CD4007B
CD4007M/CD4007C Dual
Complementary Pair Plus Inverter
General Description
The CD4007B consists of three complementary pairs of N- and
P-channel enhancement mode MOS transis- tors suitable for
series/shunt applications. All inputs are pro- tected from static
DIP14
discharge by diode clamps to VDD and VSS.
For proper operation the voltages at all pins must be constrained to be between VSS b 0.3V and VDD a 0.3V at all times.
SOP14
Features
Wide supply voltage range:3.0V to 15V
High noise immunity:0.45 VCC (typ.)
TSSOP14
Ordering Information
DEVICE
Package Type
MARKING
Packing
Packing Qty
CD4007BE
DIP14
CD4007BE
TUBE
1000pcs/Box
CD4007BM/TR
SOP14
CD4007B
REEL
2500pcs/Reel
TSSOP14
CD4007B
REEL
2500pcs/Reel
CD4007BMT/TR
http://www.hgsemi.com.cn
1/7
2018 MAR
CD4007B
Connection Diagram
Dual-In-Line Package
Note: All P-channel substrates are connected to VDD
and all N-channel substrates are connected to VSS.
Absolute Maximum Ratings (Note 1)
If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales
Office/Distributors for availability and specifications.
Parameter
Voltage at Any Pin
Min.
Max.
Unit
VSS -0.3
VDD -0.3
V
Operating Temperature Range
-40
+85
Storage Temperature Range
-65
+150
Power Dissipation (PD)
Dual-In-Line
700
mW
Small Outline
500
mW
Operating VDD Range
VSS +3.0
VSS +15
V
Lead Temperature
(Soldering, 10 seconds)
260
2/7
2018 MAR
CD4007B
DC Electrical Characteristics
Limits
+25℃
+85℃
Units
Min Typ Max Min Typ Max Min Typ Max
-40℃
Symbol
Parameter
Conditions
IL
Quiescent Device
Current
VDD = 5.0V
VDD = 10V
0.5
1.0
0.005 0.05
0.005 1.0
15
30
mA
mA
PD
Quiescent Device
VDD = 5.0V
Dissipation Package VDD = 10V
2.5
10
0.025 2.5
0.05 10
75
300
mW
mW
VOL
Output VoltageLow
Level
VDD = 5.0V
VDD = 10V
0.05
0.05
0.01
0.05
0.05
V
V
VOH
Output VoltageHigh
Level
VDD = 5.0V
VDD = 10V
4.95
9.95
4.95
9.95
5.0
10
4.95
9.95
V
V
VNL
Noise Immunity
(All inputs)
VDD = 5.0V, VO = 3.6V
VDD = 10V, VO = 7.2V
1.5
3.0
2.25
4.5
1.5
3.0
1.4
2.9
V
V
VNH
Noise Immunity
(All Inputs)
VDD = 5.0V, VO = 0.95V
VDD = 10V, VO = 2.9V
3.6
7.1
3.5
7.0
2.25
4.5
3.5
7.0
V
V
IDN
Output Drive
CurrentN-Channel
0.35
1.2
0.3
1.0
1.0
2.5
0.24
0.8
Ma
mA
IDP
Output Drive
CurrentP-Channel
VDD = 5.0V, VO = 0.4V, VI = VDD
VDD = 10V, VO = 0.5V, VI = VDD
VDD = 5.0V, VO = 2.5V, VI = VSS
VDD = 10V, VO = 9.5V, VI = VSS
-1.3
-0.65
-1.1
-0.55
-4.0
-2.5
-0.9
-0.45
mA
mA
II
Input Current
10
pA
Note 1:
This device should not be connected to circuits with the power on because high transient voltages may cause
permanent damage.
3/7
2018 MAR
CD4007B
AC Electrical Characteristics*
TA =25°C and CL = 15 pF and rise and fall times =20 ns. Typical temperature coefficient for all values of
VDD =0.3%/°C
Symbol
Parameter
tPLH = tPHL
Propagation Delay Time
tTLH = tTHL
Transition Time
CI
Input Capacitance
Conditions
VDD = 5.0V
VDD = 10V
VDD = 5.0V
VDD = 10V
Any Input
Min
Typ
Max
Units
35
30
5
75
50
100
50
ns
ns
ns
ns
pF
*AC Parameters are guaranteed by DC correlated testing.
AC Test Circuits
Switching Time Waveforms
4/7
2018 MAR
CD4007B
Physical Dimensions
DIP14
B
L1
L
E
D1
D
d
A
c
a
Dimensions In Millimeters(DIP14)
A
B
D
D1
E
L
L1
a
c
Min:
6.10
18.94
8.40
7.42
3.10
0.50
3.00
1.50
0.40
Max:
6.68
19.56
9.00
7.82
3.55
0.70
3.60
1.55
0.50
Symbol:
d
2.54 BSC
SOP14
Q
A
C
C1
B
D
A1
a
0.25
b
Dimensions In Millimeters(SOP14)
A
A1
B
C
C1
D
Min:
1.35
0.05
8.55
5.80
3.80
0.40
0°
0.35
Max:
1.55
0.20
8.75
6.20
4.00
0.80
8°
0.45
Symbol:
5/7
Q
a
b
1.27 BSC
2018 MAR
CD4007B
Physical Dimensions
TSSOP14
Dimensions In Millimeters(TSSOP14)
A
A1
B
C
C1
D
Min:
0.85
0.05
4.90
6.20
4.30
0.40
0°
0.20
Max:
0.95
0.20
5.10
6.60
4.50
0.80
8°
0.25
Symbol:
6/7
Q
a
b
0.65 BSC
2018 MAR
CD4007B
IMPORTANT STATEMENT:
Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant
information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the
altered documents.
Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design
and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design,
validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the
occurrence of potential risks that may lead to personal injury or property loss.
Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor
will not bear the consequences caused by the application of products in these fields.
The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network
tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed
to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance
scope of Huaguan Semiconductor. Not all parameters of each device need to be tested.
The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this
document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly
forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages,
costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement.
7/7
2018 MAR
很抱歉,暂时无法提供与“CD4007BE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.32340
- 50+1.08110
- 150+0.90850
- 500+0.77890
