MBR2060GCT&MBR2060DCT
20.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /10seconds, 0.25"(6.35mm)from case.
TO-252
MBR2060GCT
TO-251
MBR2060DCT
MECHANICAL DATA
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Mounting position: any
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
MAXIMUM RATINGS (TC=25℃ unless otherwise noted)
Parameter
Symbol
Units
Maximum Recurrent Peak Reverse Voltage
VRRM
VRMS
VDC
60
V
42
V
60
V
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
Per Leg
Peak Forward Surge Current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method)
Operation Junction Temperature and Storage Temperature
A
20.0
IFSM
150.0
A
CJ
TJ, TSTG
300
pF
-55 to +150
°C
Per Leg
Typical Junction Capacitance (Note 1)
10.0
IF(AV)
Total device
at TC =100°C
ELECTRICAL CHARACTERISTICS - (Per Leg) (TC=25℃ unless otherwise noted)
Parameter
Symbol
Test conditions
TJ=25℃
Forward voltage drop
VF
TJ=125℃
Reverse leakage current
IR
TJ=25℃
TJ=125℃
IF=3A
IF=10A
IF=3A
IF=10A
VR=60V
VR=60V
Typ
Max
0.49
0.66
0.75
0.42
0.58
0.67
0.1
10
Units
V
mA
THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted)
Parameter
Symbol
MBR2060GCT
MBR2060DCT
Units
Typical Thermal Resistance (Note 2)
R(JC)
6.5
6.5
°C /W
Notes:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Thermal Resistance from Junction to Case
1
RATING AND CHARACTERISTIC CURVES
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
20.0
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
100
10.0
Single Phase Half Wave
60Hz Resistive or
inductive Load
100
150
200
TJ=125℃
10
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
1
0.1
CASE TEMPERTURE,(℃)
0.5
0.3
0.1
0.7
INSTANEOUS FORWARD
VOLTAGE,(V)
0.9
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
200
150
8.3ms Single Half
Sine-Wave (JEDEC
Method)
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
100
100
50
10
10
TJ=125℃
1
0.1
0.01
0.001
TJ=25℃
12
24
36
48
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(V)
NUMBER OF CYCLES AT 60Hz
2
60
PACKAGE OUTLINE DIMENSIONS
TO-252
L
B
C
I
2
N
A
B
H
C
D
A
E
F
3
PIN 1
G
D
G
F
Dim
H
J
E
M
K
I
J
K
a
L
P
P
M
N
a
TO-252
Min
Max
.230(5.85) .246(6.25)
.250(6.35) .264(6.75)
.207(5.27) .218(5.54)
.037(0.93) .045(1.14)
.106(2.70) .138(3.50)
.028(0.72) .033(0.84)
.024(0.60) .041(1.05)
.028(0.72) .043(1.10)
.085(2.15) .096(2.45)
.037(0.95) .047(1.20)
.018(0.45) .026(0.65)
.018(0.45) .024(0.60)
.081(2.05) .094(2.40)
.000(0.00) .006(0.15)
-.008(0.20)
0°
10°
Dimensions in inches and (millimeters)
TO-251
L
B
C
Dim
I
A
B
N
H
PIN 1 2
C
D
A
E
3
F
D
J
H
I
E
J
F
P
K
K
L
N
P
TO-251
Min
Max
.250(6.35) .266(6.75)
.173(4.40) .205(5.20)
.028(0.70) .043(1.10)
-.008(0.20)
3
很抱歉,暂时无法提供与“MBR2060GCT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.76656
- 10+1.40368
- 30+1.24816
- 100+1.05408
- 500+0.96768
- 1000+0.91584
