Technical Data ELX1062
Effective June 2021
SMAJE
Automotive grade 400 W Transient voltage suppressor
Applications
Product features
Automotive grade (AEC-Q101 qualified)
Low profile SMA package
Excellent clamping capability
High reliability application
400 W peak pulse power capability at 10/1000
μs waveform
Typical IR less than 1 μA above 10 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
Plastic package meets UL 94 V-0
flammability rating
Meets moisture sensitivity level (MSL) level 1
Terminal: tin plated, solderable per J-STD-002
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Automotive chassis and safety systems
Advanced driver assistance systems (ADAS)
Communication and infotainment systems
Network systems and body electronics
Power Train controls
xEV and battery systems
Environmental compliance and general
specifications
AEC-Q101 qualified
Ordering part number
SMAJE 5-0 C A H
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
SMAJE
Effective June 2021
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Symbol
Value
Unit
Storage operating junction temperature range
Parameter
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
3.3
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
400
W
Maximum instantaneous forward voltage at
100 A for unidirectional
VF
5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
60
A
Typical thermal resistance junction to lead
R
JL
30
°C/W
Typical thermal resistance junction to ambient
R
JA
120
°C/W
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm/inches
Millimeters
Part marking
Inches
Dimension Minimum
Maximum
Minimum
Maximum
A
2.60
3.00
0.102
0.118
B
4.15
4.65
0.163
0.183
C
1.25
1.65
0.049
0.065
D
0.95
1.52
0.037
0.060
E
4.90
5.30
0.193
0.209
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.00
2.44
0.079
0.096
J
2.00
0.079
K
2.30
0.091
L
1.80
0.071
Cathode band (uni-polar only)
Part marking:
xxxx = Date code
yy- Refer to marking designator listed in
Electrical characteristics table
Packaging information - mm/inches
Drawing not to scale.
Supplied in tape and reel packaging, 5,000 parts per 13” diameter reel (EIA-481 compliant)
2
www.eaton.com/electronics
Dimensions
Millimeters
Inches
A0
2.79 ± 0.3
0.110 ± 0.012
B0
5.33 ± 0.3
0.210 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.50 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
4.00 ± 0.2
0.157 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.042 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
SMAJE
Effective June 2021
Electrical specifications (+25 °C)
Part number
VR
IR @ VR
VBR @ IT
IT
VC @ IPP
IPP
Uni-polar
Bi-polar
Marking
Uni
Bi
(V)
(µA)
min (V)
max (V)
(mA)
max (V)
(A)
SMAJE5-0AH
SMAJE5-0CAH
HE
TE
5
120
6.4
7
10
9.2
43.5
SMAJE6-0AH
SMAJE6-0CAH
HG
TG
6
120
6.67
7.37
10
10.3
38.8
SMAJE6-5AH
SMAJE6-5CAH
HK
TK
6.5
80
7.22
7.98
10
11.2
35.7
SMAJE7-0AH
SMAJE7-0CAH
HM
TM
7
50
7.78
8.6
10
12
33.3
SMAJE7-5AH
SMAJE7-5CAH
HP
TP
7.5
50
8.33
9.21
1
12.9
31
SMAJE8-0AH
SMAJE8-0CAH
HR
TR
8
9.83
1
13.6
29.4
SMAJE8-5AH
SMAJE8-5CAH
HT
TT
8.5
10
9.44
10.4
1
14.4
27.8
SMAJE9-0AH
SMAJE9-0CAH
HV
TV
9
5
10
11.1
1
15.4
26
SMAJE10AH
SMAJE10CAH
HX
TX
10
2
11.1
12.3
1
17
23.5
SMAJE11AH
SMAJE11CAH
HZ
TZ
11
1
12.2
13.5
1
18.2
22
SMAJE12AH
SMAJE12CAH
IE
UE
12
1
13.3
14.7
1
19.9
20.1
SMAJE13AH
SMAJE13CAH
IG
UG
13
1
14.4
15.9
1
21.5
18.6
SMAJE14AH
SMAJE14CAH
IK
UK
14
1
15.6
17.2
1
23.2
17.3
SMAJE15AH
SMAJE15CAH
IM
UM
15
1
16.7
18.5
1
24.4
16.4
SMAJE16AH
SMAJE16CAH
IP
UP
16
1
17.8
19.7
1
26
15.4
SMAJE17AH
SMAJE17CAH
IR
UR
17
1
18.9
20.9
1
27.6
14.5
SMAJE18AH
SMAJE18CAH
IT
UT
18
1
1
29.2
13.7
SMAJE20AH
SMAJE20CAH
IV
UV
22.2
24.5
1
32.4
12.4
SMAJE22AH
SMAJE22CAH
IX
UX
22
1
24.4
26.9
1
35.5
11.3
SMAJE24AH
SMAJE24CAH
IZ
UZ
24
1
26.7
29.5
1
38.9
10.3
SMAJE26AH
SMAJE26CAH
JE
VE
26
1
28.9
31.9
1
42.1
9.5
SMAJE28AH
SMAJE28CAH
JG
VG
28
1
31.1
34.4
1
45.4
8.8
SMAJE30AH
SMAJE30CAH
JK
VK
30
1
33.3
36.8
1
48.4
8.3
SMAJE33AH
SMAJE33CAH
JM
VM
33
1
36.7
40.6
1
53.3
7.5
SMAJE36AH
SMAJE36CAH
JP
VP
36
1
40
44.2
1
58.1
6.9
SMAJE40AH
SMAJE40CAH
JR
VR
40
1
44.4
49.1
1
64.5
6.2
SMAJE43AH
SMAJE43CAH
JT
VT
43
1
47.8
52.8
1
69.4
5.8
SMAJE45AH
SMAJE45CAH
JV
VV
45
1
50
55.3
1
72.7
5.5
SMAJE48AH
SMAJE48CAH
JX
VX
48
1
53.3
58.9
1
77.4
5.2
SMAJE51AH
SMAJE51CAH
JZ
VZ
51
1
56.7
62.7
1
82.4
4.9
SMAJE54AH
SMAJE54CAH
RE
WE
54
1
60
66.3
1
87.1
4.6
SMAJE58AH
SMAJE58CAH
RG
WG
58
1
64.4
71.2
1
93.6
4.3
SMAJE60AH
SMAJE60CAH
RK
WK
60
1
66.7
73.7
1
96.8
4.1
SMAJE64AH
SMAJE64CAH
RM
WM
64
1
71.1
78.6
1
103
3.9
SMAJE70AH
SMAJE70CAH
RP
WP
70
1
77.8
86
1
113
3.6
SMAJE75AH
SMAJE75CAH
RR
WR
75
1
83.3
92.1
1
121
3.3
SMAJE78AH
SMAJE78CAH
RT
WT
78
1
86.7
95.8
1
126
3.2
SMAJE85AH
SMAJE85CAH
RV
WV
85
1
94.4
104
1
137
2.9
SMAJE90AH
SMAJE90CAH
RX
WX
90
1
100
111
1
146
2.8
SMAJE100AH
SMAJE100CAH
RZ
WZ
100
1
111
123
1
162
2.5
SMAJE110AH
SMAJE110CAH
SE
XE
110
1
122
135
1
177
2.3
SMAJE120AH
SMAJE120CAH
SG
XG
120
1
133
147
1
193
2.1
SMAJE130AH
SMAJE130CAH
SK
XK
130
1
144
159
1
209
1.9
SMAJE150AH
SMAJE150CAH
SM
XM
150
1
167
185
1
243
1.7
SMAJE160AH
SMAJE160CAH
SP
XP
160
1
178
197
1
259
1.6
SMAJE170AH
SMAJE170CAH
SR
XR
170
1
189
209
1
275
1.5
SMAJE180AH
SMAJE180CAH
ST
XT
180
1
201
222
1
292
1.4
SMAJE200AH
SMAJE200CAH
SX
XX
200
1
224
247
1
324
1.3
SMAJE220AH
SMAJE220CAH
ZE
YE
220
1
246
272
1
356
1.1
SMAJE250AH
SMAJE250CAH
ZG
YG
250
1
279
309
1
405
1
SMAJE300AH
SMAJE330CAH
ZK
YK
300
1
335
371
1
486
0.8
SMAJE350AH
SMAJE350CAH
ZM
YM
350
1
391
432
1
567
0.7
SMAJE400AH
SMAJE400CAH
ZP
YP
400
1
447
494
1
648
0.6
SMAJE440AH
SMAJE440CAH
ZR
YR
440
1
492
543
1
713
0.6
3
Effective June 2021
SMAJE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional
Pulse waveform
IPPM (% IRSM)
PPP derating in percentage (%)
Pulse derating curve
t (ms)
TJ (°C)
PPP (KW)
Peak pulse power dissipation curve
td - Pulse width (ms)
4
SMAJE
Effective June 2021
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SMAJE5-0CAH”相匹配的价格&库存,您可以联系我们找货
