PJ8205
N-Channel Power MOSFET
Features
SOT-23-6
Advanced trench process technology
High Density Cell Design For Ultra Low On-Resistance
High Power and Current handing capability
4
5
3
6
2
1
Schematic Diagram
Drain1
2
6
Gate1
Drain2
5
4
Gate2
1 Source1
3 Source2
Absolute Maximum Ratings
Ratings at TC =25℃ unless otherwise specified.
Parameter
Drain-Source Voltage
Symbol
VDS
Maximum
Units
V
VGS
±12
V
Continuous Drain Current
ID
5
A
Pulsed Drain Current Note1
IDM
25
A
Power Dissipation
PD
1.25
W
TJ, TSTG
150, -55 to 150
°C
Symbol
Typ.
Units
RθJA
100
°C/W
Gate-Source Voltage
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum
Junction-to-Ambient Note2
www.pingjingsemi.com
Revision:1.0 May-2019
1/5
PJ8205
Electrical Characteristics
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
Static Parameters
Drain-Source Breakdown Voltage
BVDSS
ID=250µA, VGS=0V
V
Zero Gate Voltage Drain Current
IDSS
VDS=20V, VGS=0V
1
µA
Gate-Body Leakage Current
IGSS
VDS=0V, VGS=±12V
±100
nA
Gate Threshold Voltage Note3
VGS(th)
VGS=VDS, ID= 250µA
0.5
0.7
1.2
V
Static Drain-Source On-Resistance
RDS(ON)
VGS=2.5V, ID=4A
25
32
mΩ
VGS=4.5V, ID=5A
mΩ
VDS=5V, ID=5A
10
S
550
pF
125
pF
Note3
Forward Transconductance Note3
gFS
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
64
pF
Total Gate Charge
Qg
9.5
nC
Gate Source Charge
Qgs
2.1
nC
Gate Drain Charge
Qgd
1.4
nC
Turn-On DelayTime
tD(on)
9
ns
Turn-On Rise Time
tr
10
ns
Turn-Off DelayTime
tD(off)
32
ns
24
ns
0.8
1.2
V
5
A
VGS=0V, VDS=10V, f=1MHz
Switching Parameters
Turn-Off Fall Time
VGS=4.5V, VDS=10V, ID=5A
VGS=4V, VDD=10V, ID=5A
RGEN=10Ω
tf
Source-Drain Diode Parameters
Body Diode Forward Voltage
Body Diode Continuous Source
Current
VSD
IS=5A, VGS=0V
IS
Notes: 1. Repetitive rating: pulsed width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse width ≤ 300μs, duty cycle ≤ 2%
2/5
PJ8205
PD Power(W)
ID- Drain Current (A)
Electrical Characteristics Curves
TJ-Junction Temperature(℃)
Drain Current
Rdson On-Resistance(mΩ)
Power Dissipation
Vds Drain-Source Voltage (V)
Normalized On-Resistance
Output Characteristics
Vgs Gate-Source Voltage (V)
Transfer Characteristics
3/5
C Capacitance (pF)
PJ8205
Capacitance vs Vds
Is- Reverse Drain Current (A)
Rdson vs Vgs
Qg Gate Charge (nC)
Gate Charge
Vsd Source-Drain Voltage (V)
Source- Drain Diode Forward
4/5
PJ8205
Package Outline
SOT-23-6
Dimensions in mm
2.92
±0.05
1.9
0.127± 0.03
± 0.01
A
1.6
2.8
±0.1
±0.05
10
12
0.95
R0.15MAX
`4X
0.35
R0.15MAX
`4X
1.26MAX
0.06
12
± 0.05
1.1
± 0.03
0.65
± 0.05
10
Ordering Information
Device
PJ8205
Package
SOT-23-6
Shipping
3000/Reel&Tape(7inch)
5/5
很抱歉,暂时无法提供与“PJ8205”相匹配的价格&库存,您可以联系我们找货
