15BJ20CA
15BJ20CA
    EATON(伊顿)
    SMB(DO-214AA)
    TVS DIODE 20VWM 32.4VC SMBF
15BJ20CA 数据手册
Technical Data 11206 Effective November 2020 15BJ 1500 W Transient voltage suppressor Applications Product features • Low profile SMBF package • Excellent clamping capability • 1500 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 11 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number 15BJ 6-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance 15BJ 1500 W Transient voltage suppressor  Technical Data 11206 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 1500 W Maximum instantaneous forward voltage at 50 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 200 A Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Part marking Inches Maximum Minimum Maximum A 3.90 4.50 0.154 0.177 B 4.65 5.15 0.183 0.203 C 1.85 2.15 0.073 0.085 D 0.60 0.024 E 5.60 6.00 0.220 0.236 Cathode band (Uni-polar only) F 2.05 2.35 0.081 0.093 G 0.12 0.28 0.005 0.011 Part marking: xxxx = Date code yyy- Refer to marking designator listed in Electrical Characteristics table J 2.00 K L 0.079 3.20 0.126 2.30 Packaging information (mm) 0.091 Dimensions Millimeters Inches Drawing not to scale. A0 4.50 ± 0.3 0.177 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 6.10 ± 0.3 0.240 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 2 www.eaton.com/electronics E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.5 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 Technical Data 11206 15BJ  1500 W Transient voltage suppressor Effective November 2020  Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) 15BJ5-0A 15BJ5-0CA GDE BDE 5 300 6.4 7 10 9.2 163 15BJ6-0A 15BJ6-0CA GDG BDG 6 250 6.67 7.37 10 10.3 145.6 15BJ6-5A 15BJ6-5CA GDK BDK 6.5 150 7.22 7.98 10 11.2 134 15BJ7-0A 15BJ7-0CA GDM BDM 7 100 7.78 8.6 10 12 125 15BJ7-5A 15BJ7-5CA GDP BDP 7.5 50 8.33 9.21 1 12.9 116.3 15BJ8-0A 15BJ8-0CA GDR BDR 8 30 8.89 9.83 1 13.6 110.3 15BJ8-5A 15BJ8-5CA GDT BDT 8.5 20 9.44 10.4 1 14.4 104.2 15BJ9-0A 15BJ9-0CA GDV BDV 9 10 10 11.1 1 15.4 97.4 15BJ10A 15BJ10CA GDX BDX 10 5 11.1 12.3 1 17 88.2 15BJ11A 15BJ11CA GDZ BDZ 11 2 12.2 13.5 1 18.2 82.4 15BJ12A 15BJ12CA GEE BEE 12 1 13.3 14.7 1 19.9 75.4 15BJ13A 15BJ13CA GEG BEG 13 1 14.4 15.9 1 21.5 69.8 15BJ14A 15BJ14CA GEK BEK 14 1 15.6 17.2 1 23.2 64.7 15BJ15A 15BJ15CA GEM BEM 15 1 16.7 18.5 1 24.4 61.5 15BJ16A 15BJ16CA GEP BEP 16 1 17.8 19.7 1 26 57.7 15BJ17A 15BJ17CA GER BER 17 1 18.9 20.9 1 27.6 54.4 15BJ18A 15BJ18CA GET BET 18 1 20 22.1 1 29.2 51.4 15BJ20A 15BJ20CA GEV BEV 20 1 22.2 24.5 1 32.4 46.3 15BJ22A 15BJ22CA GEX BEX 22 1 24.4 26.9 1 35.5 42.3 15BJ24A 15BJ24CA GEZ BEZ 24 1 26.7 29.5 1 38.9 38.6 15BJ26A 15BJ26CA GFE BFE 26 1 28.9 31.9 1 42.1 35.6 15BJ28A 15BJ28CA GFG BFG 28 1 31.1 34.4 1 45.4 33.1 15BJ30A 15BJ30CA GFK BFK 30 1 33.3 36.8 1 48.4 31 15BJ33A 15BJ33CA GFM BFM 33 1 36.7 40.6 1 53.3 28.2 15BJ36A 15BJ36CA GFP BFP 36 1 40 44.2 1 58.1 25.8 15BJ40A 15BJ40CA GFR BFR 40 1 44.4 49.1 1 64.5 23.3 15BJ43A 15BJ43CA GFT BFT 43 1 47.8 52.8 1 69.4 21.6 15BJ45A 15BJ45CA GFV BFV 45 1 50 55.3 1 72.7 20.6 15BJ48A 15BJ48CA GFX BFX 48 1 53.3 58.9 1 77.4 19.4 15BJ51A 15BJ51CA GFZ BFZ 51 1 56.7 62.7 1 82.4 18.2 15BJ54A 15BJ54CA GGE BGE 54 1 60 66.3 1 87.1 17.2 15BJ58A 15BJ58CA GGG BGG 58 1 64.4 71.2 1 93.6 16.1 15BJ60A 15BJ60CA GGK BGK 60 1 66.7 73.7 1 96.8 15.5 15BJ64A 15BJ64CA GGM BGM 64 1 71.1 78.6 1 103 14.6 15BJ70A 15BJ70CA GGP BGP 70 1 77.8 86 1 113 13.3 15BJ75A 15BJ75CA GGR BGR 75 1 83.3 92.1 1 121 12.4 15BJ78A 15BJ78CA GGT BGT 78 1 86.7 95.8 1 126 11.9 15BJ85A 15BJ85CA GGV BGV 85 1 94.4 104 1 137 11 15BJ90A 15BJ90CA GGX BGX 90 1 100 111 1 146 10.3 15BJ100A 15BJ100CA GGZ BGZ 100 1 111 123 1 162 9.3 15BJ110A 15BJ110CA GHE BHE 110 1 122 135 1 177 8.5 15BJ120A 15BJ120CA GHG BHG 120 1 133 147 1 193 7.8 15BJ130A 15BJ130CA GHK BHK 130 1 144 159 1 209 7.2 15BJ150A 15BJ150CA GHM BHM 150 1 167 185 1 243 6.2 15BJ160A 15BJ160CA GHP BHP 160 1 178 197 1 259 5.8 15BJ170A 15BJ170CA GHR BHR 170 1 189 209 1 275 5.5 15BJ180A 15BJ180CA GHT BHT 180 1 201 222 1 292 5.2 15BJ190A 15BJ190CA GHU BHU 190 1 211 234 1 307 4.9 15BJ200A 15BJ200CA GHV BHV 200 1 224 247 1 324 4.7 15BJ210A 15BJ210CA GHX BHX 210 1 233 258 1 337 4.5 15BJ220A 15BJ220CA GHZ BHZ 220 1 246 272 1 356 4.2 15BJ250A 15BJ250CA GIE BIE 250 1 279 309 1 405 3.7 15BJ300A 15BJ300CA GIG BIG 300 1 335 371 1 486 3.1 15BJ350A 15BJ350CA GIK BIK 350 1 391 432 1 567 2.6 15BJ400A 15BJ400CA GIM BIM 400 1 447 494 1 648 2.3 15BJ440A 15BJ440CA GIP BIP 440 1 492 543 1 713 2.1 www.eaton.com/electronics 3 15BJ 1500 W Transient voltage suppressor  Technical Data 11206 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 Peak value Half value 50 0 0 td 1.0 2.0 t (ms) 4 PPP derating in percentage (%) Pulse waveform www.eaton.com/electronics 3.0 4.0 100 80 60 40 20 0 0 25 50 75 100 125 150 TJ-Initial junction temperature (°C) 175 Technical Data 11206 15BJ  1500 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
15BJ20CA 价格&库存
很抱歉,暂时无法提供与“15BJ20CA”相匹配的价格&库存,您可以联系我们找货
