PTD7 N65
65 0V/7 A
N-Channel A dv anced Power MOSFET
Features
RDS(on) (Typical 1.0 Ω )@VGS=10V
Improved dv/dt Capability, High Ruggedness
100% Avalanche Tested
Maximum Junction Temperature Range (150°C)
TO‐252
Absolute Maximum Ratings
Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the
Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may
affect device reliability.
Symbol
Parameter
Rating
Unit
Common Ratings (T J =25°C Unless Otherwise Noted)
VGS
Gate-Source Voltage
±30
V
V(BR)DSS
Drain-Source Breakdown Voltage
650
V
TJ
-50 to 150
°C
TSTG
Storage Temperature Range
--50 to 150
°C
IS
Diode Continuous Forward Current
7
A
28
A
7
A
90
W
385
mJ
1.39
°C/W
62
°C/W
Mounted on Large Heat Sink (TJ =25°C Unless Otherwise Noted)
IDM
Pulse Drain Current Tested (Sillicon Limit)
ID
Continuous Drain current@VGS=10 V
PD
Maximum Power Dissipation
EAS
Sing Pulsed Avalanche Energy
R JC
Thermal Resistance Junction−to−Case
R JA
Thermal Resistance Junction−to−Ambient
(Note1)
TC =25°C
(Note2)
Note :
1. Repetitive Rating:Pulse width limited by maximum junction temperature.
2. IL=15.7mH,IAS=7 A,VDD=50V,RG=25 Ω,Tj=25 °C
- 1-
2018-8-22
PTD7 N65
65 0V/7 A
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
V(BR)DSS
VGS=0V ID=250μA
650
V
IDSS
Zero Gate Voltage Drain current(Tc=25℃)
VDS=650V,VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±30V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=250μA
2
3
4
V
RDS(ON)
Drain-Source On-State Resistance note A
VGS=10V,ID=3.5A
1.0
1.3
Ω
930
pF
100
pF
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
note B
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
4.5
pF
Qg
Total Gate Charge
16
nC
Qgs
Gate-Source Charge
4
nC
Qgd
Gate-Drain Charge
3.6
nC
26
nS
VDS=25 V,VGS=0V,
f=1MHz
VDS=520V,ID=7A
Switching Characteristics
VGS=10V
note B
t d(on)
Turn-on Delay Time
tr
Turn-on Rise Time
ID=7A,
17
nS
t d(off)
Turn-Off Delay Time
RG=25Ω
57
nS
tf
Turn-Off Fall Time
23
nS
1.4
V
VDS= 300V
VGS=10V
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
VSD
Forward on voltage
IS= 5 A,VGS=0V
0.85
Note:
A: Pulse Test: pulse width ≤ 300 us, duty cycle ≤ 2%
B:Guranteed by design, not subject to production testing.
- 2-
2018-8-22
PTD7 N65
65 0V/7 A
Typical characteristic curve:
- 3-
2018-8-22
PTD7 N65
65 0V/7 A
- 4-
2018-8-22
PTD7 N65
65 0V/7 A
Test Circuit and Waveform
Gate Charge Test Circuit and Waveform
Switching time test circuit and waveform
Reverse Recovery Test Circuit and Waveform
Avalanche Test Circuit and Waveform
5 / 10
PowerCore 5 /
- 5-
2018-8-22
2017-8-22
很抱歉,暂时无法提供与“PTD7N65”相匹配的价格&库存,您可以联系我们找货
