GOFORD
G8N03
Features
Epoxy Meets UL 94 V-0 Flammability Rating
Moisture Sensitivity Level 1
Halogen Free Available Upon Request By Adding Suffix "-HF"
Lead Free Finish/RoHS Compliant ("P" Suffix Designates RoHS
Compliant. See Ordering Information)
N-CHANNEL
MOSFET
Maximum Ratings
Operating Junction Temperature Range : -55°C to +150°C
Storage Temperature Range: -55°C to +150°C
Maximum Thermal Resistance: 78°C/W Junction to Case(Note1)
Parameter
Symbol
Rating
Unit
Drain-Source Voltage
VDS
30
V
Gate-Source Volltage
VGS
±20
V
8
A
5.6
A
IDM
32
A
PD
1.6
W
Continuous Drain Current
Pulsed Drain Current
(Note2)
Total Power Dissipation
TC=25°C
TC=100°C
ID
SOT23-6L
G
6
4
B
1
2
C
3
A
Note 1. Surface Mounted on FR4 Board, t < 10 sec.
2. Repetitive Rating : Pulse Width Limited by Maximum Junction
Temperature.
5
H
M
K
J
D
Internal Structure
D
6
D
5
1
2
D
DIM
S
4
A
B
C
D
G
H
J
K
L
M
3
D
G
Marking:8N03
www.gofordsemi.com
TEL:0755-29961263
DIMENSIONS
INCHES
MM
MIN MAX MIN MAX
0.012 0.020 0.30 0.50
0.051 0.070 1.30 1.80
0.087 0.126 2.20 3.20
0.037
0.95
0.074
1.90
0.106 0.122 2.70 3.10
0.002 0.006 0.05 0.15
0.030 0.051 0.75 1.30
0.012 0.024 0.30 0.60
0.003 0.008 0.08 0.22
L
NOTE
FAX:0755-29961466
TYP.
TYP.
GOFORD
G8N03
Electrical Characteristics @ 25°C (Unless Otherwise Specified)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
Off Characteristics
Drain-Source Breakdown Voltage
V(BR)DSS
VGS=0V, ID=250µA
Zero Gate Voltage Drain Current
IDSS
VDS =30V, VGS =0V
1
µA
Gate-Source Leakage Current
IGSS
VDS =0V, VGS =±20V
±100
nA
Gate-Threshold Voltage
VGS(th)
VDS=VGS, ID=250µA
1.4
3
V
VGS=10V, ID=8A
14
RDS(on)
9
Drain-Source On-Resistance
VGS=4.5V, ID=8A
11
16
VDS=5V, ID=8A
30
30
V
On Characteristics(Note 3)
Forward Tranconductance
gFS
1
mΩ
S
Dynamic Characteristics(Note 4)
900
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
50
Turn-On Delay Time
td(on)
15
Turn-On Rise Time
tr
Turn-Off Delay Time
td(off)
VDS=15V,VGS=0V,f =1MHz
pF
300
Switching Characteristics(Note 4)
VGS=10V,VDD=25V,ID=1A,
RGEN=6Ω
10
Turn-Off Fall Time
tf
12
Total Gate Charge
Qg
13
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=15V, ID=8A,VGS=5V
ns
45
3.2
nC
2.0
Drain-Source Diode Characteristics and Maximum Ratings
Drain-Source Diode Forward
Current
Diode Forward Voltage(Note 3)
IS
VSD
VGS=0V, IS=8A
8
A
1.2
V
Note: 3. Pulse Test : Pulse Width≤300μs, Duty Cycle ≤ 2%.
4.
uaranteed by Design, Not Subject to Production Testing.
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466
GOFORD
G8N03
Curve Characteristics
Fig. 1 - RDS(ON)—ID
Fig. 2 - Transfer Characteristics
25
30
Pulsed
25
Drain Current (A)
Drain-Source On-Resistance (mΩ)
TA=25°C
VGS=4.5V
15
10
TC=125°C
5
VGS=10V
5
15
TC=25°C
TC=-55°C
40
Drain Current (A)
2
3
4
5
Gate To Source Voltage (V)
Fig. 4 - IS—VSD
Fig. 3 - Gate Charge Characteristics
100
10
ID=8A
8
Source Current (A)
Gate-Source Voltage (V)
VDS=15V
6
4
TJ=150°C
10
TJ=25°C
2
10
15
0.2
0.4
0.6
0.8
1.0
Source To Drain Voltage (V)
Gate Charge(nC)
www.gofordsemi.com
1
0.0
TEL:0755-29961263
FAX:0755-29961466
1.2
很抱歉,暂时无法提供与“G8N03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.24996
- 100+0.24374
- 300+0.23959
- 1000+0.23544
