Shenzhen Tuofeng Semiconductor Technology Co., Ltd
N -CHANNEL ENHANCEMENT MODE POWER MOSFET
80N03B
Description
D
The 80N03B TO-251/TO-252 uses advanced trench
technology and design to provide excellent RDS(ON) with low
G
gate charge. It can be used in a wide variety of applications .
S
Schematic diagram
General Features
RDS(on) typ
VDSS
ID
3.6 mΩ@10V
30V
80A
4.8 mΩ@4.5V
80N03B
80N03B
TFXXXYY
TFXXXYY
● High density cell design for ultra low Rdson
● Fully characterized avalanche voltage and current
Marking and pin Assignment
● Excellent package for good heat dissipation
Application
● Power switching application
● Hard switched and high frequency circuits
● Uninterruptible power supply
TO-251
TO-252
Absolute Maximum Ratings (TA=25℃
℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
30
V
Gate-Source Voltage
VGS
±20
V
ID
80
A
IDM
200
A
PD
55
W
TJ,TSTG
-55 To 150
RθJA
1.5
℃/W
Drain Current-Continuous
Drain Current-Pulsed
(Note 1)
Maximum Power Dissipation
Operating Junction and Storage Temperature Range
Thermal Characteristic
Thermal Resistance,Junction-to-Ambient
(Note 2)
Electrical Characteristics (TA=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250µA
30
32
V
Zero Gate Voltage Drain Current
IDSS
VDS =28V, V GS=0V
500
nA
Off Characteristics
www.sztuofeng.com
1
Feb 2021 V1.0
80N03B
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
1
RDS(ON)
1.3
3.6
4.8
2.0
5.5
6.5
V
Drain-Source On-State Resistance
VDS=VGS,ID=250µA
VGS=10V, ID=30 A
VGS=4.5V, ID=20A
VDS=5V,ID=20A
Gate-Body Leakage Current
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
gFS
15
mΩ
S
(Note4)
Input Capacitance
Clss
2016
PF
Output Capacitance
Coss
251
PF
Crss
230
PF
Turn-on Delay Time
td(on)
nS
Turn-on Rise Time
tr
VDD=10V,I D=30A
15
nS
td(off)
VGS=10V,RG=2.7Ω
60
nS
10
nS
60.5
nC
8.1
nC
7.8
nC
0.90
1.2
V
80
A
Reverse Transfer Capacitance
Switching Characteristics
VDS=15V,V GS=0V,
F=1.0MHz
(Note 4)
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=10V,ID=30A,
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
Diode Forward Current
(Note 2)
VSD
VGS=0V,IS=30A
IS
Notes:
1.
2.
3.
4.
Repetitive Rating: Pulse width limited by maximum junction temperature.
Surface Mounted on FR4 Board, t ≤ 10 sec.
Pulse Test: Pulse Width ≤ 300µs, Duty Cycle ≤ 2%.
Guaranteed by design, not subject to production
www.sztuofeng.com
2
Feb 2021 V1.0
80N03B
Test Circuit
1) EAS Test Circuits
2) Gate Charge Test Circuit:
3) Switch Time Test Circuit:
www.sztuofeng.com
3
Feb 2021 V1.0
80N03B
ID- Drain Current (A)
Normalized On-Resistance
Typical Electrical and Thermal Characteristics (Curves)
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance Normalized
Vsd Source-Drain Voltage (V)
Figure 3 Rdson- Drain Current
www.sztuofeng.com
Figure 6 Source- Drain Diode Forward
4
Feb 2021 V1.0
Normalized BVdss
C Capacitance (pF)
80N03B
Figure 7 Capacitance vs Vds
Figure 9 BVDSS vs Junction Temperature
Figure 8 Safe Operation Area
Figure 10 VGS(th) vs Junction Temperature
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
www.sztuofeng.com
5
Feb 2021 V1.0
80N03B
Package Information
TO-252-2L
E
A
E1
c2
L4
H
D
D1
L3
b3
c
b
e
SEE VIEW A
GAUGE PLANE
SEATING PLANE
0.25
A1
L
S
Y
M
B
O
L
A
VIEW A
TO-252-3
RECOMMENDED LAND PATTERN
MILLIMETERS
INCHES
MIN.
MAX.
MIN.
MAX.
2.18
2.39
0.086
0.094
0.005
0.13
A1
b
0.50
0.89
0.020
0.035
b3
4.95
5.46
0.195
0.215
0.024
c
0.46
0.61
0.018
c2
0.46
0.89
0.018
0.035
D
5.33
6.22
0.210
0.245
D1
4.57
6.00
0.180
E
6.35
6.73
0.250
0.236
0.265
E1
3.81
6.00
0.150
0.236
e
2.29 BSC
9.40
10.41
0.370
0.410
L
0.90
1.78
0.035
0.070
L3
0.89
2.03
0.035
0.080
www.sztuofeng.com
0.040
1.02
0°
6.8 MIN.
6.6
3 MIN.
0.090 BSC
H
L4
6.25 MIN.
8°
0°
8°
6
2.286
1.5 MIN.
4.572
UNIT: mm
Feb 2021 V1.0
80N03B
TO-251S Package Information
Symbol
A
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
2.250
2.350
0.089
0.093
A1
1.150
1.250
0.045
0.049
B
10.200
10.800
0.402
0.425
b
0.550
0.650
0.022
0.026
b1
0.750
0.850
0.030
0.033
c
0.480
0.540
0.019
0.021
c1
0.480
0.540
0.019
0.021
D
6.400
6.600
0.252
0.260
D1
5.250
5.350
0.207
0.211
E
5.400
5.600
0.213
0.220
e1
2.300 TYP
0.091 TYP
e2
2.300 TYP
0.091 TYP
L
www.sztuofeng.com
3.300
3.700
7
0.130
0.146
Feb 2021 V1.0
很抱歉,暂时无法提供与“TF80N03B”相匹配的价格&库存,您可以联系我们找货
