Technical Data 11213
Effective November 2020
SMAJE
400 W Transient voltage suppressor
Applications
Product features
Low profile SMA package
Excellent clamping capability
400 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 10 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized.
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
SMAJE 5-0 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
SMAJE
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
3.3
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
400
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5.0
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
60
A
Typical thermal resistance junction to lead
R
JL
30
°C/W
Typical thermal resistance junction to ambient
R
JA
120
°C/W
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Millimeters
Dimension Minimum
Part marking
Inches
Maximum
Minimum
Maximum
A
2.60
3.00
0.102
0.118
B
4.15
4.65
0.163
0.183
C
1.25
1.65
0.049
0.065
D
0.95
1.52
0.037
0.060
E
4.90
5.30
0.193
0.209
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.00
2.44
0.079
0.096
J
2.00
K
L
Part marking: xxxx = Date code
yy- Refer to marking designator listed
in Electrical Characteristics table
0.079
2.30
0.091
1.80
Packaging information (mm)
Cathode band (Uni-polar only)
0.071
Dimension
Millimeters
Inches
Drawing not to scale.
A0
2.79 ± 0.3
0.110 ± 0.012
Supplied in tape and reel packaging, 5,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
5.33 ± 0.3
0.210 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
4.00 ± 0.2
0.157 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
2
www.eaton.com/electronics
SMAJE
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
SMAJE5-0A
SMAJE5-0CA
HE
TE
5
120
6.4
7
10
9.2
43.5
SMAJE6-0A
SMAJE6-0CA
HG
TG
6
120
6.67
7.37
10
10.3
38.8
SMAJE6-5A
SMAJE6-5CA
HK
TK
6.5
80
7.22
7.98
10
11.2
35.7
SMAJE7-0A
SMAJE7-0CA
HM
TM
7
50
7.78
8.6
10
12
33.3
SMAJE7-5A
SMAJE7-5CA
HP
TP
7.5
50
8.33
9.21
1
12.9
31
SMAJE8-0A
SMAJE8-0CA
HR
TR
8
9.83
1
13.6
29.4
SMAJE8-5A
SMAJE8-5CA
HT
TT
8.5
10
9.44
10.4
1
14.4
27.8
SMAJE9-0A
SMAJE9-0CA
HV
TV
9
5
10
11.1
1
15.4
26
SMAJE10A
SMAJE10CA
HX
TX
10
2
11.1
12.3
1
17
23.5
SMAJE11A
SMAJE11CA
HZ
TZ
11
1
12.2
13.5
1
18.2
22
SMAJE12A
SMAJE12CA
IE
UE
12
1
13.3
14.7
1
19.9
20.1
SMAJE13A
SMAJE13CA
IG
UG
13
1
14.4
15.9
1
21.5
18.6
SMAJE14A
SMAJE14CA
IK
UK
14
1
15.6
17.2
1
23.2
17.3
SMAJE15A
SMAJE15CA
IM
UM
15
1
16.7
18.5
1
24.4
16.4
SMAJE16A
SMAJE16CA
IP
UP
16
1
17.8
19.7
1
26
15.4
SMAJE17A
SMAJE17CA
IR
UR
17
1
18.9
20.9
1
27.6
14.5
SMAJE18A
SMAJE18CA
IT
UT
18
1
1
29.2
13.7
SMAJE20A
SMAJE20CA
IV
UV
22.2
24.5
1
32.4
12.4
SMAJE22A
SMAJE22CA
IX
UX
22
1
24.4
26.9
1
35.5
11.3
SMAJE24A
SMAJE24CA
IZ
UZ
24
1
26.7
29.5
1
38.9
10.3
SMAJE26A
SMAJE26CA
JE
VE
26
1
28.9
31.9
1
42.1
9.5
SMAJE28A
SMAJE28CA
JG
VG
28
1
31.1
34.4
1
45.4
8.8
SMAJE30A
SMAJE30CA
JK
VK
30
1
33.3
36.8
1
48.4
8.3
SMAJE33A
SMAJE33CA
JM
VM
33
1
36.7
40.6
1
53.3
7.5
SMAJE36A
SMAJE36CA
JP
VP
36
1
40
44.2
1
58.1
6.9
SMAJE40A
SMAJE40CA
JR
VR
40
1
44.4
49.1
1
64.5
6.2
SMAJE43A
SMAJE43CA
JT
VT
43
1
47.8
52.8
1
69.4
5.8
SMAJE45A
SMAJE45CA
JV
VV
45
1
50
55.3
1
72.7
5.5
SMAJE48A
SMAJE48CA
JX
VX
48
1
53.3
58.9
1
77.4
5.2
SMAJE51A
SMAJE51CA
JZ
VZ
51
1
56.7
62.7
1
82.4
4.9
SMAJE54A
SMAJE54CA
RE
WE
54
1
60
66.3
1
87.1
4.6
SMAJE58A
SMAJE58CA
RG
WG
58
1
64.4
71.2
1
93.6
4.3
SMAJE60A
SMAJE60CA
RK
WK
60
1
66.7
73.7
1
96.8
4.1
SMAJE64A
SMAJE64CA
RM
WM
64
1
71.1
78.6
1
103
3.9
SMAJE70A
SMAJE70CA
RP
WP
70
1
77.8
86
1
113
3.6
3.3
SMAJE75A
SMAJE75CA
RR
WR
75
1
83.3
92.1
1
121
SMAJE78A
SMAJE78CA
RT
WT
78
1
86.7
95.8
1
126
3.2
SMAJE85A
SMAJE85CA
RV
WV
85
1
94.4
104
1
137
2.9
SMAJE90A
SMAJE90CA
RX
WX
90
1
100
111
1
146
2.8
SMAJE100A
SMAJE100CA
RZ
WZ
100
1
111
123
1
162
2.5
SMAJE110A
SMAJE110CA
SE
XE
110
1
122
135
1
177
2.3
SMAJE120A
SMAJE120CA
SG
XG
120
1
133
147
1
193
2.1
1.9
SMAJE130A
SMAJE130CA
SK
XK
130
1
144
159
1
209
SMAJE150A
SMAJE150CA
SM
XM
150
1
167
185
1
243
1.7
SMAJE160A
SMAJE160CA
SP
XP
160
1
178
197
1
259
1.6
1.5
SMAJE170A
SMAJE170CA
SR
XR
170
1
189
209
1
275
SMAJE180A
SMAJE180CA
ST
XT
180
1
201
222
1
292
1.4
SMAJE200A
SMAJE200CA
SX
XX
200
1
224
247
1
324
1.3
SMAJE220A
SMAJE220CA
ZE
YE
220
1
246
272
1
356
1.1
SMAJE250A
SMAJE250CA
ZG
YG
250
1
279
309
1
405
1
SMAJE300A
SMAJE300CA
ZK
YK
300
1
335
371
1
486
0.8
SMAJE350A
SMAJE350CA
ZM
YM
350
1
391
432
1
567
0.7
SMAJE400A
SMAJE400CA
ZP
YP
400
1
447
494
1
648
0.6
SMAJE440A
SMAJE440CA
ZR
YR
440
1
492
543
1
713
0.6
3
SMAJE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse waveform
Peak value
Half value
50
td
1.0
2.0
3.0
100
Ppp (kW)
400 W at 10/1000 μs +25 °C
10
1.0
0.1
td-Pulse width (ms)
4
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
Peak pulse power dissipation vs. pulse width
0.01
80
t (ms)
0.1
0.001
100
1.0
10
175
SMAJE
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMAJE15CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+9.44125
- 25+2.75370
- 100+1.54732
- 180+1.32877
- 420+1.25884
