SHANGHAI
Feb 2008
MICROELECTRONICS CO., LTD.
SE8810A
Dual N-Channel Enhancement Mode Field Effect Transistor
Revision:A
Features
For a single mosfet
●VDSS = 20 V
●RDS(ON) < 20mΩ @ VGS=4.5V @Ids=7A
RDS(ON) < 25mΩ @ VGS=2.5V @Ids=4A
Applications
●Battery protection
●Load switch
●Power management
Construction
●Silicon epitaxial planer
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
V
Gate-Source Voltage
VGS
±12
V
Continuous
ID
7
Pulsed
IDM
28
Drain-Source Diode Forward Current
IS
1.7
A
Maximum Power Dissipation
PD
1.5
W
Operating Junction Temperature Range
TJ
-55 to 150
°C
Drain Current (Note 1)
Storage Temperature Range
ShangHai Sino-IC Microelectronics Co., Ltd.
TSTG
A
1.
SE8810A
Electrical Characteristics
Symbol
(TJ=25°C unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS
BVDSS
Drain-Source Breakdown Voltage
ID=250μA, VGS=0 V
IDSS
Zero Gate Voltage Drain Current
VDS=16 V, VGS=0 V
1
μA
IGSS
Gate-Body leakage
VDS=0 V, VGS=±12 V
±10
μA
V
B
V
ON CHARACTERISTICS
VGS(th)
RDS(ON)
gFS
Gate Threshold Voltage
VDS=VGS ID=250μA
Static Drain-Source On-Resistance
Forward Transconductance
0.5
0.8
1.2
VGS=4.5V, ID=7A
17
VGS=2.5V, ID=5A
VDS=5V, ID=5A
mΩ
19
S
693
pF
189
pF
136
pF
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VGS=0V,
VDS=8V,
f=1.0MHz
SWITCHING PARAMETERS
Qg
Total Gate Charge
VGS=4.0V
11
Qgs
Gate Source Charge
VDS=10V
1.8
Qgd
Gate Drain Charge
ID=5A
4.9
td(on)
Turn-On DelayTime
VGEN=4.0V
31
td(off)
Turn-Off DelayTime
RGEN=10Ω
96
td(r)
Turn-On Rise Time
VDD=10V
62
td(f)
Turn-Off Fall Time
ID=1A
40
nC
ns
2.
SE8810A
3.
SE8810A
PACKAGE DIMENSION (Uint:mm)
SOT-23-6
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402 33932403 33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
4.
很抱歉,暂时无法提供与“SE8810A(ESD)”相匹配的价格&库存,您可以联系我们找货
