TL431L-1%
GOFORD
FEATURES
Programmable Output Voltage to 40V
Low Dynamic Output Impedance 0.27Ω (Typ)
SinkCurrentCapabilityof0.1mAto100mA
EquivalentFull-RangetemperatureCoefficientof50ppm/℃
Temperature Compensated for Operation ov
er Full Rated Operating Temperature
Range
LowOutputNoiseVoltage
FastTurnonResponse
TO-92,SOP-8,SOT-89orSOT-23-3packages
DESCRIPTION
The TL431 is a three-terminal adjustable regulator series with a guaraneed thermal stability
over applicable temperature ranges. The output voltage may be set to any value between
Vref (approximately 2.5 volts) and 40 volts with two external resistors. These devices have
a typical dynamic output impedance of 0.2Ω. Activeoutputcircuitryprovidesa
verysharpturnoncharacteristic,makingthesedevicesexcellentreplacement
forzenerdiodesinmanyapplications.
TheTL431ischaracterizedforoperationfrom-0℃ to+70℃.
Pin Configuration
HTTP://www.gofordsemi.com TEL:0755-29961262 FAX:0755-29961466
Page 1
TL431L-1%
GOFORD
TO-92 Package Information
Symbol
A
B
C
D
E
G
H
J
Dimensions in Millimeters
MIN.
NOM.
MAX.
4.60
4.60
3.55
2.55
1.25
1.27
14.30
0.38
All Dimensions in mm
-4.62
3.60
2.60
1.30
1.30
14.32
4.59
4.58
3.50
2.50
-1.24
14.28
Page 2
TL431L-1%
GOFORD
Symbol Diagram and Block Diagram
Symbol Diagram
Block Diagram
Absolute Maximum Ratings (Operating temperature range applies unless otherwise
specified)
Characteristic
Symbol
Value
Unit
Cathode Voltage
VKA
40
V
Continuous Cathode Current Range
IK
-100 ~ 150
mA
Reference Input Current Range
IREF
0.05 ~ 10
mA
Power Dissipatin at 25℃:
PD
TO-92package(R⊙JA=178℃/W)
SOT-23-3Package(R
625℃/W)
⊙J
A=
Junction Temperature Range
TJ
Operating Temperature Range
Tg
0.7
0.2
0 ~ 150
0 ~ 70
W
W
Storage Temperature Range
-65 ~ 150
TSTG
Recommended Operating Conditions
Characteristic
Symbol
Cathode current
IK
Cathode voltage
VKA
Min
0.5
VREF
Typ
Max
100
40
Unit
mA
V
Page 3
TL431L-1%
GOFORD
Parameter Measurement Information
Electrical Characteristics
TA =25℃,VKA =VREF, IK = 10 mA unless otherwise noted
Parameter
Symbol Test Conditions
Reference Input Voltage
VREF
IK=10mA,VKA=VREF
△VREF
Deviation of Reference
Input Voltage over Full
Temperature Range
Ratio of Chane in
△VREF
△VKA
to the Change in Cathode
Voltage
IREF
Current over Full
Temperature Range
Minimum Cathode
Current for Regulation
Off-State Cathode
Current
Dynamic Impedance
I i(DEV)
Min.
2.47
Tmin≤Ta ≤Tmax
Max.
2.52
Unit
V
3
17
mV
△VKA=10V to VREF
△VKA=36V to 10V
-0.4
-0.4
0.0
0.0
2.7
2.0
mV/V
R1=10KΩ, R2=∞
1.8
4
μA
R1=10KΩ, R2=∞
0.4
1.2
μA
0.25
0.5
mA
0.17
0.9
μA
0.27
0.5
Ω
IKmin
IK off
Typ.
2.495
VKA= 40V VREF= 0
│ZKA│ IK=10 mA to 100 mA,
f ≤1.0kHz
Page 4
很抱歉,暂时无法提供与“TL431L-1%”相匹配的价格&库存,您可以联系我们找货
