ES07J
ES07J
    PINGWEI(平伟)
    SOD-123FL-2
ES07J 数据手册
ES07A THRU ES07J 1.0AMP. SURFACE MOUNT SUPER FAST RECTIFIERS SOD-123FL FEATURES .Glass passivated device .Ideal for surface mouted applications .Low reverse leakage .Metallurgically bonded construction .Superfast recovery time for high efficiency .High temperature soldering guaranteed: 250℃/10 seconds at terminals. MECHANICAL DATA .Case: Molded plastic .Epoxy: UL94V-0 rate flame retardant .Lead: MIL-STD- 202E, Method 208 guaranteed .Polarity:Color band denotes cathode end .Packaging:12mm tape per EIA STD RS-481 .Mounting position: Any Dimensions in millimeters MAXIMUM RATINGS AND ELECTRONICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%. SYM BOL marking Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward rectified Current at TA =65°C (Note 1) VRRM VRMS VDC ES07A ES07B ES07D ES07G ES07J EA EB ED EG EJ 50 100 200 400 600 V 35 70 140 280 420 V 50 100 200 400 600 V units IF(AV) 1.0 A IFSM 25 A Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rate load (JEDEC method) Maximum Instantaneous forward Voltage at 1.0 A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =125°C Maximum Reverse Recovery Time (Note 2) Typical Junction Capacitance (Note 3) Typical thermal resistance (Note 4) Storage Temperature Range Operation Temperature Range VF 0.95 1.3 1.7 5.0 IR µA 100.0 trr CJ R(JA) TSTG TJ 35 Note: 1. Averaged over any 20 ms period. 2.Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 3. Measured at 1MHz and applied reverse voltage of 4.0 volts d.c. 4. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas - 447 - nS 10 20 V pF 180 °C /W -55 to +150 °C -55 to +150 °C RATING AND CHARACTERISTIC CURVES (ES07A THRU ES07J) Single Phase Half Wave 60Hz Resistive or inductive Load 50 V20 0V FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE TJ=25℃ Pulse Width=300μs 1% Duty Cycle 1.0 4 8 2.2 AMBIENT TEMPERTURE,(℃) INSTANEOUS FORWARD VOLTAGE,(V) FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT FIG.4-TYPICAL REVERSE CHARACTERISTICS INSTANEOUS REVERSE CURRENT,(μA) PEAK FORWARD SURGE CURRENT,(A) 0V 60 0V 40 8.3ms Single Half Sine-Wave (JEDEC Method) TJ=25℃ PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz FIG.5-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERSITIC 50 Ω NONINDUCTIVE (+) 25Vdc (approx) (-) 10 Ω NONINDUCTIVE (+) PULSE GENERATOR (NOTE 2) 1Ω (NOTE 1) NON- OSCILOSCOPE INDUCTIVE (-) NOTES:1. Rise Time=7ns max, Input Impedance= 1 megohm.22pF. 2. Rise Time=10ns max, Souce Impedance= 50 ohms. - 448 -
ES07J 价格&库存
很抱歉,暂时无法提供与“ES07J”相匹配的价格&库存,您可以联系我们找货
