GOFORD
G1NP02ELL
N and P Channel Enhancement Mode Power MOSFET
Description
This Product uses advanced trench technology
MOSFETs to provide excellent RDS(ON) and low gate
charge. The complementary MOSFETs may be used to
form a level shifted high side switch, and for a host of
other applications.
General Features
NMOS
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
RDS(ON) (at VGS = 2.5V)
RDS(ON) (at VGS = 1.8V)
PMOS
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
RDS(ON) (at VGS = -2.5V)
RDS(ON) (at VGS = -1.8V)
100% Avalanche Tested
RoHS Compliant
ESD (HBM)>2.0KV
Schematic diagram
20V
1.36A
< 375mΩ
< 450mΩ
< 800mΩ
Marking and pin assignment
-20V
-1.15A
< 520mΩ
< 700mΩ
< 1000mΩ
SOT-23-6L
Application
⚫ Power switch
⚫ DC/DC converters
Device
Package
Marking
Packaging
G1NP02ELL
SOT-23-6
G1NP02
3000pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
NMOS
PMOS
Unit
VDS
V
ID
1.36
-1.15
A
IDM
5.4
-3.4
A
Gate-Source Voltage
VGS
±10
±10
V
Power Dissipation
PD
1.12
1.12
W
TJ, Tstg
-55 To 150
-55 To 150
ºC
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Symbol
Value
Unit
RthJA
111
ºC/W
Thermal Resistance, Junction-to-Ambient
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
NMOS Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250µA
V
Zero Gate Voltage Drain Current
IDSS
VDS = 20V, VGS = 0V
1
μA
Gate-Source Leakage
IGSS
VGS = ±10V
±10
uA
VGS(th)
VDS = VGS, ID = 250µA
0.35
0.55
1
V
VGS = 4.5V, ID = 0.65A
159
370
VGS = 2.5V, ID = 0.55A
209
450
VGS = 1.8V, ID = 0.45A
290
800
VDS=10V,ID=0.5A
1.6
60
15
5
750
75
Gate-Source Threshold Voltage
Drain-Source On-Resistance
Forward Transconductance
RDS(on)
gFS
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
VGS = 0V,
VDS = 10V,
f = 1.0MHz
VDD = 10V,
ID = 250mA,
VGS = 4.5V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
225
Turn-on Delay Time
td(on)
6.7
Turn-on Rise Time
tr
4.8
Turn-off Delay Time
td(off)
17.3
7.4
Turn-off Fall Time
VDD = 10V,
ID = 0.5A,
RG = 10Ω
tf
pF
pC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
1.36
A
VSD
TJ = 25ºC, ISD = 0.5A, VGS = 0V
1.2
V
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
NMOS Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 2. Transfer Characteristics
ID, Drain Current (A)
ID, Drain Current (mA)
Figure 1. Output Characteristics
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
RDS(on), On-Resistance (mΩ)
VGS=1.8V
300
Figure 4. Gate Charge
Vgs Gate-Source Voltage(V)
Figure 3.Drain-Source On-Resistance
350
250
VGS=2.5V
200
150
VGS=4.5V
100
5
VDS=10V
ID=250mA
4
3
2
1
0.5
0.7
0.9
ID-Drain Current(A)
0.2
0.4
0.6
0.8
Qg Gate Charge(nC)
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
Is, Reverse Drain Current (A)
Figure 5. Capacitance
-Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961262
VSD, Source-to-Drain Voltage (V)
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
Figure 8. Safe Operation Area
Figure 7. Drain-Source On-Resistance
VGS=10V
ID=600mA
1.4
ID, Drain Current(A)
RDS(on), (Normalized)
1.6
1.2
1
0.8
0.6
-50
-25
50
75
100
125
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
PMOS Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
V(BR)DSS
VGS = 0V, ID = -250µA
-20
V
IDSS
VDS = -20V, VGS = 0V
-1
μA
Gate-Source Leakage
IGSS
VGS = ±10V
±10
uA
VGS(th)
VDS = VGS, ID = -250µA
-0.35
-0.55
-0.8
V
VGS = -4.5V, ID = -0.5A
375
520
VGS = -2.5V, ID = -0.5A
478
700
VGS = -1.8V, ID = -0.5A
621
1000
VDS=-5V,ID=-0.6A
1.7
68.4
17
5.7
855
85.5
RDS(on)
gFS
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Crss
Total Gate Charge
Qg
VGS = 0V,
VDS = -10V,
f = 1.0MHz
VDD = -10V,
ID = -250mA,
VGS = -4.5V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
256.5
Turn-on Delay Time
td(on)
6.5
Turn-on Rise Time
tr
6.5
Turn-off Delay Time
td(off)
18.2
5.5
Turn-off Fall Time
VDD = -10V,
ID = -0.6A,
RG = 3Ω
tf
pF
pC
ns
Body Diode Voltage
IS
TC = 25ºC
-1.15
A
VSD
TJ = 25ºC, ISD = -0.5A, VGS = 0V
-1
V
Notes
1.
2.
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
PMOS Typical Characteristics TJ = 25ºC, unless otherwise noted
-ID, Drain Current (A)
4
25ºC
3
2
125ºC
1
-VDS, Drain-to-Source Voltage (V)
VGS=-1.8V
600
VGS=-2.5V
VGS=-4.5V
300
2
2.5
3
3.5
4
4.5
5
VDS=-10V
ID=-250mA
4
3
2
1
0.4
0.6
0.8
-ID-Drain Current(A)
0.4
0.6
0.8
1
-Is, Reverse Drain Current (A)
120
100
Ciss
80
60
Coss
40
0.2
Qg Gate Charge(nC)
Capacitance(pF)
1.5
-Vgs Gate-Source Voltage(V)
Figure 3.Rdson-Drain Current
400
1
-VGS, Gate-to-Source Voltage (V)
700
500
0.5
Crss
8
12
16
www.gofordsemi.com
TEL:0755-29961262
-VSD, Source-to-Drain Voltage (V)
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
-ID, Drain Current(A)
-VDS, Drain-Source Voltage(V)
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
GOFORD
G1NP02ELL
SOT-23-6L Package Information
Dimensions in Millimeters
Symbol
MIN.
NOM.
MAX.
A1
0.00
0.10
A2
1.00
1.10
1.20
b
0.30
0.40
0.50
c
0.10
0.15
0.20
D
2.80
2.90
3.00
E
1.50
1.60
1.70
E1
2.60
2.80
3.00
e
0.2GAUGE PLANE
e1
1.90
L
0.30
0.45
0.60
Θ
0°
8°
All Dimensions in mm
www.gofordsemi.com
TEL:0755-29961262
FAX:0755 -29961466
V2.0-Version
