2SC3356-R25
Silicon Epitaxial Planar Transistor
2SC3356-R25
FEATURES
z
Low noise and high gain.
NF=1.1dB TYP.,Ga=11dB TYP.
@VCE=10V,IC=7mA, f=1.0GHz
z
High power gain. MAG=13dB TYP.
@VCE=10V,IC=20mA,f=1.0GHz.
MI
JS
APPLICATIONS
z
SOT-23
Designed for low noise amplifier at VHF,UHF and CATV band.
Type No.
O
CR
ORDERING INFORMATION
Marking
2SC3356-R25
Package Code
R25
SOT-23
mi
Se
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Parameter
Value
Units
VCBO
Collector-Base Voltage
V
VCEO
Collector-Emitter Voltage
12
V
VEBO
Emitter-Base Voltage
3
V
IC
Collector Current -Continuous
100
PC
Collector Dissipation
200
Tj,Tstg
Junction and Storage Temperature
-65 to +150
mA
r
to
www.jsmsemi.com
uc
nd
co
Symbol
mW
第1/4页
2SC3356-R25
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Symbol
Test conditions
Collector-base breakdown voltage
V(BR)CBO
IC=10μA,IE=0
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA,IB=0
12
V
Emitter-base breakdown voltage
V(BR)EBO
IE=10μA,IC=0
3
V
Collector cut-off current
ICBO
VCB=10V,IE=0
1
μA
Emitter cut-off current
IEBO
VEB=1V,IC=0
1
μA
hFE
VCE=10V,IC=20mA
Transition frequency
fT
VCE=10V,IC= 20mA
Insertion power gain
|S21e|2
VCE=10V, IC= 20mA ,
f=1GHz
11.5
Feed-back capacitance
Cre
VCB=10V, IE=0,f=1MHz
0.55
1.0
pF
Noise Figure
NF
VCE=10V,IC=7mA,
f=1GHz
1.1
2.0
dB
DC current gain
O
CR
MI
JS
Parameter
50
hFE
125-250
Marking
R25
www.jsmsemi.com
UNIT
300
GHz
dB
r
to
Range
120
MAX
uc
nd
co
OF
TYP
7
mi
Se
CLASSIFICATION
MIN
第2/4页
2SC3356-R25
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
O
CR
MI
JS
r
to
uc
nd
co
mi
Se
www.jsmsemi.com
第3/4页
2SC3356-R25
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
SOT-23
A
E
K
B
MI
JS
J
D
O
CR
G
Min
Max
A
2.70
3.10
B
1.10
1.50
C
1.0 Typical
D
0.4 Typical
E
0.35
0.48
G
1.80
2.00
H
0.02
0.1
J
H
C
Dim
K
0.1 Typical
2.20
2.60
All Dimensions in mm
0.95
0.95
2.00
0.90
Unit : mm
0.80
PACKAGE
Device
2SC3356-R25
r
to
uc
nd
co
mi
Se
SOLDERING FOOTPRINT
INFORMATION
Package
SOT-23
Shipping
3000/Tape&Reel
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“2SC3356-R25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.13712
- 100+0.11120
- 300+0.09824
- 3000+0.08415
- 6000+0.07637
- 9000+0.07248
