OSC-SMD3225-100.00MHZ
    STI-ELE(华安思泰)
    SMD3225_4P
    有源晶振 100MHz ±25ppm 3.3V SMD3225_4P 表面贴装
OSC-SMD3225-100.00MHZ 数据手册
Shenzhen STI Electronics Co., Ltd. Specification for approval Product Name: Customer Name: Crystal Oscillator Holder Type: Customer Part NO.: OSC SMD3225 Description: Issued Date: 100.00MHZ / ±25PPM / 3.3V 2022-11-10 Please confirmatory sample, and give us valuable suggestion, thanks! Customer Approved engineer quality buyer Supplier Approved Issued by Checked by Approved by E-mail:david@sti-ele.com Tel:86 (755) 2949-7475 Website:http://www.sti-ele.com Fax:86 (755) 2949-7476 Address:5 floor, 6 Building, A District, Baoan Internet industry base, Xixiang, Baoan District, Shenzhen ,Guangdong, China 518101 1-4 Shenzhen STI Electronics Co., Ltd. 1:Electrical parameters No. Item Spec 1 Model NO. 2 Nominal Frequency 3 Temperature Characteristics 4 Operating temperature Range -40℃ ∼ +85℃ 5 Storage Temperature Range -55℃ ∼ +125℃ 6 Supply Voltage 3.3V±0.1V 7 Supply Current 30mA Max 8 Output wave HC CMOS 9 Output Load 15PF 10 Rise/Fall Time 10ns Max 12 Symmetry 50%±10% 13 Aging Rate a Year 14 start up time OSC SMD3225 100.000000MHZ ±25ppm ±3ppm/year 5ms Max 2. Reflow Condition 2-4 Shenzhen STI Electronics Co., Ltd. 3. Test Circuit 4. matters need attention 4.1:Install the product in the anti-static environment ( IC circuit for this item as a requirement) 4.2:Note that prevent fall or collision caused by the product failure 4.3:Crystal plus power voltage amplitude, tolerance, correct polarity, attention to power supply ripple(Low phase noise crystal recommended low ripple linear power) 4.4:Output load to match 4.5:Oscillator circuit,NC/tri-state pin must be Vacant / tri-state control terminal 4.6:DIP package crystal welded by hand,SMD package crystal using reflow,The welding temperature does not exceed 265 ℃,Time of less than 5 seconds 4.7:Product storage ambient temperature is -10℃∼40℃、Relative humidity less than 80%、Ambient non-acidic, alkaline and other harmful gases Shenzhen STI Electronics Co., Ltd. 3-4 5:Dimensions (Unit:mm) 44
OSC-SMD3225-100.00MHZ 价格&库存
很抱歉,暂时无法提供与“OSC-SMD3225-100.00MHZ”相匹配的价格&库存,您可以联系我们找货
