UMW
M28S
R
UMW M28S
SOT-23 Plastic-Encapsulate Transistors
TRANSISTOR (NPN)
SOT–23
FEATURES
Excellent hFE Linearity
High DC Current Gain
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
VCBO
Parameter
Collector-Base Voltage
1. BASE
Value
Unit
40
V
3. COLLECTOR
VCEO
Collector-Emitter Voltage
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current
1
A
PC
Collector Power Dissipation
200
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
2. EMITTER
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=0.1mA, IE=0
40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA, IB=0
V
Emitter-base breakdown voltage
V(BR)EBO
IE=0.1mA, IC=0
6
V
Collector cut-off current
ICBO
VCB=35V, IE=0
0.1
µA
ICEO
VCE=20V, IB=0
5
µA
Emitter cut-off current
IEBO
VEB=5V, IC=0
0.1
µA
hFE(1)
VCE=1V, IC=1mA
290
hFE(2)
VCE=1V, IC=100mA
300
hFE(3)
VCE=1V, IC=300mA
300
hFE(4)
VCE=1V, IC=500mA
300
DC current gain
Collector-emitter saturation voltage
VCE(sat)
fT
Transition frequency
Collector output capacitance
Cob
1000
IC=600mA, IB=20mA
0.55
VCE=10V,IE=50mA, f=1MHz
VCB=10V, IE=0, f=1MHz
100
V
MHz
9
pF
CLASSIFICATION OF hFE(2)
RANK
B
C
D
RANGE
300–550
500–700
650–1000
MARKING
www.umw-ic.com
28S
1
友台半导体有限公司
UMW
R
UMW M28S
Static Characteristic
hFE
160
hFE
180uA
120
140uA
100
120uA
80
100uA
60
80uA
60uA
40
Ta=100℃
1000
DC CURRENT GAIN
160uA
IC
(mA)
COMMON
EMITTER
Ta=25℃
200uA
140
COLLECTOR CURRENT
IC
2000
Ta=25℃
40uA
IB=20uA
2
3
4
COLLECTOR-EMITTER VOLTAGE
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
1
Ta=100℃
Ta=25℃
10
100
COLLECTOR CURRENT
VBE
1000
IC
1000
IC
1000
(mA)
IC
Ta=25℃
Ta=100℃
β=30
β=30
1
1
VBEsat
2000
100
10
100
COLLECTOR CURRENT
IC
10
(V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
VCEsat
1000
VCE
VCE=1V
100
5
100
1000
1
10
(mA)
100
COLLECTOR CURRENT
—— IC
Cob/ Cib
1000
1000
(mA)
IC
—— VCB/ VEB
f=1MHz
IE=0/IC=0
(pF)
CAPACITANCE
COLLCETOR CURRENT
10
Ta=25℃
VCE=1V
0.3
0.4
0.5
0.6
0.7
BASE-EMMITER VOLTAGE
fT
VBE
0.8
0.9
10
Cob
1
0.1
1.0
1
(V)
10
REVERSE VOLTAGE
IC
PC
250
COLLECTOR POWER DISSIPATION
PC (mW)
(MHz)
1000
fT
Cib
1
0.1
0.2
TRANSITION FREQUENCY
100
C
Ta=100℃
IC
(mA)
Ta=25℃
100
100
10
V
(V)
Ta
200
150
100
50
VCE=10V
Ta=25℃
1
10
COLLECTOR CURRENT
www.umw-ic.com
100
IC
(mA)
25
50
75
AMBIENT TEMPERATURE
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW M28S
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“M28S”相匹配的价格&库存,您可以联系我们找货
