HER303
HER303
    HL(豪林)
    DO-201AD
    二极管配置:-;直流反向耐压(Vr):200V;平均整流电流(Io):3A;正向压降(Vf):1V@3A;反向电流(Ir):10uA@200V;
HER303 数据手册
HER301 THRU HER308 Voltage Range 50 to 1000 Volts Current 3.0 Amperes 3.0 AMPS. HIGH EFFICIENT RECTIFIERS DO-201AD Features *Low forward voltage drop *High current capability *High reliability *High surge current capability 1.0(25.4) MIN. .220(5.6) .197(5.0) DIA. Mechanical Data *Cases:Molded plastic *Epoxy:UL 94V-O rate flame retardant .375(9.5) .335(8.5) *Lead:Axial leads,solderable per MIL- STD-202,Method 208 guaranteed *Polarity:Color band denotes cathode end *High temperature soldering guaranteed: 1.0(25.4) MIN. 2500C/10 seconds/.375",(9.5mm) lead lengths at 5 lbs.,(2.3kg) tension *Weight:1.2 grams .052(1.3) .048(1.2) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS o Rating at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20% HER301 HER302 HER303 HER304 HER305 HER306 HER307 HER308 Type Number Maximum Repetitive Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage VRRM VRMS 50 100 200 300 400 600 800 1000 V 35 70 140 210 280 420 560 700 V VDC 50 100 200 300 400 600 800 1000 V Maximum Average Forward Rectified oCurrent .375"(9.5mm) Lead Length @TA = 55 C IF(AV) 3.0 Peak Forward Surge Current, 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) IFSM 150 Maximum Instantaneous Forward Voltage @3.0A VF 1.3 1.0 A A 1.7 o Maximun DC Reverse Current @ TA = 25 C o at Rated DC Blocking Voltage @ TA = 100 C UNITS uA uA 10.0 200 IR V TRR 50 75 nS Typical Junction Capacitance (Note 2) CJ 80 50 pF Operating Temperature Range TJ -55 to+125 o TSTG -55 to+150 o Maximum Reverse Recovery Time (Note 1) Storage Temperature Range NOTES: 1. Reverse Recovery Test Conditions: IF=0.5A,IR=1.0A,IRR=0.25A 2.Measured at 1 MHz and Applied Reverse Voltage of 4.0 V D.C. C C
HER303 价格&库存
很抱歉,暂时无法提供与“HER303”相匹配的价格&库存,您可以联系我们找货
