Shenzhen Orient Components Co ., Ltd
OR-6N135/6N136
ORIENT
Photo coupler
Product Data Sheet
Part Number:
OR-6N135&6N136
Customer:
Date:
SHENZHEN ORIENT COMPONENTS CO ., LTD
Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD
TEL:0755-29681816
FAX:0755-29681200
www.orient-opto.com
Copyright© 2020 Orient .All rights Reserved
1
V8
OR-6N135/6N136
1. Features
(1)
High speed - 1MBd model
(2)
Adapted to the dual-in-line, lead spacing width, surface installation.
(3)
Store output.
(4)
Safety approval
UL
approved (No.E323844)
VDE
approved (No.40029733)
CQC approved (No.CQC19001231254 )
(5)
In compliance with RoHS, REACH standards
(6)
MSL Class Ⅰ
2. Instructions
OR-6N135/6N136 consists of highly efficient AlGaAs
light-emitting diodes and high-speed optical detectors. The design
provides good ac and dc isolation at the input and output ends of the
photoelectric coupler. Connections related to photo diode biasing can
improve the speed of conventional photo transistor couplers by reducing
the capacitance of the matrix collector. Internal shielding ensures high
transient immunity in general mode. Ensure the common-mode transient
immunity to 1 kv/μsec.
3. Application Range
(1) line receiver isolation
(2) A/ D, D/A converted digital signal isolation
(3) eliminate noise from the ground loop
(4) switching power supply
(5) alternative pulse transformers
(6) motor control system
(7) interface of microprocessor system, computer and peripheral equipment
4. Functional Diagram
Pin Configuration
1. No Connection
2. Anode
3. Cathode
4. No Connection
5. Gnd
6. Vout
7. VB
8. VCC
2
V8
OR-6N135/6N136
5. Absolute Maximum Ratings (Ta=25℃) *1
Parameter
Symbol
Rated Value
Unit
Average Forward Input Current
IF
25
mA
Reverse Input Voltage
VR
5
V
Power Dissipation
PI
45
mW
Output Collector Current
IO
8
mA
Output Collector Voltage
VO
V
PO
100
mW
Supply Voltage
VCC
30
V
Insulation Voltage
Viso
5000
Vrms
Working Temperature
Topr
-40 ~ + 110
Storage Temperature
Tstg
-55~ + 125
*2 Soldering Temperature
Tsol
260
Input
Output
Output Collector Power Dissipation
*1. Room temperature = 25 ℃. Exceeding the maximum absolute rating can permanently damage the device. Working
long hours at the maximum absolute rating can affect reliability.
*2. soldering time is 10 seconds
3
V8
OR-6N135/6N136
6. Electrical optical characteristics (at TA=25℃)
Parameter
Input
Symbol
Min
Typ
Max
Unit
Condition
Forward Voltage
VF
1.4
1.7
V
IF= 16mA
Reverse Voltage
VR
5
V
IR = 10μA
0.5
1
140
200
uA
0.01
1
uA
IF=0mA,Vo=open,
VCC=15V,TA=25℃
2
uA
IF=0mA,Vo=open,
VCC=15V
OR-6N135
7
50
OR-6N136
19
50
High Level Output Current
Output
Low Level Supply Current
High Level Supply Current
Current
Transfer
Ratio
Transfer
Characteris
tics
Logic Low
Output
Voltage
IOH
ICCL
ICCH
CTR
uA
VCC=5.5V,
VO=5.5V,
IF=0mA
VCC=15V,
VO=15V,
IF=0mA
IF=16mA,
Vo=open,
VCC=15 V
IF = 16mA ,
VO = 0.4V,
VCC=4.5V,
TA=25°C
OR-6N135
5
OR-6N136
15
IF = 16mA ,
VO = 0.5V,
VCC=4.5V
OR-6N135
0.18
0.4
IF = 16mA ,IO = 1.1mA,
VCC=4.5V, TA=25°C
OR-6N136
0.25
0.4
IF = 16mA ,IO = 3mA,
VCC=4.5V, TA=25°C
VOL
OR-6N135
0.5
OR-6N136
0.5
4
V
IF = 16mA ,IO =0.8mA,
VCC=4.5V
IF= 16mA ,IO=2.4mA,
VCC=4.5V
V8
OR-6N135/6N136
7. Switching Characteristics ( at TA=25℃ )
Parameter
Symbol
Min
Typ
Max
Unit
0.09
1.5
us
OR-6N136
0.1
0.8
us
OR-6N135
0.8
1.5
us
0.4
0.8
us
OR-6N135
Propagation delay time to
output Low level
output High level
Condition
RL=4.1kΩ
IF=16mA
tPHL
tPLH
OR-6N136
RL=1.9kΩ
IF=16mA
RL=4.1kΩ
IF=16mA
RL=1.9kΩ
IF=16mA
VCM=10Vp-p,
RL=4.1kΩ,
OR-6N135
Logic High Common Mode
Transient Immunity
|CMH|
1
10
IF=0mA
kV/μs
VCM=10Vp-p,
RL=1.9kΩ,
OR-6N136
IF=0mA
VCM=10Vp-p,
RL=4.1kΩ,
OR-6N135
Logic Low Common Mode
Transient Immunity)
|CML|
1
10
IF=0mA
kV/μs
VCM=10Vp-p,
RL=1.9kΩ,
OR-6N136
IF=0mA
Recommended temperature range (TA = 0 ℃ ~ 70 ℃), unless otherwise specified power supply for 5V.
Typical values of TA = 25 ℃.
5
V8
OR-6N135/6N136
8. Isolation characteristics ( at TA=25℃ )
Parameter
Symbol
Min
Typ
Max
Unit
Input-Output Insulation Leakage
Current
II-O
1
μA
Withstand Insulation Test
VISO
5000
VRMS
RI-O
5x1010
1012
Ω
Condition
45% RH,t=5s,VI-O=3kV DC,TA
Voltage
Input-Output Resistance
=25 C
RH ≤ 50%, t =1min,
TA=25℃
VI-O=5000V DC
9. Order Information
Part Number
OR-6N13XY-Z
Note
6N13X = Part Number (6N135 or 6N136)
Y = Lead form option (S, M or none)
Z = Tape and reel option ( TA,TA1 or none).
Option
Description
Packing quantity
None
Standard SMD Option
45 units per tube
M
Wide lead bend (0.4 inch spacing)
45 units per tube
TA
Surface mount lead form (low profile) + TA tape & reel option
1000 units per reel
TA1
Surface mount lead form (low profile) + TA1 tape & reel option
1000 units per reel
6
V8
OR-6N135/6N136
10. Naming Rule
NOTE:
1.
Manufacturer : ORIENT.
2.
Part Number : 6N135 or 6N136 .
3.
Shape Code
4.
Year Code
5.
Week Code
6.
Anode.
: '21' means '2021' and so on.
: 01 means the first week, 02 means the second week and so on.
7
V8
OR-6N135/6N136
11. Outer Dimension
(1)OR-6N13X
(2)OR-6N13XM
8
V8
OR-6N135/6N136
(3)OR-6N13XS
12. Recommended Foot Print Patterns (Mount Pad))
(unit:mm)
9
V8
OR-6N135/6N136
13. Taping Dimensions
(1)OR-6N13XS-TA
(2)OR-6N13XS-TA1
type
symbol
Dimensions: mm ( inches)
bandwidth
W
16±0.3(0.63)
pitch
P0
4±0.1(0.15)
F
7.5±0.1(0.295)
P2
2±0.1(0.079)
P1
12±0.1(0.472)
pitch
interval
Encapsulation
TA/TA1
type
Amount(pcs)
1000
10
V8
OR-6N135/6N136
14. Package Dimension
DIP Type
Packing Information
Packing type
Tube
Qty per Tube
45pcs
Small box (Inner) Dimension
525*128*60mm
Large box (Outer) Dimension
545*290*335mm
The Amount per Inner Box
2,250pcs
The Amount per Outer Box
22,500pcs
SOP Type
Packing Information
Packing type
Reel type
Tape Width
16mm
Qty per Reel
1,000pcs
Small box (inner) Dimension
345*345*58.5mm
620x360x360mm
Max qty per small box
2,000pcs
Max qty per large box
20,000pcs
(2)Packing Label Sample
Note:
1.
2.
Material Code :Product ID.
P/N :Contents with "Order
Information" in the specification.
3. Lot No. :Product data.
4. D/C :Product weeks.
5. Quantity :Packaging quantity.
11
V8
OR-6N135/6N136
15. Reliability Test
Reliability Testing
NO.
1
ITEMS
QTY.
(Pcs)
RSH
耐焊接热
22
Condition
260±5℃
Process
5s/3 次
Device
Standard
锡炉
JESD22-A106
高温烤箱
测试仪
JESD22-A103
低温箱
测试仪
JESD22-A119
168 hrs
2
HTSL
高温存储
77
125℃
500 hrs
1000 hrs
168 hrs
3
LTSL
低温存储
77
-40℃
500 hrs
1000 hrs
4
TC
温度循环
77
H:125℃ 15min
∫5min
L:-55℃ 15min
300
cycle
冷热冲击
机
JESD22-A104
5
TS
温度冲击
77
H:100℃ 5min
∫15s
L:-40℃ 5min
300
cycle
冷热冲击
机
JESD22-A106
JESD22-A108
168 hrs
6
HTOL
高温操作
77
100°C
IF=10mA
Vcc=5V
500 hrs
1000 hrs
高温烤箱
测试仪、
老化电路
板
ESD静电
测试仪
JESD22-A114
锡炉
JESD22-B102
恒温恒湿
机,测试
仪
JESD22-A101
压力锅
JESD22-A102
7
ESDHBM
人体模式
22
≥8KV 1Cycle
1次
8
SD
可焊性
22
Pb-free
245±5℃
5s/1次
9
HTHB
温湿寿命
试验
168 hrs
77
85℃,85%RH
IF=10mA,Vcc=5V
500 hrs
1000 hrs
10
Autoclave
压力锅
77
Ta=121
℃,100%RH,2atm
96hrs
12
V8
OR-6N135/6N136
16. Temperature Profile Of Soldering
(1) IR Reflow soldering (JEDEC-STD-020C compliant)
Note: one solder backflow is recommended under the conditions described below in the temperature and time
profile. Do not weld more than three times.
Profile item
Conditions
Preheat
150˚C
- Temperature Min (T Smin )
200˚C
- Temperature Max (T Smax )
90±30 sec
- Time (min to max) (ts)
Soldering zone
- Temperature (TL )
217˚C
- Time (t L )
60 sec
Peak Temperature
260˚C
Peak Temperature time
20 sec
Ramp-up rate
3˚C / sec max.
Ramp-down rate from peak temperature
3~6˚C / sec
Reflow times
≤3
13
V8
OR-6N135/6N136
(2) Wave soldering (JEDEC22A111 compliant)
One-time welding is recommended under the temperature condition.
Temperature
260+0/-5˚C
Time
10 sec
Preheat temperature
5 to 140˚C
30 to 80 sec
Preheat time
(3) Hand soldering by soldering iron
Single lead welding is allowed in each process and one-time welding is recommended.
Temperature
380+0/-5˚C
Time
3 sec max
14
V8
OR-6N135/6N136
17. Switching time test circuit
15
V8
OR-6N135/6N136
18. Characteristics Curve
16
V8
17
OR-6N135/6N136
V8
