DSS22 THRU DSS210
HD FL 45
SOD-1 23FL Plastic-Encapsulate Diodes
Features
●Io
2A
SOD-1 23FL
●VRRM
20V-100V
●High surge current capability
● Polarity: Color band denotes cathode
Applications
● Rectifier
Marking
● DSS22-DSS210 : S22-S210
Item
Symbol Unit
Repetitive Peak Reverse Voltage
VRRM
Maximum RMS Voltage
DSS
Test Conditions
22
23
24
25
26
28
210
V
40
50
60
80
100
V
40
50
60
80
100
Average Forward Current
IF(AV)
A
60HZ Half-sine wave, Resistance
load, TL(Fig.1)
2.0
Surge(Non-repetitive)Forward
Current
IFSM
A
60Hz Half-sine wave ,1 cycle ,
Ta =25℃
40
TJ
TSTG
Junction Temperature
Storage Temperature
-55~+125
-55~+150
-55 ~ +150
Electrical Characteristics (Ta=25℃Unless otherwise specified)
Item
Peak Forward Voltage
Peak Reverse Current
Thermal
Resistance(Typical)
Symbol Unit
VF
IRRM1
IRRM2
RθJ-A
RθJ-L
Test Condition
IF =2.0A
V
mA
W
VRM =VRRM
22
23
0.55
Ta =25℃
Ta =100℃
24
DSS
25
26
28
0.70
210
0.85
0.5
0.1
10
5.0
Between junction and ambient
751)
Between junction and terminal
171)
Notes:
Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper
pad areas
High Diode Semiconductor
1
Typical Characteristics
IO(A)
FIG.1: FORWARD CURRENT DERATING CURVE
FIG.2: MAXIMUM NON-REPETITIVE FORWARD URGE CURRENT
2.5
DSS22-DSS24
DSS25-DSS210
2.0
1.5
1.0
0.5
Resistive or Inductive Load
P.C.B. Mounted on 0.2"×0.2"
(5.0mm×5.0mm)Copper Pad Areas
50
25
100
125
150
TL(℃)
FIG.4:TYPICAL REVERSE CHARACTERISTICS
IR(mA)
IF(A)
FIG.3: TYPICAL FORWARD CHARACTERISTICS
100
TJ=25℃
Pulse width=300us
1% Duty Cycle
100
DSS22 -DSS26
DSS28 -DSS210
10
10
Tj=125℃
1.0
1.0
Tj=75℃
0.1
DSS22-DSS24
DSS25-DSS26
DSS28-DSS210
0.1
0.01
Tj=25℃
0.001
0.01
0.4
0.6
0.8
1.0
1.2
1.4
VF(V)
60
80
100
Voltage(%)
2
SOD-1 23FL
1.8± 0.1
1.0 ±0.15
Cathode Band
Top View
1.3± 0.1
0.12-0.20
2.8 ±0.15
0.8±0.1
3.7 ±0.15
Dimensions in millimeters
SOD-1 23FL
1.4
2.85
1.2
JSHD
JSHD
3
Reel Taping Specifications For Surface Mount Devices-SOD-123FL
SOD-123FL
50
1.969
4
很抱歉,暂时无法提供与“DSS24”相匹配的价格&库存,您可以联系我们找货
