FDN335N
N-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The FDN335N is the high cell density trenched
N-ch MOSFETs, which provides excellent
RDSON and efficiency for most of the small
power switching and load switch applications.
The FDN335N meets the RoHS and Green
Product requirement with full function reliability
approved.
VDS
V
RDS(ON),typ
46
mΩ
ID
3
A
SOT23S Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
PD@TA=25℃
±12
V
Continuous Drain Current, VGS @
4.5V1
3
A
4.5V1
2.2
A
Current2
10
A
Dissipation3
0.71
W
Pulsed Drain
Total Power
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.1
1
Typ.
Max.
Unit
120
℃/W
65
℃/W
1
FDN335N
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
VGS=4.5V , ID=2.5A
46
60
VGS=2.5V , ID=1A
61
85
VGS=VDS , ID =250uA
0.5
0.65
1.0
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=2A
5
S
Qg
Total Gate Charge (4.5V)
3.5
Qgs
Gate-Source Charge
0.6
Qgd
Gate-Drain Charge
0.45
VDS=10V , VGS=4.5V , ID=2.5A
nC
8
Rise Time
VDD=10V , VGS=4.5V , RG=6
7
Turn-Off Delay Time
ID=2.5A
30
Fall Time
7
Ciss
Input Capacitance
180
Coss
Output Capacitance
39
Crss
Reverse Transfer Capacitance
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
3
A
VGS=0V , IS=1A , TJ=25℃
1.2
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=10V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,4
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.1
2
FDN335N
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
5
IS Source Current(A)
4
3
2
TJ=150℃
TJ=25℃
1
0.6
0.9
1.2
VSD , Source-to-Drain Voltage (V)
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.1
3
FDN335N
1000
F=1.0MHz
Capacitance (pF)
Ciss
100
Coss
Crss
10
1
5
9
13
17
21
VDS , Drain to Source Voltage (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.1
4
FDN335N
Ordering Information
Part Number
FDN335N
www.hs-semi.cn
Package code
SOT-23
Ver 2.1
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“FDN335N”相匹配的价格&库存,您可以联系我们找货
