TW0115SR-Y
N-Channel Enhancement Mode Power MOSFET
Features
General Description
VDS = 100V,
• DC-DC Converters
ID = 15.2A
• DC-AC Inverters
RDS(ON) @VGS= 10V, TYP 68mΩ
• Motor Drives
RDS(ON) @VGS= 4.5V, TYP 75mΩ
Pin Configurations
TO252
Absolute Maximum Ratings @TA=25℃ unless otherwise noted
Parameter
Symbol
Ratings
Unit
Drain-Source Voltage
VDSS
100
V
Gate-Source Voltage
VGSS
±20
V
Drain Current (Continuous) *AC
Drain Current (Pulse)
TC=25°C
15.2
ID
TC=100°C
*B
TC=25°C
Power Dissipation
Operating Temperature/ Storage Temperature
A
9.6
IDM
50
A
PD
42
W
TJ/TSTG
-55~150
Symbol
Maximum
Unit
Thermal Resistance Ratings
Parameter
Maximum Junction-to-Ambient *AC
t≤10s
RthJA
60
Maximum Junction-to-Case (Drain)
Steady State
RthJC
3
www.tw-gmc.com
1
°C/W
TW0115SR-Y
Electrical Characteristics @TA=25℃ unless otherwise noted
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
Static
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID= 250μA
100
V
Zero Gate Voltage Drain Current
IDSS
VDS = 80V, VGS = 0V
1
μA
VGS = VDS, IDS= 250μA
1
1.7
2.5
V
VGS= 20V, VDS=0V
100
nA
RDS(on)
VGS = 10V, ID = 5A
68
90
mΩ
RDS(on)
VGS = 4.5V, ID = 3A
75
100
mΩ
ISD= 1A , VGS=0V
0.74
1.2
V
TC =25°C
15.2
A
19.7
nC
3.5
nC
4.2
nC
8
ns
11
ns
17
ns
Gate Threshold Voltage
VGS(TH)
Gate Leakage Current
IGSS
Drain-Source On-state Resistance
Diode Forward Voltage
VSD
Diode Forward Current *AC
IS
Switching
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td ( on )
VGS=10V, VDS=50V, ID=6.6A
VGEN=10V, VDD=50V,
Turn-on Rise Time
tr
Turn-off Delay Time
td( off )
Turn-Off Fall Time
tf
6
ns
Input Capacitance
Ciss
855
pF
Output Capacitance
Coss
84
pF
Reverse Transfer Capacitance
Crss
41
pF
RL=9.6Ω,RG=1Ω,
ID=5.2A
Dynamic
VDS=50V,VGS=0V, f=1.0MHz
2
A: The value of RθJA is measured with the device mounted on 1in FR-4 board with 2oz. Copper, in a still air environment with TA=25°C. The value in any given
application depends on the user's specific board design.
B: Repetitive rating, pulse width limited by junction temperature.
C: The current rating is based on the t≤ 10s junction to ambient thermal resistance rating.
www.tw-gmc.com
2
TW0115SR-Y
Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
www.tw-gmc.com
3
TW0115SR-Y
www.tw-gmc.com
4
TW0115SR-Y
www.tw-gmc.com
5
TW0115SR-Y
Package Information
www.tw-gmc.com
6
很抱歉,暂时无法提供与“TW0115SR-Y”相匹配的价格&库存,您可以联系我们找货
