SF31 THRU SF38
3.0AMPS. SUPER FAST RECTIFIERS
DO-27/DO-201AD
FEATURE
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge capability
.High temperature soldering guaranteed
260°C /10sec/ 0.375" lead length at 5 lbs tension
.Super fast recovery time for high efficiency.
0.96(24.4)
MIN.
.220(5.6)
.187(5.0)
.375(9.5)
.335(8.5)
MECHANICAL DATA
.Terminal: Plated axial leads solderable per
MIL-STD 202E, method 208C
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.Polarity: color band denotes cathode
.Mounting position: any
DIA.
0.96(24.4)
MIN.
.051(1.3)
.043(1.1)
DIA.
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
.375"(9.5mm) lead length at TA =55°C
SYM
BOL
SF
31
SF
32
SF
33
SF
34
SF
35
SF
36
SF
37
SF
38
units
VRRM
VRMS
VDC
50
100
150
200
300
400
500
600
V
35
70
105
140
210
280
350
420
V
50
100
150
200
300
400
500
600
V
IF(AV)
3.0
A
IFSM
90.0
A
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rated load (JEDEC
method)
Maximum Instantaneous forward Voltage at
3.0A DC
Maximum DC Reverse Current
at rated DC blocking voltage
@TA =25°C
@TA =100°C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance (Note 3)
Storage Temperature
Operation JunctionTemperature
VF
0.95
1.3
1.7
5.0
IR
µA
100.0
trr
CJ
R(JA)
TSTG
TJ
35
100
nS
80
pF
50
°C/W
-55 to +150
°C
-55 to +150
°C
Note:
1. Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
3. Thermal Resistance from Junction to Ambient at 0.375"(9.5mm)lead length, vertical P.C.Board Mounted.
- 419 -
V
RATING AND CHARACTERISTIC CURVES (SF31 THRU SF38)
Single Phase Half
Wave 60Hz
Resistive or
inductive Load
50
V20
0V
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
V
00
0-4
V
00
-6
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
120
8
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
8.3ms Single Half
Sine-Wave (JEDEC
Method)
INSTANEOUS REVERSE
CURRENT,(μA)
PEAK FORWARD SURGE
CURRENT,(A)
4
AMBIENT TEMPERTURE,(℃)
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERSITIC
50 Ω
NONINDUCTIVE
25Vdc
(approx)
10 Ω
NONINDUCTIVE
PULSE
GENERATOR
(NOTE 2)
1Ω
(NOTE 1)
NON- OSCILOSCOPE
INDUCTIVE
NOTES:1. Rise Time=7ns max, Input
Impedance= 1 megohm.22pF.
2. Rise Time=10ns max,
Souce Impedance= 50 ohms.
- 420 -
很抱歉,暂时无法提供与“SF34”相匹配的价格&库存,您可以联系我们找货
