BC847B
BC847B
    PSI(宝力芯)
    SOT-23
    晶体管类型:NPN;集射极击穿电压(Vceo):45V;集电极电流(Ic):100mA;功率(Pd):200mW;集电极截止电流(Icbo):100nA;集电极-发射极饱和电压(VCE(sat)@Ic...
BC847B 数据手册
DATA SHEET BC846A/B,BC847A/B/C,BC848A/B/C NPN GENERAL PURPOSE TRANSISTORS VOLTAGE 30 ~ 65 V CURRENT 100 mA FEATURES  IDEALLY SUITED FOR AUTOMATIC INSERTION  FOR SWITCHING AND AF AMPLIFIER APPLICATIONS  NPN SILICON EPITAXIAL PLANAR TRANSISTOR FOR SWITCHING AND AMPLIFIER APPLICATIONS  COLLECTOR CURRENT IC =100mA  LEAD FREE AND HALOGEN-FREE MECHANICAL DATA  CASE: SOT-23  TERMINALS: SOLDERABLE PER MIL-STD-202G, METHOD 208  APPROX. WEIGHT: 0.008 GRAMS CASE: SOT-23 ABSOLUTE MAXIMUM RATINGS AT TA =25C, UNLESS OTHERWISE NOTED PARAMETER SYMBOL BC846 BC847 BC848 UNITS COLLECTOR-EMITTER VOLTAGE VCEO 65 45 30 V COLLECTOR-BASE VOLTAGE VCBO 80 50 30 V EMITTER-BASE VOLTAGE VEBO 6.0 V DC COLLECTOR CURRENT IC 100 mA COLLECTOR POWE DISSIPATION PC 200 mW THERMAL RESISTANCE, JUNCTION TO AMBIENT RθJA 555 °C/W JUNCTION TEMPERATURE TJ 150 °C STORAGE TEMPERATURE RANGE TSTG -55 ~ +150 °C NOTE: 1. RθJA IS THE SUM OF THE JUNCTION-TO-CASE AND CASE-TO-AMBIENT THERMAL RESISTANCE WHERE THE CASE THERMAL REFERENCE IS DEFINED AS THE SOLDER MOUNTING SURFACE OF THE DRAIN PINS. THE VALUE OF RθJA IS MEASURED WITH DEVICE MOUNTED ON 1 IN2 FR-4 BOARD WITH 2 OZ COPPER. PAGE.1 ELECTRICAL CHARACTERISTICS AT TA =25C, UNLESS OTHERWISE SPECIFIED PARAMETER OFF CHARACTERISTICS SYMBOL TEST CONDITIONS BC846 BC847 BC848 BC846 BC847 BC848 COLLECTOR-BASE BREAKDOWN VOLTAGE COLLECTOR-EMITTER BREAKDOWN VOLTAGE EMITTER-BASE BREAKDOWN VOLTAGE BC846 BC847 BC848 BC846 BC847 BC848 COLLECTOR CUT-OFF CURRENT COLLECTOR CUT-OFF CURRENT V(BR)CBO IC =10µA , IE =0 V(BR)CEO IC =10mA , IB =0 V(BR)EBO IEBO IE =10µA , IC =0 VCB =70V , IE =0 VCB =50V , IE =0 VCB =30V , IE =0 VCE =60V , IB =0 VCE =45V , IB =0 VCE =30V , IB =0 VEB =5V , IC =0 hFE VCE =5V , IC =2mA VCE(sat) VBE(sat) IC =100mA, IB =5mA IC =100mA, IB =5mA ICBO ICEO EMITTER CUT-OFF CURRENT ON CHARACTERISTICS (NOTE.1) BC846A,847A,848A BC846B,847B,848B BC847C,848C COLLECTOR-EMITTER SATURATION VOLTAGE BASE-EMITTER SATURATION VOLTAGE SMALL−SIGNAL CHARACTERISTICS DC CURRENT GAIN TRANSITION FREQUENCY fT COLLECTOR OUTPUT CAPACITANCE Cob NOTE: 1. PULSE TEST: PULSE WIDTH ≦300 S; DUTY CYCLE ≦2%. VCE =5V, IC =10mA f =100MHz VCB =10V , f =1MHz MIN. MAX. UNITS 80 50 30 65 45 30 6.0 - V - 0.1 µA - 0.1 µA - 0.1 µA 110 200 420 - 220 450 800 0.5 1.1 V V 100 - MHz - 4.5 pF V V - ORDERING AND MARKING INFORMATION PART NUMBER BC846A-T3R BC846B-T3R BC847A-T3R BC847B-T3R BC847C-T3R BC848A-T3R BC848B-T3R BC848C-T3R PACKAGE SOT-23 SOT-23 SOT-23 SOT-23 SOT-23 SOT-23 SOT-23 SOT-23 SHIPPING TAPE REEL TAPE REEL TAPE REEL TAPE REEL TAPE REEL TAPE REEL TAPE REEL TAPE REEL MARKING CODE SEE CLASSIFICATION OF hFE CLSSIFIATION OF hFE PART NUMBER BC846A BC848A BC846B 1J 1B 110 ~ 220 RANGE OF hFE MARKING BC847A 1A 1E BC847B BC848B BC847C 1K 1G 200 ~ 450 1F BC848C 420 ~ 800 1L PAGE.2 TYPICAL PERFORMANCE CHARACTERISTICS PAGE.3 SOT-23 DIMENSION Symbol L L1 W W1 E H H1 D T θ Dimensions In Millimeters Min Max 2.80 3.10 0.30 0.50 2.25 2.54 1.20 1.40 1.80 2.00 0.90 1.15 0.40 0.80 0.30 0.50 0.08 0.15 0∘ 8∘ Dimensions In Inches Min Max 0.110 0.122 0.012 0.020 0.089 0.100 0.047 0.055 0.071 0.079 0.035 0.045 0.016 0.031 0.012 0.020 0.003 0.006 0∘ 8∘ PAGE.4
BC847B 价格&库存
很抱歉,暂时无法提供与“BC847B”相匹配的价格&库存,您可以联系我们找货
