HSS2301C
P-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The HSS2301C is the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS2301C meet the RoHS and Green Product
requirement with full function reliability approved.
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
VDS
-20
V
RDS(ON),typ
130
mΩ
ID
-2
A
SOT23 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
PD@TA=25℃
±12
V
Continuous Drain Current, VGS @
-4.5V1
-2
A
-4.5V1
-1.4
A
Current2
-8
A
Dissipation3
1
W
Pulsed Drain
Total Power
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.1
1
Typ.
Max.
Unit
145
℃/W
80
℃/W
1
HSS2301C
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
VGS=-4.5V , ID=-2A
130
150
VGS=-2.5V , ID=-1A
170
190
VGS=VDS , ID =-250uA
-0.3
-0.65
-1.0
VDS=-16V , VGS=0V , TJ=25℃
-1
VDS=-16V , VGS=0V , TJ=55℃
-5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-1A
5
S
Qg
Total Gate Charge (-4.5V)
4.3
Qgs
Gate-Source Charge
0.7
Qgd
Gate-Drain Charge
1
VDS=-10V , VGS=-4.5V , ID=-2A
nC
12
Rise Time
VDD=-10V , VGS=-4.5V , RG=3.3
Turn-Off Delay Time
ID=-2A
23
Fall Time
9
Ciss
Input Capacitance
270
Coss
Output Capacitance
54
Crss
Reverse Transfer Capacitance
44
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-10V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,4
VG=VD=0V , Force Current
-2
A
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.1
2
HSS2301C
Typical Characteristics
www.hs-semi.cn
Ver 2.1
3
HSS2301C
www.hs-semi.cn
Ver 2.1
4
HSS2301C
Ordering Information
Part Number
HSS2301C
www.hs-semi.cn
Package code
SOT-23
Ver 2.1
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS2301C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18088
- 200+0.14443
- 600+0.12417
