technology Co., Limited is not responsible for any
problems caused by circuits or diagrams described herein whose related industrial
properties, patents, or other rights belong to third parties. The application circuit
examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
When the products described herein are regulated products subject to the Wassenaar
Arrangement or other arrangements, they may not be exported without authorization
from the appropriate governmental authority.
Use of the information described herein for other purposes and/or reproduction or
copying without express permission of Suzhou XySemi Electronic Technology Co.,
Limited is strictly prohibited.
The products described herein cannot be used as part of any device or equipment
affecting the human body, such as exercise equipment ,medical equipment, security
systems, gas equipment, or any apparatus installed in airplanes and other vehicles,
without prior written permission of Suzhou XySemi Electronic Technology Co., Limited.
Although Suzhou XySemi Electronic Technology Co., Limited. exerts the greatest
possible effort to ensure high quality and reliability, the failure or malfunction of
semiconductor may occur. The use of these products should therefore give thorough
consideration to safety design, including redundancy, fire-prevention measure and
malfunction prevention, to prevent any accidents, fires, or community damage that
may ensue.
- 12 -
www.xysemi.com.cn
REV0.6
