14D SERIES
PART NUMBER CODE
14
D 220 K
① ② ③ ④
①Element dia.14: φ14.0mm;
②Disc type;
③Varistor voltage,examples:220——22×100=22V,221——22×101=220V;
④ Tolerance,K=±10%,or customer special requirement;
DIMENSIONS
(unit:mm)
D
T
H
d
25mm
L
30mm
D(max)
16.5mm
F(±0.8)
7.5mm
H(max)
20.0mm
L
25-30mm
d(±0.02)
0.8mm
F
T Thickness (max)
(unit:mm)
Part Code
14D
Part Code
14D
14D180L
4.6
14D331K
5.8
14D220K
4.7
14D361K
6.0
14D270K
4.8
14D391K
6.2
14D330K
5.0
14D431K
6.5
14D390K
5.3
14D471K
6.7
14D470K
5.4
14D511K
6.8
14D560K
5.5
14D561K
7.0
14D680K
5.6
14D621K
7.3
14D820K
4.7
14D681K
7.6
14D101K
4.9
14D751K
8.0
14D121K
5.1
14D781K
8.1
14D151K
5.4
14D821K
8.3
14D181K
4.8
14D911K
8.8
14D201K
5.0
14D102K
9.3
14D221K
5.1
14D112K
9.9
14D241K
5.2
14D122K
10.4
14D271K
5.4
14D182K
13.0
14D301K
5.5
PACKAGING
Model
Component Package
Quantity
14D□□□K
14.0mm
500
http://www.sembo.com.cn
14D SERIES
ELECTRICAL CHARACTERISTIC
Part Number
Maximum
allowable
voltage
Φ14.0mm
Standard
High
surge
Varistor
voltage
Clamping
Maximum peak
Maximum peak
voltage
current
current
(Max.)
(8/20μs)
(8/20μs)
AC.rms
DC
V1.0mA
VC
IP
(V)
(V)
(V)
(V)
(A)
Standar
High
Stand
High
d
surge
ard
surge
(A)
(A)
(J)
(J)
Rated
power
(W)
Typical
capacitance
(Reference)
@1KHz(pf)
14D180L
J
10
14
18(15-21)
36
4.0
7.0
11100
14D220K
J
14
18
22(20-24)
43
5.0
8.0
9100
14D270K
J
17
22
27(24-30)
53
6.0
10
7400
14D330K
J
33(30-36)
65
7.5
12
6100
14D390K
J
25
31
39(35-43)
77
8.6
13
14D470K
J
30
38
47(42-52)
93
10.0
17
4300
14D560K
J
35
45
56(50-62)
110
11.0
14D680K
J
40
56
68(61-75)
135
14.0
24
2900
14D820K
J
50
65
85(74-90)
135
22.0
27
2400
14D101K
J
60
85
100(90-110)
165
28.0
33
2000
14D121K
J
75
100
120(108-132)
200
32.0
40
1700
14D151K
J
95
125
150(135-165)
250
40.0
53
1300
14D181K
J
115
150
180(162-198)
300
50.0
60
1100
14D201K
J
130
170
200(185-225)
340
57.0
70
1000
14D221K
J
140
180
220(198-242)
360
60.0
78
900
14D241K
J
150
200
240(216-264)
395
63.0
84
830
14D271K
J
175
225
270(243-297)
455
70.0
99
740
14D301K
J
190
250
300(270-330)
500
77.0
108
670
14D331K
J
210
275
330(297-363)
550
85.0
115
610
14D361K
J
230
300
360(324-396)
595
93.0
130
560
14D391K
J
250
320
390(351-429)
650
100
140
14D431K
J
275
350
430(387-473)
710
115
155
460
14D471K
J
300
385
470(426-517)
775
125
175
430
14D511K
J
320
415
510(459-561)
845
125
180
390
14D561K
J
350
460
560(504-616)
925
125
185
360
14D621K
J
385
505
620(558-682)
1025
125
190
320
14D681K
J
420
560
680(612-748)
1120
130
200
290
14D751K
J
460
615
750(675-825)
1240
143
210
270
14D781K
J
485
640
780(702-858)
1290
148
220
260
14D821K
J
510
670
820(738-902)
1355
157
235
240
14D911K
J
550
745
910(819-1001)
1500
175
255
220
14D102K
J
625
825
1000(900-1100)
1650
190
280
200
10
50
1000
4500
2000
6000
0.1
0.6
5100
510
14D SERIES
Part NumberΦ
14.0mm
Standard
Maximum
Varistor
Clamping
Maximum peak
Maximum peak
Rated
Typical
allowable
voltage
voltage
current
current
power
capacitance
(Max.)
(8/20μs)
8/20μs)
voltage
High
AC.rms
DC
V1.0mA
VC
IP
Standar
High
Standar
High surge
surge
(V)
(V)
(V)
(V)
(A)
d
surge
d(J)
(J)
(A)
(A)
213
310
213
310
250
335
14D112K
J
680
895
1100(990-1210)
1815
14D122K
J
700
990
1200(1080-1320)
1880
14D182K
J
1100
1465
1800(1620-1980)
2970
50
4500
6000
5000
(Reference)
(W)
@1KHz(pf)
180
0.6
150
130
很抱歉,暂时无法提供与“14D821K”相匹配的价格&库存,您可以联系我们找货
