MMBTA42
TRANSISTOR (NPN)
FEATURES
z High breakdown voltage
z Low collector-emitter saturation voltage
z Complementary to MMBTA92 (PNP)
SOT-23
3
2
1
1. BASE
Marking: 1D
2.EMITTER
3.COLLECTOR
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
300
V
VCEO
Collector-Emitter Voltage
300
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current -Continuous
0.3
A
ICM
Collector Current-Peak
0.5
A
PC
Collector Power dissipation
0.35
W
RӨJA
Thermal Resistance, junction to Ambient
357
℃/W
TJ,Tstg
Operation Junction and
Storage Temperature Range
-55~+150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC= 100μA,IE=0
300
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= 1mA, IB=0
300
V
Emitter-base breakdown voltage
V(BR)EBO
IE= 100μA, IC=0
5
V
Collector cut-off current
ICBO
VCB=200V, IE=0
0.25
μA
Emitter cut-off current
IEBO
VEB= 5V, IC=0
0.1
μA
hFE(1)
VCE= 10V, IC= 1mA
60
hFE(2)
VCE= 10V, IC=10mA
100
hFE(3)
VCE=10V, IC=30mA
60
Collector-emitter saturation voltage
VCE(sat)
IC=20mA, IB= 2mA
0.2
V
Base-emitter saturation voltage
VBE(sat)
IC= 20mA, IB=2mA
0.9
V
DC current gain
Transition frequency
www.fuxinsemi.com
fT
Page 1
VCE= 20V, IC= 10mA,
f=30MHz
50
200
MHz
Ver2.1
MMBTA42
TRANSISTOR (NPN)
532!
0!22!
IC
18
VCE
IC
COMMON
EMITTER
Ta=25℃
hFE
80uA
70uA
60uA
50uA
10
40uA
8
Ta=100℃
DC CURRENT GAIN
(mA)
12
COLLECTOR CURRENT
14
IC
16
hFE
1000
90uA
30uA
6
Ta=25℃
100
20uA
4
IB=10uA
COMMON EMITTER
VCE=10V
2
10
0.1
4
6
8
10
12
14
16
COLLECTOR-EMITTER VOLTAGE
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
IC
10
VBEsat ——
900
Ta=100 ℃
100
1
COLLECTOR CURRENT
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
VCEsat
500
18
VCE (V)
Ta=25℃
100
IC
(mA)
IC
Ta=25℃
600
Ta=100 ℃
β=10
β=10
10
0.1
1
10
COLLECTOR CURREMT
IC
100
IC
1
fT
VBE
IC
100
(mA)
IC
(MHz)
300
fT
100
TRANSITION FREQUENCY
T =2
5℃
a
T =1
00℃
a
10
1
COMMON EMITTER
VCE=10V
COMMON EMITTER
VCE=20V
Ta=25℃
0.1
600
900
10
0.1
1200
1
Cob/Cib
100
VCB/VEB
COLLECTOR POWER DISSIPATION
PC (mW)
f=1MHz
IE=0/IC=0
(pF)
C
10
Cob
1
0.1
1
REVERSE VOLTAGE
www.fuxinsemi.com
10
V
(V)
PC
400
Ta=25 ℃
Cib
10
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (mV)
CAPACITANCE
10
COLLECTOR CURREMT
(mA)
(mA)
IC
COLLECTOR CURRENT
300
0.1
100
IC
100
(mA)
Ta
300
200
100
50
75
AMBIENT TEMPERATURE
Page 2
100
Ta
125
150
Ver2.1
MMBTA42
TRANSISTOR (NPN)
SOT-23 Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
2.000
0.071
e
e1
0.950 TYP.
1.800
L
L1
www.fuxinsemi.com
0.037 TYP.
0.550 REF.
0.300
0.079
0.022 REF.
0.500
Page 3
0.012
0.020
Ver2.1
很抱歉,暂时无法提供与“MMBTA42”相匹配的价格&库存,您可以联系我们找货
