HY1506D/U/V
N-Channel Enhancement Mode MOSFET
Features
Pin Description
60V/55A,
RDS(ON)=10.5 m(typ.) @ VGS=10V
Avalanche Rated
Reliable and Rugged
Lead Free and Green Devices Available
G
D
S
G
(RoHS Compliant)
G
TO-252-2L
D
S
D S
TO-251-3L
TO-251-3S
Applications
Power Management for Inverter Systems.
N-Channel MOSFET
Ordering and Marking Information
Package Code
D
HY1506
U
HY1506
V
HY1506
YYXXXJWW G YYXXXJWW G YYXXXJWW G
D : TO-252-2L
V : TO-251-3S
U : TO-251-3L
Date Code
YYXXX WW
Assembly Material
G : Lead Free Device
Note: HUAYI lead -free products contain molding compounds/die attach materials and 100% matte tin plate
Termination finish;which are fully compliant with RoHS. HUAYI lead -free products meet or exceed the leadFree requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature.
HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed
900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to
this pr-oduct and/or to this document at any time without notice.
www.hymexa.com
V1.1
1
HY1506D/U/V
Absolute Maximum Ratings
Symbol
Parameter
Unit
Rating
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
60
VGSS
Gate-Source Voltage
±25
Maximum Junction Temperature
175
°C
-55 to 175
°C
TC=25°C
55
A
TC=25°C
220**
A
TC=25°C
55
TC=100°C
38
TC=25°C
100
TC=100°C
50
TJ
TSTG
IS
Storage Temperature Range
Diode Continuous Forward Current
V
Mounted on Large Heat Sink
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
A
W
RJC
Thermal Resistance-Junction to Case
1.5
°C/W
RJA
Thermal Resistance-Junction to Ambient
110
°C/W
EAS
Drain-Source Avalanche Energy
L=0.5mH
200***
mJ
Note: * Repetitive rating ; pulse width limiited by junction temperature
** Drain current is limited by junction temperature
*** VD=48V
Electrical Characteristics
Symbol
Parameter
(TC = 25C Unless Otherwise Noted)
Test Conditions
HY1506
Min.
Typ.
Max.
60
65
1
30
Unit
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
IGSS
VGS=0V, IDS=250A
VDS=60V, VGS=0V
TJ=85°C
V
A
Gate Threshold Voltage
VDS=VGS, IDS=250A
1.0
1.6
3.0
V
Gate Leakage Current
VGS=±25V, VDS=0V
±100
nA
VGS=10V, IDS=28A
10.5
13.5
m
13.5
15
m
0.8
1.1
V
50
ns
74
nC
RDS(ON) * Drain-Source On-state Resistance
VGS=4.5V, I DS=28A
Diode Characteristics
VSD *
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=28A, VGS=0V
IDS=28A, dlSD/dt=100A/s
www.hymexa.com
V1.1
2
HY1506D/U/V
Electrical Characteristics (Cont.)
Symbol
Test Conditions
Parameter
HY1506
Min.
Typ.
Max.
1.2
3522
666
172
21
39
25
48
27
52
31
58
62
6
11
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(ON)
Turn-on Delay Time
Tr
Turn-on Rise Time
td(OFF)
Turn-off Delay Time
Tf
VGS=0V,VDS=0V,F=1MHz
VGS=0V,
VDS=25V,
Frequency=1.0MHz
VDD=30V, RG = 4 ,
IDS =28A, VGS =10V,
Turn-off Fall Time
pF
ns
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=48V, VGS=10V,
IDS=28A
nC
Note * : Pulse test ; pulse width 300s, duty cycle2%.
www.hymexa.com
V1.1
3
HY1506D/U/V
Typical Operating Characteristics
Power Dissipation
Drain Current
120
100
ID - Drain Current (A)
Ptot - Power (W)
100
80
60
40
40
o
o
TC=25 C
TC=25 C,VG=10V
40
60
80 100 120 140 160 180 200
60
Tc - Case Temperature (°C)
Safe Operation Area
Rd
s(o
n)
Lim
it
400
100
100us
1ms
10
10ms
DC
1
o
TC=25 C
0.1
0.1
1
10
100
400
VDS - Drain - Source Voltage (V)
Thermal Transient Impedance
Normalized Effective Transient
10
1
Duty = 0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
0.001
Mounted on minimum pad
o
RJA : 62.5 C/W
Single
0.0001
0.001
0.1
0.01
1
10
Square Wave Pulse Duration (sec)
www.hymexa.com
V1.1
4
HY1506D/U/V
Typical Operating Characteristics (Cont.)
Output Characteristics
160
17
VGS= 7,8,9,10V
120
RDS(ON) - On - Resistance (m)
140
6V
100
80
5.5V
60
40
5V
4.5V
15
VGS=4.5V
14
13
12
VGS=10V
11
10
4V
2
3
4
9
5
Drain-Source On Resistance
1.8
50
IDS =250A
IDS=28A
1.6
18
Normalized Threshold Vlotage
40
VDS - Drain-Source Voltage (V)
14
12
10
8
6
30
1.4
1.2
1.0
0.8
0.6
0.4
0.2
4
5
6
7
8
9
0.0
-50 -25
10
50
75 100 125 150 175
Tj - Junction Temperature (°C)
VGS - Gate - Source Voltage (V)
www.hymexa.com
V1.1
5
HY1506D/U/V
Source-Drain Diode Forward
160
2.2
VGS = 10V
IDS = 28A
1.8
IS - Source Current (A)
Normalized On Resistance
2.0
100
1.6
1.4
1.2
1.0
0.8
o
Tj=175 C
10
o
Tj=25 C
1
0.6
0.4
o
0.2
-50 -25
RON@T =25
C:10.5m
j
50
0.1
0.0
75 100 125 150 175
1.2
Capacitance
Gate Charge
1.5
10
VDS= 48V
9
VGS - Gate-source Voltage (V)
4500
Ciss
4000
C - Capacitance (pF)
0.9
VSD - Source-Drain Voltage (V)
Frequency=1MHz
3500
3000
2500
2000
1500
Coss
1000
5000
500
0.3
Crss
5
IDS= 28A
8
7
6
5
4
3
2
1
10
15
30
35
40
50
60
70
QG - Gate Charge (nC)
www.hymexa.com
V1.1
6
HY1506D/U/V
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
V1.1
7
HY1506D/U/V
Device Per Unit
Package Type
Unit
Quantity
TO-252-2L
TO-252-2L
TO-251-3L
TO-251-3S
Tube
75
Reel
Tube
Tube
2500
75
75
Package Information
TO-252-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A1
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
2.90REF
L2
0.51BSC
L3
0.88
1.28
L4
1.00
L5
1.65
1.80
1.95
θ
0°
8°
V1.1
8
HY1506D/U/S
TO-251-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b2
0.00
0.04
0.10
b2'
0.00
0.04
0.10
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
2.286BSC
H
16.22
16.52
16.82
L1
9.15
9.40
9.65
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
www.hymexa.com
V1.1
9
HY1506D/U/S
TO-251-3S
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
2.286BSC
H
10.00
11.22
11.44
L1
3.90
4.10
4.30
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
www.hymexa.com
V1.1
10
HY1506D/U/S
Classification Profile
Classification Reflow Profiles
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 C
150 C
60-120 seconds
150 C
200 C
60-120 seconds
3 C/second max.
3C/second max.
183 C
60-150 seconds
217 C
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
Time (tP)** within 5C of the specified
classification temperature (Tc)
20** seconds
30** seconds
Average ramp-down rate (Tp to Tsmax)
6 C/second max.
6 C/second max.
6 minutes max.
8 minutes max.
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak
(Tp)*
package
body
Temperature
Time 25C to peak temperature
* Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
V1.1
11
HY1506D/U/S
Table 1. SnPb Eutectic Process – Classification Temperatures (Tc)
3
Package
Thickness
很抱歉,暂时无法提供与“HY1506D”相匹配的价格&库存,您可以联系我们找货
