Transient Voltage Suppression Diodes
1.0SMB Series1000W
Trustworthy electronic circuit protection expert
1.0SMB Series
Description
The 1KSMB series is designed specifically to protect sensitive
electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Features
Functional Diagram
●Low profile package
●Ideal for automated placement
●Glass passivated chip junction
●Available in uni-directional and bi-directional
●Excellent clamping capability
●Very fast response time
●Low incremental surge resistance
●Meets MSL level 1, per J-STD-020, LF maximum peak of
Applications
260 °C
●Case: DO-214AA (SMBJ)
Use in sensitive electronics protection against voltage
● 1000 W peak pulse power capability with a10/1000 us
transients induced by inductive load switching and lighting
waveform, repetitive rate (duty cycle):0.01 %
on ICs, MOSFET, signal lines of sensor units for consumer,
● Polarity: For uni-directional types the color band denotes
computer, industrial, and telecommunication
cathode end, no marking on bi-directional types
Maximum Ratings (TA=25℃ unless otherwise noted)
Parameter
Symbol
Minimum Peak Pulse Power Dissipation (T = 1 ms)
Value
Unit
PPK
1000
Watts
IFSM
100
Amps
PD
5
Watts
VF
3.5/5.0
Volts
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
Peak Forward Surge Current
8.3 ms Single Half Sine Wave Superimposed on Rated Load
(JEDEC Method)
Steady State Power Dissipation @ TL = 75 °C
Maximum Instantaneous Forward Voltage @ I PP = 35 A
(For Unidirectional Units Only)
Operating Temperature Range
Storage Temperature Range
Note:
1.
Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
2.
Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
3.
VF
很抱歉,暂时无法提供与“1.0SMB24CA”相匹配的价格&库存,您可以联系我们找货
