SHENZHEN TUOFENG SEMICONDUCTOR TECHNOLOGY CO.,LTD
SOT-23 Plastic-Encapsulate MOSFETS
TF2341
TF2341
P-Channel 20-V(D-S) MOSFET
V(BR)DSS
RDS(on)MAX
ID
SOT-23
0.050Ω@-4.5V
-20V
0.070Ω@-2.5V
-4.1A
3
1.GATE
2.SOURCE
1
General FEATURE
●TrenchFET Power MOSFET
●Lead free product is acquired
●Surface mount package
3.DRAIN
2
MARKING
Equivalent Circuit
412TF w
APPLICATION
●Load Switch for Portable Devices
●DC/DC Converter
*w:week code
Maximum ratings (Ta=25℃ unless otherwise noted)
Symbol
Value
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±12
Parameter
Continuous Drain Current
ID
-4.1
Pulsed Drain Current
IDM
-15
Continuous Source-Drain Diode Current
IS
-1.4
Maximum Power Dissipation
PD
Thermal Resistance from Junction to Ambient(t ≤5s)
125
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 ~+150
1
V
A
1.25
R θJA
www.sztuofeng.com
Unit
W
℃/W
Feb,2018
V1.0
TF2341
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
-0.7
-1
Units
Static
Drain-source breakdown voltage
V(BR)DSS VGS = 0V, ID =-250µA
-20
Gate-source threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
-0.5
Gate-source leakage
IGSS
VDS =0V, VGS =±12V
±100
nA
Zero gate voltage drain current
IDSS
VDS =-16V, VGS =0V
-1
µA
Drain-source on-state resistance a
RDS(on)
Forward transconductance a
gfs
V
VGS =-4.5V, ID =-4.1A
0.045
0.050
VGS =-2.5V, ID =-3.0A
0.065
0.070
VDS =-5V, ID =-2.0A
6.0
Ω
S
b
Dynamic
740
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
190
Total gate charge
Qg
9.0
Gate-source charge
Qgs
Gate-drain charge
Qgd
2.5
Turn-on delay time
td(on)
12.0
Rise time
tr
Turn-off delay time
td(off)
Fall time
VDS =-4 V ,VGS =0V,f =1MHz
VDS =- 4V ,VGS =-4.5V,ID =-4.1A
VDD=-4V,ID=-3.3A ,
RL=-1.2Ω,VGEN=-4.5V,Rg=1Ω
tf
290
pF
nC
1.0
35.0
ns
30.0
10.0
Drain-source body diode characteristics
Continuous source-drain diode current
Pulse diode forward current
Body diode voltage
a
IS
TC=25℃
-1.4
-10
ISM
VSD
A
IS=-1.4A
-0.8
-1.2
V
Notes :
a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%.
b.Guaranteed by design, not subject to production testing.
www.sztuofeng.com
2
Feb,2018
V1.0
TF2341
Typical Electrical and Thermal Characteristics
ton
tr
td(on)
toff
tf
td(off)
90%
VOUT
90%
INVERTED
10%
10%
90%
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
Figure 1:Switching Test Circuit
ID- Drain Current (A)
1.40
PD Power(W)
1.05
0.70
0.35
TJ-Junction Temperature(℃)
Figure 4 Drain Current
Rdson On-Resistance(Ω)
Figure 3 Power Dissipation
Vds Drain-Source Voltage (V)
Figure 5 Output Characteristics
www.sztuofeng.com
Figure 6 Drain-Source On-Resistance
3
Feb,2018
V1.0
Normalized On-Resistance
TF2341
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Qg Gate Charge (nC)
Vsd Source-Drain Voltage (V)
Figure 11 Gate Charge
www.sztuofeng.com
Figure 12 Source- Drain Diode Forward
4
Feb,2018
V1.0
TF2341
r(t),Normalized Effective
Transient Thermal Impedance
Figure 13 Safe Operation Area
Square Wave Pluse Duration(sec)
Figure 14 Normalized Maximum Transient Thermal Impedance
www.sztuofeng.com
5
Feb,2018
V1.0
TF2341
SOT-23 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
Dimensions In Inches
Min
Max
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
SOT-23 Suggested Pad Layout
www.sztuofeng.com
6
Feb,2018
V1.0
很抱歉,暂时无法提供与“2341”相匹配的价格&库存,您可以联系我们找货
