MUR405
MUR4100E
THRU
4.0 AMP SUPER FAST RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
4.0 Amperes
FEATURES
* Low forward voltage drop
* High current capability
* High reliability
* High surge current capability
* Good for switching mode application
DO-27
.220(5.6)
.197(5.0)
DIA.
1.0(25.4)
MIN.
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Lead: Axial leads, solderable per MIL-STD-202,
method 208 guranteed
* Polarity: Color band denotes cathode end
* Mounting position: Any
.375(9.5)
.285(7.2)
1.0(25.4)
MIN.
.052(1.3)
.048(1.2)
DIA.
* Weight: 1.10 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
MUR405 MUR410 MUR420 MUR430 MUR440 MUR460 MUR480 MUR4100EUNITS
50
35
50
100
70
100
200
140
200
300
210
300
.375"(9.5mm) Lead Length at Ta=50 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
600
420
600
800
560
800
150
1.3
5.0
1.0
45
200
60
-65
75
+150
1000
700
1000
V
V
V
A
4.0
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Operating and Storage Temperature Range TJ, TSTG
400
280
400
1.85
75
A
V
A
A
nS
pF
C
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (MUR405 THRU MUR4100E)
FIG.2-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.1-TYPICAL FORWARD
CHARACTERISTICS
AVERAGE FORWARD CURRENT,(A)
1.0
.1
3.0
2.5
2.0
Single Phase
1.5
Half Wave 60Hz
Resistive Or Inductive Load
1.0
0.375"(9.5mm) Lead Length
0.5
50
75
100
125
150
175
AMBIENT TEMPERATURE ( C)
Tj=25 C
Pulse Width 300us
1% Duty Cycle
.01
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.6
.8
1.0
1.2
1.4
1.6
1.8
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
25Vdc
(approx.)
D.U.T.
PULSE
GENERATOR
(NOTE 2)
1W
NONINDUCTIVE
150
PEAK FORWARD SURGE CURRENT,(A)
.001
.4
120
90
8.3ms Single Half
Tj=25 C
Sine Wave
60
JEDEC method
30
OSCILLISCOPE
(NOTE 1)
5
50
10
100
NUMBER OF CYCLES AT 60Hz
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
FIG.5-TYPICAL JUNCTION CAPACITANCE
175
trr
+0.5A
-0.25A
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
10
150
125
100
75
50
25
-1.0A
1cm
.01
.05
.1
.5
1
5
10
50
100
SET TIME BASE FOR
50 / 10ns / cm
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“MUR460-B”相匹配的价格&库存,您可以联系我们找货
