XP151A13AOMR
N-Channel 20-V(D-S) MOSFET
V(BR)DSS
RDS(on)MAX
ID
SOT-23
0.100Ω@-4.5V
0.150Ω@-2.5V
0.5A
3
1.GATE
2.SOURCE
3.DRAIN
1
2
General FEATURE
to
r
20V
●TrenchFET Power MOSFET
●Lead free product is acquired
MARKING
Equivalent Circuit
uc
●Surface mount package
113T w
nd
APPLICATION
●Load Switch for Portable Devices
●DC/DC Converter
Se
mi
co
*w:week code
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
VDS
Gate-Source Voltage
VGS
±12
Continuous Drain Current
Pulsed Drain Current*1
ID
0.5
IDM
4.0
Continuous Source-Drain Diode Current
IS
1.0
Maximum Power Dissipation
PD
0.5
W
R θJA
250
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~+150
JS
MI
CR
O
Drain-Source Voltage
Thermal Resistance from Junction to Ambient(t ≤5s)
V
A
Note :
*1. Pulse Width ≤ 300μs, Duty cycle ≤2%
www.jsmsemi.com
第1页,共6页
XP151A13AOMR
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
0.8
1.0
Units
Static
V(BR)DSS VGS = 0V, ID =-250µA
Gate-source threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
0.5
Gate-source leakage
IGSS
VDS =0V, VGS =±12V
Zero gate voltage drain current
IDSS
VDS =16V, VGS =0V
RDS(on)
VGS =4.5V, ID =0.5A
VGS =2.5V, ID =0.5A
Forward transconductance a
gfs
VDS =5V, ID =0.5A
b
Coss
Reverse transfer capacitance
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
VDD=10V,ID =0.5A
tr
CR
O
Rise time
Fall time
VDS =10V,VGS =4.5V,ID =0.5A
td(on)
Turn-on delay time
Turn-off delay time
VDS =10V,VGS =0V,f =1MHz
co
Output capacitance
mi
Ciss
Se
Input capacitance
nd
Dynamic
VGEN=4.5V,Rg=6Ω
td(off)
tf
±100
nA
1
µA
0.085
0.100
0.135
0.150
8.0
uc
Drain-source on-state resistance a
V
to
r
Drain-source breakdown voltage
Ω
S
300
120
pF
80
4.0
nC
0.65
1.6
15.0
85.0
ns
45.0
20.0
Drain-source body diode characteristics
JS
MI
Continuous source-drain diode current
Body diode voltage
IS
TC=25℃
VSD
IS=1.0A
1.0
0.7
1.3
A
V
Notes :
a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
b.Guaranteed by design, not subject to production testing.
www.jsmsemi.com
第2页,共6页
XP151A13AOMR
Typical Electrical and Thermal Characteristics
Vdd
Rgen
D
td(off)
Vout
90%
VOUT
G
toff
tf
90%
INVERTED
10%
10%
90%
S
VIN
50%
to
r
Vgs
td(on)
Rl
Vin
ton
tr
50%
10%
uc
PULSE WIDTH
Figure 2:Switching Waveforms
nd
Figure 1:Switching Test Circuit
0.39
0.13
CR
O
Se
mi
PD Power(W)
co
ID- Drain Current (A)
0.65
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(mΩ)
JS
MI
Figure 3 Power Dissipation
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
Figure 6 Drain-Source On-Resistance
www.jsmsemi.com
第3页,共6页
to
r
Normalized On-Resistance
XP151A13AOMR
uc
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
nd
Figure 7 Transfer Characteristics
Se
mi
co
C Capacitance (pF)
0.5A
CR
O
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
0.5A
JS
MI
Figure 9 Rdson vs Vgs
Vsd Source-Drain Voltage (V)
Qg Gate Charge (nC)
Figure 11 Gate Charge
Figure 12 Source- Drain Diode Forward
www.jsmsemi.com
第4页,共6页
nd
uc
to
r
XP151A13AOMR
co
mi
Se
CR
O
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
JS
MI
Figure 14 Normalized Maximum Transient Thermal Impedance
www.jsmsemi.com
第5页,共6页
XP151A13AOMR
co
nd
Dimensions In Inches
Min
Max
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
mi
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
Se
Symbol
uc
to
r
SOT-23 Package Outline Dimensions
JS
MI
CR
O
SOT-23 Suggested Pad Layout
www.jsmsemi.com
第6页,共6页
很抱歉,暂时无法提供与“XP151A13A0MR”相匹配的价格&库存,您可以联系我们找货
